Question about Braun Oral-b oxyjet md20 irrigator electric rechargeable toothbrush [md20]
Braun oxyjet will not **** up water to spray.i have cleaned it inside and outside.however there is a spring that has come off inside. Not sure where this goes.
Need to fix on the small spring about 1 cm in length.not sure if air is coming in to tube when pump is on could this be blocked?
3 Suggested Answers
  • 3 Answers
SOURCE: Braun Cruzer3 trimmer not working / spring replacement.
Try this out:
Posted on Jul 30, 2012
robertcbowde
SOURCE: On the Braun Oxyjet dental care unit the hose
Spare hose assemblies for WaterPiks are available , maybe they could be cut and spliced . . Geekoz.com
Posted on Nov 24, 2012
Haven't used my Braun tammiso 1370 for Afew years , all lights flashing and not working
"All lights flashing" on Tassimo is a general error condition. But the two absolutely most-likely conditions to cause it are:
1: Unit is not detecting a water tank with sufficient water in it. Inside the tank, near the bottom, there's a vertical chamber that holds a small, floating magnet. As long as the tank contains some water, that magnet should float to the top of its chamber, where it can be sensed by a detector hidden inside the brewer. Make sure your magnet is present and not stuck, and that the water tank is seated correctly.
2: Unable to read bar codes. Use a damp cloth to clean the bar code scanner window under the T-disc holder. Use the cleaning disc to test.
Apr 26, 2015 | Braun Health & Beauty
Braun oxyjet does not suck water to spray
check to see if the moter is working on the washer by turning ignition on and activating wash you should hear it. if not check pipes to wash from resovour. if that fails could be blocked jets. clear with a pin.
Nov 27, 2013 | Cars & Trucks
CLEANING
Remove it from the window,just slide it out from the shell,make sure there are no retaining screws,remove the front from the unit,and set it on a table outside,use a water hose and spray all debris from inside the unit,just remember not to spray hard stream of water directly into the coils on the evaporator,or condenser,you may have to remove some debris by hand if it is to large for the water hose to remove,make sure drain holes are clear,and let drip dry for about 30 minutes,then tilt unit one way,or another to finish draining the water,coils can be cleaned gently,just make sure nothing is restricting the air flow threw them,and make sure the fan has no objects in it`s way,then place the unit back in the shell in the window and you are ready for another hot hot summer.
May 28, 2010 | LG Heat cool Window Air Conditioner
Braun electric water heater lid came off along with spring parts, all intact. How do I re-assemble it? Manual? Schematic available?
This is the solution for the BLACK Braun electic water heater, so you must adjust the color to fit if yours is another color.
First take the 3 pieces that go inside the top. Two look like a "Z", and the other is the square, white doo-dad. Take the square piece and slip it into the slot with lid open. YOU CANT PUT IT IN FLAT UNLESS THE LID IS OPEN! Make sure that you can put it in FLAT. Once it is in flat, take it back out. Now you have the 2 "Z" pieces. Fiddle around with these pieces until you learn how to put them in together so they will fit together. This may take several tries. There is a piece that acts like a pivot. Now take all 3 pieces out. The trick is not to put the 2 "Z" pieces in together. You have to figure out what Z-piece to put in first. Then put the rectangular white piece in, and then the other Z-piece. This all must be done with the lid OPEN, otherwise the rectangular piece will not lie flat. Make sure the little spring inside this rectangular piece it put in properly - it should be against the little black doo-dad on the lid. If everything is sitting happily together, you should be able to snap the other black part onto the lid, and close it successfully.
May 16, 2009 | Braun WK200 AquaExpress Electric Water...
How do I clean out the vents in my RV Dometic roof ac?
Take it off,the plastic inside vents, with soap water and a hose wash it.  Outside condendor and inside evapator, making sure the drain is open and outside shroad removed, brush off fthe loose stuff. wet both units, put liquid dishwashing soap on both. Spray then through , with a hose untill they rince clean.  While up there. Oil the motor if possible.  Keep the drain clear and open,making sure none of the water is getting into the RV.
May 08, 2009 | Dometic Rooftop RV Air Conditioner
Need to find manual for bunn coffee maker
You can go to Bunn.com and print one out or I think buy one. To clean you need a deliming spring and white vinegar. You put the spring up into the hole where your water comes out of to empty into your carafe. Remove the grounds basket. then remove the spray head by twisting off. Then you are ready to put the spring into the hole. Insert all but a couple of inches into it. If it has been awhile you may have to force it by twisting and pushing. Work the spring up and down and it will eventually go in and out with no problem. Check the holes in the spray head to make sure they are clean and free of any build up. As you know Bunn has a reservoir where water is kept hot. You put in and what is in the reservoir comes out. Pour 1 quart of white vinegar into the pot. Let it sit for two or three hours or longer is OK. After your wait pour water in 8 to 10 times to flush all vinegar or you can unplug the pot and turn upside down over the sink. If you do this while the water is still hot be careful. Most of the water will come out of the hole where you put the deliming spring into. Some will come out of the top possibly. If you do it this way make sure you fill back with water before you turn it back on. Repeat vinegar flushes again if you water isin't running clear yet.
Mar 14, 2009 | Bunn NHB Coffee Maker
Air conditioner cleaning procedure
If its a window air conditioner, take it our of the window, then take it outside unplugged. Spray the coils with a garden hose at low water pressure. You don't want too much water pressure cause it can bend the fins. Also try not to get the electrical components wet. Spray the water strait into the coils at a 90 degree angles to push the dirt free on the inside of the condensor( outside coil).
Jan 24, 2008 | Heating & Cooling
Braun Oral-b oxyjet md20 irrigator electric rechargeable toothbrush [md20] Logo
246 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
