Flashes code "ddo" - Washing Machines
  • 15,935 Answers
Ddo is Dispenser Drawer Open
Check to see if the Dispenser Drawer is open or the small tubular Magnet # 51 is missing
Magnet is shown at location #51 on page two of this parts manual..
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995430112.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
DDO have the problem that is the part that I have to change
Thank you for your inquiry, edwin chiu!
Based off the information you have provided your Frigidaire washer is displaying the error code "DDO". "DDO" stands for dispenser door open which could be a problem within your door or reed switch. I would recommend opening and closing you do to secure the connection is proper.
If that does not correct the issue I would perform a reset on your washer which you can do by disconnecting the power from it by either unplugging the power cord or flipping the household circuit breaker for ten minutes. Hopefully this information has been helpful. -Matt
Sep 26, 2014 | Frigidaire Affinity Glacier Blue 3.5 Cu....
MACHINE FLASHING DDO CODE
Hi Friend, this is Z. Thank you for allowing me to assist you!
Generally, error code DDO means that the dispenser drawer on your unit may be open. If so, close the drawer and the error code should resolve itself.
If you've double-checked the drawer and it is closed, remove the drawer and examine the magnet. If the magnet is missing or defective, the magnet probably needs replacing.
If the magnet is fine and in place, an experienced technician may need to examine the reed switch or main control board.
Since there are cost differences in parts and accessories, it is always a good idea to have a service tech properly diagnose your appliance.
Jul 12, 2014 | Electrolux EW1200i Front Load Washer /...
Error code DDo ON A FRIDGEDAIRE FRONT LOAD WASHER
Hello geraldinerid - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a further diagnosis is recommended to have a professional check the reed switch.
Apr 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Front load washer with ''ddo'' code
The DDO trouble code means that the detergent(D) dispenser(D) door is not closed properly((O)open).
The door uses a reed switch and a magnet to send the door closed signal to the control card.If the
magnet becomes dislodged you will get this code.You will need to have the magnet replaced in
its proper position to clear this code.
Apr 05, 2010 | Frigidaire GLTF2940ES Front Load Washer
Ddo
Hi
This ddo error code means Dispenser Drawer Open.Check to see if the Dispenser Drawer is open or the small tubular Magnet # 51 is missing. The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself, you will see snapping clips to unsnap, then you will see the magnet#8 in diagram#1 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=117979
reference
http://www.fixya.com/support/t2180388-code_ddo
Mar 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
Ddo error code on frigidaire front washer
Hi
Thanks for using FixYa. Error DDo means dispenser drawer open. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch to "tell" the machine that the drawer is closed. That magnet might have moved from it's place and that's why you are getting error ddo. magnet is part key number 51. Pull the drawer out and check on the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Please check this link for details(part #51)--
Frigidaire exploded parts catalog
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
Code ddo
Hi
This error code appears in the frigidaire washer which means--
ddo error--- Dispenser Drawer Open
GLTF1670AS0
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 08, 2009 | Washing Machines
Error code ddo
the dispenser drawer has a magnet in it that has to line up with a sensor. if you can put the drawer back in that will solve the problem. if the magnet isn't lost.
Oct 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Error code ddo will not start wash
This indicates a problem with the door interlock switch and until resolved the machine will not start.
Sep 18, 2008 | Frigidaire GLTF2940ES Front Load Washer
Our washer has an error code of DDO.
ok if it is the rigt thing for that code there will be a switch on the door have a pen or some thing you can use to trip the switch to thinking the door is closed. and unplug the unit and replug it in.. todays age every thing has to rebooted
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 16, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
