Question about RCA 46 46LA45RQ LCD TV
Rca shop mode - RCA 46 46LA45RQ LCD TV
RCA camcorder model # CC6363 is stuck in safe mode and I can't eject my tape, how do I solve this?
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=RCA+camcorder+model+%23+CC6363+is+stuck+in+safe+mode+fix
Hi at the above link, you will find a myriad of people with a problem exactly the same as yours, it is a real headache, with NO real, well DIY fix, sorry, it appears that RCA will repair it for a price, so maybe it would be simply best to bite the bullet, and take it to a professional RCA servicing center, but ONLY ask for a "Quote". Now when you get this information, then you can make up your mind as to what to do, repair or replace?
As an aside here, and it is mentioned in that link i give you above, that this problem is a "Known About Issue" and in some countries they have been made to repair this issue FREE of charge to customers...
I actually haven't come across this exact type of problem with this exact type of camcorder, however, in my shop, I have seen similar repairs etc, and they can cost upwards of $200.00, so make sure you always get that quote. Further, there are a few postulated "Fixes" in that site given too, you can not do any real harm in trying any or all of them, especially the one about cleaning the "Heads & tape transport path" as described, this may just work, as may the Battery Removal/Replacement ... so good luck.
Jun 27, 2011 | RCA CC6373 Camcorder
How do i hook it up to my toshiba laptop
You need a cable like this. The left end goes to your laptop and the 2 cables goes into your Sony system. It's called a 3.5mm to RCA cable an you can get it at any supermarket/audio shop. You will also need to set your system to AUX/input mode.
Mar 03, 2011 | Sony CMT-HP7 CD Shelf System
RCA 42" lcd tv won't turn on
Must be a dirt cheap part if they are willing to absorb that cost and just charge for labor/ unit is out of warranty.
May be a power supply issue and that is something worth checking if the supply is very reasonable in cost.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Sears Online In Store Shopping Appliances Clothing More
Sep 20, 2017 | RCA L42FHD37 42 in. LCD HDTV
Can RC65 remote replace the original RCA Remote for DirectTV?
http://shop.ebay.com/items/rca+universal+remote?_dmd=2&_cpr=249 this is a e-bay web page link for purchasing RCA universal remote controls. Here you will find all different makes and models of RCA remote controls. They are for immediate sale and for auction. You should find the model number of your old remote control and put the number into a search engine to find the replacement mode for your television.l.Once you have the model number you can go to the e-bay web page and find the model and purchase it. If you cannot find it there. Use the model number in the search engine to find places to purchase the replacement. I hope this information help you find a replacement remote control for your television. Thank you for using FixYa and have a nice day!
Mar 28, 2009 | RCA DIRECTV Satellite Remote Control
I've hooked up my dvd player to my rca television
Did the dvd Play? if yes, Maybe you have to select in the VIDEO mode on your t.v. not in the CHANNEL Mode. Because you cannot watch video in channel stations unless otherwise you have RF tuner. or the rca plug is faulty???? Try another rca
Mar 20, 2009 | RCA Televison & Video
Jensen LXA400 Fuse Size and RCA hook up for 2 channel mode?
take it to a stereo shop. there are variables you may not be aware of when hooking up speakers to an amplifier like ohms, very important!
Dec 08, 2008 | Jensen LXA400 Car Audio Amplifier
Green Screen Then Shut Off
No hay mas solucion que llevarla a un taller para que te la reparen ya que tiene daño en el socket del cinescopio.
Dec 16, 2007 | RCA 20F420T 20" TV
Scrambled Picture/Snow Screen, has sound, can play DVDs through colorstream
I had this with a rca once. Can you hear a crackeling noise coming from the flyback transformer? My problem was just the wire was loose
Sep 27, 2007 | Toshiba TP50H50 50" Rear Projection...
New Remote
Theres not alot you can do as most universal remotes, you cannot get into the menu to program the TV sets ot use any special audio functions. But this is an RCA universal so you should be able to get into the audio menu with it and change to nornmal audio. Also You should see if anybody you know has a RCA remote that may work for you That you can borrow to do this with
Sep 22, 2006 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Vertical Green/Purple Lines on lower half of screen
I would contact RCA if the repair center dosent know how to troubleshoot this set. But I bet its an eeprom or ground issue. Contact RCA here at 580-634-0151 or At https://www.rca.com/secure/service/contactrca/1,,,00.html Good Luck
Jun 15, 2006 | RCA Scenium HD65W20 65" Rear Projection...
RCA 46 46LA45RQ LCD TV Logo
16 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
