Question about Sony SA-W305 Subwoofer
How can I use my sub woofer sony SA WMS315 as a by itself using it just for a small emplification
I have the surround sound pacage SAWMS315 that I cannot use due to a damaged emplifier. Can I use the subwoof unit by it self, inputing other sound source. It has some inputs at the back
markevans
  • 148 Answers
SOURCE: Sub-woofer Malfunction
sub can be detecting signal from your amp. maybe your amp has some small output when in standby mode. some amps throughput signal from satellite boxes when they are supposed to be off.
try shutting off that signal source as well.
good luck
mark
Posted on Dec 28, 2007
early1234
  • 871 Answers
SOURCE: sony sa-wx90 subwoofer
thats called electrical recoil, the energy that is stored bursts out thru your subs therefore you hear your subwoofer bang.
i suggest you clean your wirings.
hope this helps.
Posted on Jan 14, 2008
VOTIT
  • 2071 Answers
SOURCE: HOOKING UP THE SONY SA-WM20 TO AN AUDIOPHILE PREAMP
Just click and choose whatever connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Sep 02, 2008
welcomejee
  • 10594 Answers
SOURCE: I would like a manual for my sony sub woofer model sa - w305.
Download operating manual for SA-W305 from Sony Support.
Posted on Dec 18, 2008
SOURCE: Power, but no sound
take an ohm meter and remove wires from speaker...put meter in the ohms position...you will put a lead on each of the terminals of the speaker...you should have a reading of 2, 4, 8 ohms....you may also try to use the continuity test, same, but there will be a beep ....this basically ensures that the coil running through the speaker is still good, as one piece, otherwise it will get no good reading and this is usually from blowing the speaker or sudden high bass sounds....
Posted on Aug 09, 2009
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
Replacing sub speaker
I wouldn't try reinventing it by replacing the driver. Drivers and their enclosures are designed to work together. And this being a self-amplified subwoofer, there is one more piece that's electrically optimized to the rest. Don't mess with it.
Why don't you just set your receiver's individual relative speaker volume levels so the sub isn't weak by comparison to your other speakers? Weakness, as you call it, is relative.
Is your receiver properly channeling Low Frequencies to the sub? Experiment with the cutoff, too.
This problem doesn't require meatball surgery.
May 18, 2009 | Sony SA-WM500 Subwoofer
Surround sound system is not producing sound through the subwoofe
Several things could cause this, to make sure the sub woofer is working at all disconnect the cable from the back of the receiver. You should hear some sort of output from the subwoofer when you handle the plug. IF so replace the plud and go into your settings menu (press the A and B button at the same time) and go through the speaker set up. It may be that the receiver has not retained the memory that there is a sub woofer connected.
I hope this helps.
Feb 24, 2009 | Panasonic SA-HE90 Receiver
Lcd speakers
I suggest to unplug surround and sub woofer so you will get sound from front speakers only.
Dec 12, 2008 | LG 42LG50 42 in. LCD HDTV
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Surround sound
How do I hook-up my surround sound system with powered sub woofer to my Sony stereo receiver and sony dvd player?
Sep 19, 2008 | Sony DAV-HDX500 System
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
good luck
mark
Dec 28, 2007 | Sony SA-FT1H TV Speakers
Sony SA-W305 Subwoofer Logo
62 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
