Question about KitchenAid KESC300 Electric Kitchen Range
Lower bake element dosent work - KitchenAid KESC300 Electric Kitchen Range
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Whirlpool wgp30801
It is common to have the broil element pulse on or they will send 120 volts to the broil element to even the heat in the oven. Some ovens have a preheat function that will power the broil and bake simultaneously until the oven reaches temperature then the broil element will shut down. If they both stay on red continuously through the entire bake process then something is wrong. Probably a stuck contact on the control.
Feb 12, 2014 | Ovens
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 | Ovens
Lower oven top element
The top element is not supposed to come on in bake mode. only when broil is selected.
Jun 28, 2017 | Maytag MER6769 Gemini Electric Kitchen...
Top element does not work in bake mode,but it does work in broil mode
The top element is a broil element and will not come on in bake mode just as the lower bake element will not come on during the broil mode
Aug 21, 2011 | Maytag MER5775Q Electric Kitchen Range
Bake element
It may have also Blown the Fuse, to the element, in the stove itself.
Feb 12, 2010 | Dacor ECD230 Epicure Electric Double Oven
Lower elment not working
The lower element is known as the bake element. It is controlled by a bake relay on the control board. Either the relay on the control board has failed, or the element has failed. The most common fail is the element itself. The following link explains how to replace a heating element (if required):
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
If the model number is correct, the part number for a replacement bake element is WB44T10011. You purchase replacement parts at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare.
If you have any questions, please let me know. I hope this help you.
Nov 26, 2009 | GE Spectra JBP84 Electric Kitchen Range
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Element Question
In most ovens, both elements are used during the warmup phase even when used for baking and after the set-temperature is reached, the lower element keeps it stable.
You should be able to detect which one is not working with your bare hand. Set the baking temperature for 250-300 degrees, leaving the oven door open. Hold your hand at different heights in the oven and you should be able to sense which element is working and which isn't within a couple of minutes.
If you still aren't certain, then try using the broil element only. If it is heating, then it's obviously OK and that would point to the bake (lower) element by default.
A final check could be done with an open door and hovering with your hand over the lower element; no heat = defective.
Mar 03, 2009 | Amana AOES3030SS Oven
Bottom Baking element not working
dmiller58
If all your connections are solid then your controller is defective. Did you get any faults before changing the element? Does the broil (one at the top of the oven) work?
Post a response
Regards
Sep 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
KitchenAid KESC300 Electric Kitchen Range Logo
27 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
