Question about Motorola Mobility Droid RAZR HD
After reset factory i get the message phone locked code 0 and its not starting
I did a factory reset but my phone got locked and rebooting again and again
  • Official Brand Answer
  • 3,100 Answers
Contact Verizon for replacement or Motorola: Select Your Location Motorola Google Company
Posted on Jun 02, 2014
2 Suggested Answers
  • 31 Answers
SOURCE: unlock code
if u didn't change the security code all u need to do is press the menu button when the phone is asking for a lock code it will then change to security code, then insert 000000 (6 zeros) n u shud be able to access ur cell
Posted on Nov 26, 2007
My env3 takes about 8 to 10 seconds to load the messages menu, and load anything in that menu (such as starting a new text or opening texts). anything to help it?
Please try resetting the phone but this will reset the phone to factory default.
Steps to Reset Settings
This resets the phone to factory default settings.
  1. Open the flip and press OK [Menu].
  2. Press 9 or Settings & Tools.
  3. Press 6 or Phone Settings.
  4. Press 7 or Security.
  5. Enter lock code. The default lock code is the last 4 digits of your phone number.
  6. Press 5 or Reset Default.
  7. Press OK after reading the warning message.
  8. Press OK to select Revert. A confirmation message is displayed briefly before the phone resets itself.
http://www.resetcellphone.com/solution/LG/vx9200-env3
Feb 22, 2011 | LG enV3 VX9200 Cell Phone
Hello! how can i get a code to open LG cyon.i m from nepal.i had made one way by searching codes from net.but i cant do phone so what can i do??
1-Press 277634#*# phone will enter Service Menu
2-Select GCF Setting
3-Select GCF On
4-Phone reboot and unlocked working with any sim
Note:This Solution working with only old firmware version
Phone lock,user code
- Press 277634#*# phone will enter Service Menu
- Select Factory reset
- Phone reset and reboot
- Phone unlocked (All phone defaul setting).
Unlock LG KH1800
- Press menu - 0 (hold) enter code: 147359
- Phone enter Service menu
- Select GCF Test - Select Rel.99 or Rel.15 phone reboot and unlocked
Sep 16, 2010 | LG Cyon
Hi, my name is Michael as I UPGRADED my cellphone contract in 2008, I set aside my old handset which is HUAWE U120, now I want to give it to my son but he cannot use it as I forgot the password. How can I...
Unlock procedure:
1. Connect cable to phone. Also insert locked SIM card ( not Vodafone card )
2. Switch on phone. When keyboard light comes on, press "Reset Unlock Code" button. Phone will freezed. After few second phone start work again and show locked message.
3. Press left button under screen on phone and enter 16 zeros (0000000000000000), then press OK.
4. If code resetted ok, phone show correct code and ask for reboot. Reboot phone.
5. After reboot phone will be unlocked.
IMPORTANT: you must use JTAG socket in box and your box must be updated to latest version - otherwise you will get error:
hope this was helpful
Nov 15, 2009 | Cell Phones
Tv is lock with smartlock
The Factory code number is 0 0 0 0 If the code has been changed, You can select to reset it using the Setup Code either under the channel blocking or setup code section.
Once there, Press 0 7 1 1
You will be given a message "INCORRECT ACCESS CODE" Press 0 7 1 1 on the remote again
Next, "enter your new access code" shows on screen.
Now you can enter a new 4 digit code. (write it down somewhere)
Feb 15, 2009 | Televison & Video
How to unlock phillips tv
Try this ..
Jan 31, 2009 | Televison & Video
I want to codes
LG SECRET CODES:
LG all models test mode: Type 2945#*# on the main screen.
2945*#01*# Secret menu for LG
IMEI (ALL): *#06#
IMEI and SW (LG 510): *#07#
Software version (LG B1200): *8375#
Recount cheksum (LG B1200): *6861#
Factory test (B1200): #PWR 668
Simlock menu (LG B1200): 1945#*5101#
Simlock menu (LG 510W, 5200): 2945#*5101#
Simlock menu (LG 7020, 7010): 2945#*70001#
Simlock menu (LG 500, 600): 2947#*
LG-U81XX SPECIAL CODES
Code to read phone version :
- Phone without SIM
- Enter 277634#*# or 47328545454#
- Select 'SW Ver.info'
Code to reset phone :
- Phone without SIM
- Select 'Factory Reset'
Code to enter UNLOCK MENU :
- Phone wit SIM inside
- Enter 2945#*88110#
Test Menu 8330 : 637664#*#
Test Menu 8180 V10a: 49857465454#
Test Menu 8180 V11a: 492662464663#
Test Menu 8130-8138: 47328545454#
Test Menu 8110-8120: 277634#*#
MOTOROLA SECRET CODES
On the main screen type
IMEI number:
*#06#
Code to lock keys. Press together *7
Note: [] (pause) means the * key held in until box appears.
Select phone line - (use this to write things below the provider name):
[] [] [] 0 0 8 [] 1 []
Add phonebook to main menu:
[] [] [] 1 0 5 [] 1 []
Add messages to main menu:
[] [] [] 1 0 7 [] 1 []
Copy SIM memory (phonebook menu):
[] [] [] 1 0 8 [] 1 []
Eng Field options (main menu):
[] [] [] 1 1 3 [] 1 []
Slow (Frequency of search menu):
[] [] [] 1 0 1 [] 1 []
Medium (Frequency of search menu):
[] [] [] 1 0 2 [] 1 []
Fast (Frequency of search menu):
[] [] [] 1 0 3 [] 1 []
Enable EFR:
[] [] [] 1 1 9 [] 1 []
Function :
[] [] [] # # # [] 1 []
Change pin:
[] [] [] 0 0 4 [] 1 []
Unblocking using the "puk" number:
[] [] [] 0 0 5 [] 1 []
There are lots of similar codes exist. If you change the last number to 0 you can deactive that code. The 3 digit number at the middle are from 0 to 999. I put the most interesting codes. (EFR):Enhanced Full Rate Codec.
You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps:
enter menu and press 048263* quickly, then you will enter the secret engineering menu
under "Opcode"
input 10*0*3 for GSM 900
10*0*4 for GSM 1800
10*0*5 for GSM 1900
10*0*6 for dual band GSM 900/1800
10*0*7 for dual band GSM 850/1900
To add extra message space 4 your Motorola C350 C450 C550 or C650, press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.You will receive an extra 50 msgs memory space.Switch phone off and back on.(not tested)
NOKIA SECRET CODES:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that supports WLAN like N80
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
*#7328748263373738# resets security code.
Default security code is 12345
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin#
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.)
Press and hold "0" on the main screen to open wap browser.
Dec 13, 2008 | Nokia 5200 Cellular Phone
I forget the lock code and when i start my phone it ask me to enter code
ok try following steps:reboot your phone when they getting reboot press = green button(answer key) + 3 star key(*) but befor that make sure that your phone data will be lost above procudere may restore factory settings of your phone
Oct 23, 2008 | Nokia 6600
Unlock code
Nov 11, 2007 | Motorola Mobility RAZR V3
Reset password on Samsung SGH-E250
*2767*3855# resets all locks xx hope it helps
Sep 06, 2007 | Lands Phones
Motorola Mobility Droid RAZR HD Logo
41 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
