Question about AEG Lavamat 16810 Front Load Washer/Dryer
Machine starts but timer unit is not fuctioning
Machine starts refilling water but the Timer unit is not functioning. Spinning and pumping out water works only when the knob is operated manually.
    Genius:
  • 1,198 Answers
See if you can remove the timer motor and test it. If it doesn't work, check Repairclinic.com for a motor or a new timer.
Good problem description, most folks don't give us good clues.
Posted on Nov 28, 2013
How do I clear the timer fuction on my GE profile microwave
hi Donna.
this is all i could find out.
How to clear timer on GE microwave? Clearing the Timer on the Microwave. On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function. Review the Owner's Manual for model specific directions.
Clearing the Timer on the Microwave - Products - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?contentId=16868 Search for: How to clear timer on GE microwave?
or this.On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function.
How to clear the timer fuction on my GE profile microwave Google Search
Nov 26, 2017 | GE Microwave Ovens
Maytag washer starts drain pump and nothing else works
best guess timer issue
timer runs all the water ins and outs and wash cycles
or depending on model electronic controller board
not sure why the machine is unplugged often
it is worth buying a one plug surge protector
hint
unplugging to fix any washing machine during a set wash cycle only interrupts the timer
spinning the timer around fast to restart an unfinishied cycle .damages the timer
Oct 11, 2016 | Maytag Washing Machines
Hello, I have a Maytag legacy series washing machine and recently it stopped working properly, first it tripped the breaker, then in regular washing mode it washes normally but skips spinning and water...
Sounds like a bad relay array, or timer module. The little motor that makes the selector move (and then trip the function switches inside the timer module) could have trouble moving the selector past a certain point. When the machine stops, press your ear up against the timer module. Do you hear the little timer motor running? Yes? then it's probably the timer module itself, not the timer motor. I say this because you can manually move the selector to activate the modes.
Jan 03, 2014 | Maytag Legacy Series Top Load Washer
Calypso will not advance past wash cycle. I have a Calypso GVW9959K washer that displays no error codes and will run all functions in test mode. Problem is - it will run forever in the wash mode (clock...
If the machine is filling and washing but not advancing then the timer mechanism is not fuctioning. There is no codes so all other parts must be working, likke the pressure switch. You might test the door or lid switch this can sometimes hang these up. to test simply jump across the switch with a jumper wire. Basically
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • I am supplying the service manual for this machine. Please be careful when attempting any repair and always make sure the machine is unplugged before starting any repair. This manual include service guides for testing components as well if your capable of these tests. The link will lead you to the manual. These manuals are not easy to come by due to the fact they are meant for service personell who make a living on these so it is inclusive and should help you in you issue.
  • https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
  • May 13, 2011 | Washing Machines
    Whirlpool washer will occasionally be filling with water and pumping water out, problem will last until i turn timer knob to next action, after turning timer to "sweet spot" washing machine will...
    These timers are normally sealed units (crimped and pressed sheet metal) and replaced as a unit.
    If you could open one up, you'd find
    that the contacts causing the intermittent problem are burnt from arcing. All washing machine timers
    will eventually get this problem with enough use. As an electrician, you'll recognize that all switches
    (washing machine timers are a series of switches oriented around a slow (timer) motor) are rated
    for a given number of make/break cycles. Washing machine timer contacts are no different.
    If you could actually "shine up" the offending pair of burnt contacts, another pair would soon
    show the same symptoms, since all the contacts in your timer have endured the same number of
    make/break cycles.
    Feb 21, 2011 | Washing Machines
    My Maytag top load, looks like PAV2300 but not sure, will not rinse. The water drizzles a bit during the cycle and I hear the timer but the machine does not rinse. I cannot force it into rinse. I have to...
    Hi and welcome to FixYa. I am Kelly
    There is a water level pressure switch inside the top panel that has 3 wires on it and a vacuum line. That pressure switch controls the water inlet valve functions via the timer.
    If by chance the pressure sensing line is getting hydraulically locked with water due to some form of obstruction it can cause the symptom you describe.
    This pressure switch also controls the start of the spin once the water level has dropped (prevents the wash tub from being a water brake and damaging the motor clutch)
    If the water level pressure switch is working normally then the only thing left is the timer.
    You can do your own testing of the water level presure switch with an external vacuum hose (3 feet in length) connected in place of the machine hose. (DO NOT drop the machine hose when you disconnect it!)
    1. place timer on wash and start filling. LID CLOSED
    a. Force air orally into the external line
    1) Result fill stops agitation begins
    2. place timer in spin LID CLOSED and force air into external line until the pressure switch clicks.
    a. START SPIN CYCLE NOW and listen for water pump out
    b. release pressure on external air line
    1) result tub starts spinning
    If it passes the above tests your looking at a timer problem causing your no rinse situation.
    Thanks for using FixYa!
    Kelly
    Feb 18, 2010 | Maytag PAV2300 Top Load Washer
    End of wash cycle, no draining or spinning, but can move to rinse cycle and it agitates again, no spinning after rinse either
    This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
    First, see the Sears parts site for your washer:
    http://www.searspartsdirect.com/partsdirect/index.action
    Enter your model number and you'll see a list of major sub-components with diagrams and parts.
    The drain and spin functions are started when the timer advances to the spin mode.
    The motor is reversible. When agitating, the motor spins one way, when going to the drain / spin mode it reverses.
    Since the machine agitates, the problem points to the timer.
    Sep 04, 2009 | Kenmore Washing Machines
    Washer will agitate but does nothing through it's spin cycles. The timer advances through the spin cycle but you can't hear the motor run or even try to start, Washer is aout eight years old.
    When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
    • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    as you mentioned timer advances,then check out cold water entering the machine or not. If your washer won't spin, check these:
    It doesn't pump or spin
    It pumps, but doesn't spin
    It spins only with the lid closed
    It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
    • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
    • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
    • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
    • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
    • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
    • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
    • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
    • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
    Jul 13, 2009 | Maytag Washing Machines
    Indesit washing machine not spinning - fault code timer and dor lock light flashing
    my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
    May 30, 2009 | Indesit W 123 Front Load Washer
    Washer
    sounds like the water isnt shutting off once it starts washing,check the valve assy or may have a timer fault,try turning off the taps once it starts washing and see what happens if it starts pumping then timer?
    Mar 25, 2008 | Kenmore 24032\24036 Top Load Washer
    AEG Lavamat 16810 Front Load Washer/Dryer Logo
    52 people viewed this question
    Top AEG Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Einar Axel...
    Einar Axel...
    Level 1 Expert
    Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
