Question about Pioneer PureVision PDP-4340HD 43 in. Plasma HDTV
Red and green lights on media reciever box are flashing all the time.whats wrong with it?
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Pioneer pdp-ro3u pops up E01 then shuts off
reset the device by unpluging the device for somr minutes and then again replug and see if it works.
thanks.
Oct 28, 2008 | Televison & Video
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Danfoss rx1 thermostat shows 'of' ?
Remove batteries from room stat,turn off the electrical supply to reciever unit.
Turn back on the electric to reciever unit,the red light should be on,press the top "manual" button,the green light should come on and boiler should fire (assuming the programmer is in an "on" period)
Press the bottom button,and keep it pressed,then press the top button until the green light flashes,stand about 6 feet away,and refit the batteries to the stat while observing the reciever unit,either the red or green light (cant remember which) should flash to show the 2 units are syncronised.
Another basic test if all seems ok,when turning the stat up or down,when the green light on the reciever unit comes on or goes off,its usually accompanied by an audible "click" ive found,that if this is not happening, the reciever unit does not switch either on or off,may be intermittant.
Replacement is the only cure.
garden led light
Jun 04, 2012 | Garden
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Dec 31, 2009 | Televison & Video
Power green light will flash then flash red when first turned on
Please intimate exact model of your Sony TV to find out reason of no power up.
Jul 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Mar 29, 2009 | Pioneer PureVision PDP-4340HD 43 in....
I have Pioneer plasma screen using a media box. When I switch it on the red and green buttons flash alternately for several minutes before it comes on. Once on the tv works ok. It is only on starting that...
This may be due to the media box taking its good old time to set up when you turn your tv on.
Try without it and see if the problem goes away.
Mar 12, 2008 | Televison & Video
The reciever box light flashes red
Same issue here in NZ with a set.  Fixed (twice) before.  Same problem for the thirs time in 4 years. Solution  - get a Sony.
Feb 11, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
Returns to standby
Green flashing 3 times = digital DC - DC converter fault
Red flashing 3 times = scan circuit fault
Oct 31, 2007 | Pioneer PureVision PDP-5040HD 50 in....
Pioneer PureVision PDP-4340HD 43 in. Plasma HDTV Logo
26 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
