Question about Magic Chef Ovens
Kenmore Oven Glow bar doesn't glow> Can I just replace the glow bar or do I need to replace the gas valve also?
    Prodigy:
    An expert who has answered 500 questions.
  • Magic Chef Expert
  • 650 Answers
I am sure you will just have to replace the oven igniter (glow bar) These will crack and not let any power through the oven valve.
Posted on Nov 28, 2013
SOURCE: hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Posted on Dec 27, 2008
  • 4 Answers
SOURCE: Oven will not ignite
The problem is not fixed, but I know it involves replacing the ignitor and/or the gas valve. I just wanted help diagnosing the two so I only had to buy one part if I could. We live on a budget and if I could avoid replacing an unnecessary part that would help. I am afraid your elite people would just tell me to start with the ignitor and then the valve.
Thank you just the same.
Randy
Posted on Jan 03, 2009
  • 117 Answers
SOURCE: kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Posted on Feb 25, 2009
Maytag317
  • 1136 Answers
SOURCE: I need to replace the
Hi, As long as the wires connecting the ignitor are long nough, you can do this while the oven is in the wall. They usually come out far enough. Make sure the oven is unplugged or the breaker is turned off. It is fairly simple to change.
Please let me know if this helps you or if I can assist you further.
Vic
Posted on Jul 11, 2009
localwonder
  • 6784 Answers
SOURCE: glow bar comes on but oven ignites 20-30 minutes later
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working. If the ignitor did not appear to function and it is the spark type, it may be out of adjustment which generally requires professional service or it may require replacement. If the ignitor is the glow type, you can test it for resistance with a multimeter.
The ignitor has two wires connected to it.Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading anywhere between 50 and 600 ohms. If you get a reading of zero or infinity, the ignitor is definitely bad and will need to be replaced.
(((If the ignitor is optimal, this will confirm a faulty set of coils. replace them all if this is the case))).
Posted on Jul 28, 2009
Whirlpool oven wont start, is there away to light the pilot?
You don't say what model you have. That being said, I highly doubt it uses a pilot light. It most likely uses a glow bar igniter to ignite the gas. Take the bottom of the oven cavity off (remove the racks and you'll see a couple screws in the back on the bottom. Remove those and the bottom of the oven cavity should lift up).
Once you have the bottom cover off, turn on your oven and watch the glow bar. If it glows bright white, it's good and your gas valve is most likely bad. If it doesn't glow at all, or it's not very bright, or it has one bright white spot on it and the rest of it looks a little yellowish orange, then you need to replace the glow bar igniter.
Anyway, that's where I'd start.
Nov 04, 2014 | Whirlpool Ovens
No gas flow to oven, glow bar ignites no flame no smell of gas. safety gas safety valve was replaced
With the glow bar going and no gas smell that means you have a good circuit from control to valve and glow bar. For that glow bar to work it must change in resistance. If it is weak it won't change enough resistance to make the gas valve bi-metal open. Also the gas safety valve does not come preset and usually is bottomed out all the way for propane. You must adjust the orifice to aprox the same height as the old one to get the propah gas output for natural gas.
if your old valve did not leak and has continuity between the terminals it is fine. The ignitor/glowbar is weak. If it is dim orange that is usually a way to tell. Bumping the stove makes the bi-metal come on also is a sign of a weak glowbar
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 14, 2011 | Magic Chef Ovens
I have a Kenmore Gas Wall Oven Model Number 911.30469894. When BAKE is selected, temperature shows 100 degrees and the oven never starts up or gets hot. BROIL works fine. Thank you, John
The oven control supplies voltage to the oven igniter/gas valve circuit. When the oven control is set to Bake, voltage is supplied to the oven igniter which should glow bright red to almost white hot. Once the igniter comes on and begins to glow it must pull enough current to cause the gas valve to open so the burner can ignite from the igniter. I added an image below with the theory of operation. Click this link:--http://media.fotki.com/1_p,swbbsqrsgstsqkkxgtqsskgwtqkq,vi/wrgtsbrktxwdfwfbgdg/1/1303472/5961857/image5576034710104836299img-or.png
----Open the broiler drawer and then set the oven control to bake and watch to see if the glow bar igniter glows or not. If it does not glow, the failure could be a broken Igniter, failed oven control board or gas valve. If the igniter is glowing red, then it can be possible that gas valve is faulty. To see how igniter looks. See the fig below:--
To order this part click the link below:--
http://www.repairclinic.com/PartDetail/Hot-Surface-Glow-Bar-Igniter/1990?modelNumber=911.30469894
Also to confirm, check to see if the igniter is getting 120 volts when it's turned on. If it gets 120 volts, then your safety gas valve is bad because it's not letting the neutral go through. Otherwise, if it's NOT getting 120 volts, your control board shorted out and you need a new control board.
But as you mentioned that control board is replaced. So igniter should get 120 volts. If valve is faulty. But if igniter is not glowing then its faulty igniter confirmed.
To see how gas valve looks, please click the link below:---
http://www.repairclinic.com/PartDetail/Gas-Safety-Valve-Assembly/251898
In most of the cases the igniter is faulty, because gas valve getting faulty is very rare. But still getting the voltages checked, will confirm. These will help. Thanks. Helpmech.
Feb 04, 2011 | Kenmore 30464 / 30465 / 30469 Gas Single...
GE gas oven--Spectra--the oven does not heat--the broiler works, however
Most common problem is the glow bar ignitor. Lift off the bottom panel of the oven and remove. (Some have two screws holding the panel at the back of the panel.) Turn the oven on and see if the glow bar glows.
Even if the glow bar glows doesn't mean that it is working 100%. An amp probe is need to see if the glow bar is drawing the proper amperage to allow the gas valve to open allowing gas to come to the burner. The glow bar should draw about 3.5 to3.8 amps. If drawing more or less than this, replace the glow bar ignitor.
I hope this helps.
Jan 25, 2010 | GE Ovens
Kenmore gas oven 362.7163191 wont light, what could be the problem ?
The glow bar ignitor in the oven is going bad. Remove the oven racks. Remove the base pan in the oven. This gives you access to the glow bar.
Turn the gas off to the oven. Place a clamp on amp meter on one wire of the ignitor and turn the oven on to Bake. If the amp draw is 3.2 or less,replace the glow bar ignitor.
Nov 22, 2009 | Kenmore Ovens
Glow plug comes on and smell gas but no fire
That is a bad gas valve. Need too change it out. The glow bar is working but the valve is not opening.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 02, 2009 | Tappan 30IN ELEC IGNa Oven
I replaced the igniter (glow bar)on our Kenmore
IF THE UNIT IS 14 YEARS OLD BE CAREFUL THE GAS VALVE MAY BE GETTING TO THE POINT WHERE IT IS NOT SHUTTING OFF AS QUICK AS IT USE TOO, YES THIS WOULD CONCERN ME ,YOU DON'T KNOW IF ONES OF THESE TIMES THE GAS VALVE MAY NOT SHUT AND GAS BUILD UP COULD BE POSSIBLE ,NOT A GOOD THING. PLEASE BE CAREFUL
Aug 31, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
Kenmore gas range model # 362.7121191 oven
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Glow bar??
it sounds to me like you are on the right tract yes you can change this item pretty easily after you remove the covers it just plugs in just follow your wires and do not touch the new glow bar with bare hands use a clean rubber glove like doctors wear to hold it (the oils on your hand will cause it to go bad faster.although rule of thumb is to replace the glow bar and gas valve at the same time you may get lucky and fix the problem with just the glow bar.after you replace the bar (if it does not work the problem would be the gas valve>NOT RECOMMENDED TO DO IF YOU HAVE NO MECHANICAL KNOWLEDGE
LET ME KNOW HOW IT TURNS OUT FOR YA.YOU CAN EMAIL ME DIRECT AT FIXITRIGHT1@YAHOO.COM I HOPE THIS HELPS YA
BILL
Jan 06, 2009 | Ovens
Electric starter gas oven model jgrp17 won't heat
more than likely your glow bar ignitor has stopped working or at least pulling enough amps to open the safety valve. The floor of the ovens come out may have a couple screws toward the back. take the floor out if a diffuser is on top of the burner remove it. the glow bar ignitor is mounted on the burner turn the oven on and watch it should glow bright red and in about 30 secs open the gas safety valve. If it does not glow you may want to verify power to the ignitor, more than likely the ignitor is the problem. If it glows but does not open the safety valev still replace the ignitor not pulling the required amps to open the safety valve. just put a little dish soap on the screws to the ignitor to help from srtripping them out
Nov 13, 2007 | GE JGRP17 Gas Single Oven
Ovens Logo
41 people viewed this question
Top Magic Chef Ovens Experts
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
