Mri PCIDS/R) Serial Adapter Logo
Driver MRI PCIDS VERSION 3.0
I have to have a MRI for prostrate cancer I am a age pensioner and have been told I must pay 595$
probably correct as MRI is only part paid for
going to a public hospital will cost nothng
How Does an MRI Work
Magnetic resonance imaging (MRI), also known as nuclear magnetic resonance imaging, is a technique for creating detailed images of the human body.
The human body is mostly water. Water molecules (H20) contain hydrogen nuclei (protons), which become aligned in a magnetic field. An MRI scanner applies a very strong magnetic field (about 0.2 to 3 Teslas, or roughly a thousand times the strength of a typical fridge magnet), which aligns the proton "spins."
The scanner also produces a radio frequency current that creates a varying magnetic field. The protons absorb the energy from the variable field and flip their spins. When the field is turned off, the protons gradually return to their normal spin, a process called precession. The return process produces a radio signal that can be measured by receivers in the scanner and made into an image.
What is an MRI Magnetic Resonance Imaging
My mom had a MRI scan of her brain. White spots were detected on both her frontal lobes of her brain. What could this indicate?
MRI cancers and tumors images benign or malignant
are solid masses
not white dots ..also the patient would be presenting with a few specific symptoms if a tumor or cancer was present
and other tests would be required not just an MRI
depending on age
and health of patient ....if its good ..without symptoms
may never be a issue .
more will .will depend on the MRI radiologist report
Put all you questions and your concerns to the specialist team
MRI isnt the only diagnostic tool available to these specialists
plenty of information , biopsies , key hole techniques and trial drugs out there
one possible answer about white spots on an MRI
bright spots, representing multiple sclerosis brain lesions, that form and then grow, shrink, or disappear over 12 months
Multiple Sclerosis
I had MIR done and it said ,on the right side there is an abnormality which demonstrates enhancement. Thesextends into the neuroforamina and is certainly consistent with a plexiform neurofibroma. Thi
Magnetic Resonance Imaging. This technology measures the signal from precessing protons as they relax to a lower energy state after having been pushed to a higher energy state by a radio frequency pulse. So, the image is generated from proton concentration in the body unlike X-ray images which are generated from density differences such as bone and soft tissue. To get useful information from soft tissue, MRI is often used because soft tissue has a higher concentration of protons (H+) than say bone. Bones do not provide much useful information in an MRI scan but do when using X-rays.
My picture is very blurry and often freezes. What could be the reason?
BLurry...
1. you may adjust the focus of the camera by turning lens left or right..
Freeze problem Posibilities
1. Posible driver problem. REinstall the camera driver
2. Your Computer memory is low..
3. Display driver is not updated..
Jun 13, 2010 • Mri WebCam
Ive just plugged it in and it hasnt registered. The green light hasnt come on ontop of the cam. I have tried different usb ports but the pc isnt picking up the connection.
You need to install the software driver, either from disc or the Logitech website. After loading the driver the webcam should work. You can always test it on the free webcam test tool.
May 10, 2010 • Mri WebCam
Top Mri Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Mri Computer and Internet Expert? Answer questions, earn points and help others
