Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Hot air coming out of ac
Unit 3 years old - not used in two years - only hot air comes out in house - unit outside seems normally runs etc...
heating works fine!
thoughts????
    Genius:
  • 1,198 Answers
The workings of split units can be difficult to repair. I would have a professional repairman look at it.
Posted on May 08, 2009
Problem with Fujitsu minisplit heating
did you try to set to maximum heat? (suspect the thermostat is defective)
Oct 03, 2015 | Fujitsu AOU24RLXFZ Dual, Tri and Quad Zone...
MY AC WORKS FOR FOUR HOURS PER DAY AND BARELY COOLS DOWN THE HOUSE, NOT MUCH AIR COMING UP TO THE UPSTAIRS OF THE HOUSE. AFTER 4 HOURS, THE OUTSIDE UNIT SHUTS UP AND NOT MORE COOL AIR COMES IN. BEFORE THIS...
I am not understanding exactly what is happening with your unit. You say it only runs for 4 hours a day and then say that after 4 hours the outside unit shut off. But you don't describe the condition of the outside unit! Is there ice on your outside unit after it runs for four hours or is it so hot that the housing would fry an egg? Since it works for four hours and then stops working, I would guess that ice forms on the condenser grill which tells the thermostat that your air is much colder than it actually is. Then it takes time for the ice to melt off again. Am I close? If so this condition is usually caused by your unit being low on freon making everything work harder. But it could also mean that you have a leak in the system somewhere. But it shouldn't be much of a leak or it wouldn't run for the 4 hours.
I would recommend you charge it to the correct level and then check for leaks.
Aug 03, 2011 | Carrier 38CKC060 Air Conditioner
Goodman package- no heat below 30 degrees outside
I believe the unit you are describing is a heat pump. Heat pump are great when the temperature isn't below 30 With low ambient temps. outside it is much more efficient and comfortable to run aux. electric heat from the heat pump.
Jan 03, 2010 | Goodman PHKJ048-1 Air Conditioner
Earlier this week, I noticed that the house felt "stuffy" but the thermostat showed everything to be cooling as expected. Last night, the house was definitely warmer than expected when we got home. My...
nope, nope, sounds like a stuck contactor in the electrical compartment of the condenser, but there are actually several things that could cause it.
Sep 30, 2009 | Heating & Cooling
It is 98 degrees outside, and my AC is only cooling the house to around 84 degrees I am so upset. It is a new unit about 2 years old, and I got a bigger unit than I used to have.  My old unit was...
Sounds like have charge problem. You need aservice tech to check this. Make sure you ask him to check the unit split. Which means the temp. of the air coming into your reurn or filer area and temp of the air at your closest outlet. The difference between these two is the split. Should be between 19 to 23 degrees if charge is right. If this is to low the problem may be a heat strip stuck in or the charge is off. Either way you need a good service tech you trust. Not all service techs are service techs period. Ask for a free estimate on checking your unit. If you put a bigger unit in your house it should be freezing you out. Russ
Jul 18, 2009 | Ruud UAKA048 Air Conditioner
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
Rinnai 1004F Heating the Outdoors!
Do you have the Economy button on? If so, and you have a large space to heat or the outside temp is very cold the unit may not be able to keep up. If this is the case the stove runs forever, trying to reduce the temp by 2 degrees every 30 minutes. This may not work for your space and outside temp.
Your ideas about the intake and exhaust are not quit right. There is a fan that pulls air from outside over the outside of the exhaust pipe (to preheat it). This fan actually pushed the combustion gasses all the way out the exhaust. The exhaust exiting should be a little hot. In very cold temps, frost can build up around the air intake, which is right around the exhaust pipe. If you see this you will need to keep it clean. It is a good idea to look at the exhaust everyday when it really cold.
Good luck,
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Jan 10, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Fan not turning outside
Is the outside compressor running? Check the fuses in the outside disconnect by the outside condensing unit. Also check the breaker for the A/C in the main power panel.
Jul 06, 2008 | Heating & Cooling
Central ac blowing hot air outside fan not moving but making a noise
This is nothing but an either or -or ! First, make the thermostat calls for cool, there are suppose to be 2- noise outside, the fan motor and the compressor (and if a old system,a humming noise which is the contactor coil which picks up the main 240-volts).. hurry up and take a stick or something and turn the fan blades, if it picks up speed and run, then its the capicator. If not then the fan motor is bad.! (BOTTOM LINE)!
Jun 09, 2008 | Heating & Cooling
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
199 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
