Question about Davka Simcha Planner Deluxe
Need simcha planner to work with windows 7
My old data is stuck in my computer and I cant retrieve it without the program which windows 7 wont support HELP!!!!!
Could you please illustrate your problem in details,
1. what and when happen and also
2. now what you wants.
Posted on Dec 02, 2013
How do i remove sierra event planner from my windows 10. Managed to remove Hallmark card studio but cant now reinstall it.
in windows 10 on the charms bar, touch the search option and type in what your looking for and it should come up. you can also go to the my pc which should be the c drive and see if there is a folder of the program and see if you can delete it also
Mar 20, 2016 | Sierra Hallmark Card Studio Deluxe 2005...
Data retrieval
There are some things that you can try. Look and see if Vista drivers work. Also if you are using the more advanced versions of windows 7, you can use XP mode in the windows 7 environment and see if you can install the drivers for it.
Jun 29, 2013 | Iomega Computers & Internet
American Greeting Print Premium Windows 95/98 Will the above programe work on Windows 7?, I am having problems retrieving old templates that I need access too. Im currently running windows 7; however, the...
More than likely it will not. What you can do is run a virtual PC. But it also depend on if the program will run in XP or win 2000. If you have a windows 95 or 98 disk and key, then you can install it with Virtual PC from Microsoft. Check it out here:
http://www.microsoft.com/windows/virtual-pc/default.aspx
May 03, 2011 | Computers & Internet
My old computer with a Borland dBase 5.0 program on it crashed but the hard drive was salvaged and I have hooked it up to my new computer. However, my old computer ran Windows XP on 32 bit, the new one...
Do I need Windows XP Mode?
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software. Visit the Windows 7 Compatibility Center to find software that works with Windows 7.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
It's the best of both worlds: The new Windows XP Mode lets you run older Windows XP business software right on your Windows 7 desktop.
Designed primarily with small- and medium-sized businesses in mind, Windows XP Mode comes as a separate download and works only with Windows 7 Professional, Ultimate, and Enterprise. Windows XP Mode also requires virtualization software such as Windows Virtual PC. Both are available free on the Microsoft website.
Download
Learn how
Jan 23, 2011 | Borland DBASE 5.0 Upgrade Version Academic...
I forgot password how can i use
This is hard to answer without knowing what operating system you are referring to.
If you are using windows XP you can try logging on with
Username: Administrator
no password
The go in to the control panel and reset a password for the user you want to log in with.
Log out and log back in.
Dec 06, 2010 | Computers & Internet
I backed up all my files when I switched to Windows 7 from XP but I don't know how to retrieve my data.
when saving files from any OS two methods come to mind 1. using windows to back up files . and 2. using
a redundant static drive ( a HD without an OS installed
or an external HD without an OS installed ) , since you used windows to back up your files you'll have to find them in Documents , they will be listed as the old user IE ; "Tom's Computer" if you didn't use the same user name ( name of computer ) you'll find it tricky to
apply the old data to the new OS , note that some programs wont work with windows 7 if 64 bit because the drivers that run the programs will not install into
windows 7 , most manufacturers are hurrying to update the drivers to windows 7 since 7 is no long in its infancy .
Jan 14, 2010 | Computers & Internet
Cant log in on vista password forgotten
Discussion: When we are running imagex we are not deleting user data from the HDD, in this process we are overwriting data. But, its better to set expectation to Customer that thre might be possibility of data loss. After completing the process we can logon to the system with new user account that we create and we can retrieve data from old user profile.
Here is the process to run Imagex:
1. Boot to the computer using VISTA DVD.
2. Select the option repair my computer.
3. Go to command prompt
4. Go to D: prompt
5. Type Path d:\windows;d:\windows\system32 and press Enter
6. Go to Tools folder using command "cd tools".
7. Use this command Imagex /apply d:\dell\image\factory.wim 1 c:\
This process will take 15 Minutes after that reboot the system. After rebboting we will get OOBE Screen.
We can logon to the system using new username. We can retrieve the data by navigating to old user profile.
How to retrieve the data from the old user profile after using the Imagex procedure :
1. Click Computer
2. Click Local Disk C:
3. Locate Windows.old and double click on the same
4. Click Users
5. Click <username>
Note : <username> would be the login name for which he has forgotten the password
6. Accordingly you can access the files available in the folders Desktop, Favourites, Music, Downloads etc
Nov 26, 2009 | Computers & Internet
Forgot the password on my Asus Eee PC Note book
Get your hands on Hiren's boots-cd from http://www.hiren.info/ or piratebay or any other place you find. Burn it on a cd or on an usbstick (follow the instructions at hirens.info) then boot your computer with this cd/usb-stick.
You will find that there is 3-5 password-tools you can use. Use the first one and clear your password.
Reboot without hiren's connected and login to your account.
Done.
Sep 15, 2009 | ASUS Eee 4G Notebook
Need to replace hdd but cant copy old one
The Drives Reader arm Is Either Stuck Or Knocked Off Track And Can' Pass Over The Platters... The Hard Drive Will Need To Be Opened Up And Inspected/Repaired Before Data Can Be Retrieved..
You would hear a ticking or knocking sound if the arm is not working right.. If It Sounds Like its Running Properly You Might Have Erased Data by Scratching The Platters, You Can Try Using A Software Named.. Recover My Files..... And Do A Low Level Search, If THere's any life in the drive, This Program will find the data.....
Feb 07, 2009 | Toshiba Satellite A135 Notebook
Davka Simcha Planner Deluxe Logo
63 people viewed this question
Top Davka Computers & Internet Experts
David Payne
David Payne
Are you a Davka Computer and Internet Expert? Answer questions, earn points and help others
