Question about iLive it202b 32 2 1- soundbar
Chromecast to bytecc hm-cv15 hdmi audio extractor to an iLive IT202B - no audio output
I've plugged in Chromecast into a Bytecc HM-cv15 Audio extractor. Using the RCA output on the HM-CV15 to an ilive IT202B sound bar. Audio is not playing. Video does work. iLive says it has a built in amplifier (25 watts per channel?) Ideas?
2 Suggested Answers
SOURCE: ilive 37
Turn off the sleep mode. For some reasons the geniuses ship it with a sleep setting already on. Hold the sleep button til it shows the time then press the sleep button several times until it displays 00. good luck!
Posted on Nov 25, 2012
Toshiba theater wide HD external speakers not working?
When you convert from HDMI to DVI you only convert the video signal so you wont get any sound. To get the sound you will need a device that extracts the sound from the HDMI signal. These are readily available. However as you need the Chromecast to plug into the DVI converter and the sound extractor, you will also need an HDMI device that converts a single HDMI input the two HDMI outputs, or a sound extracting device that has an HDMI pass through. Ether way this is going to be a bit expensive compared to the original cost of the Chromecast. It might just be cheaper to buy a TV that has an HMDI input.
Jun 21, 2016 | Toshiba Televison & Video
Why isnt my tv sound comming out of soundbar
What did you plug into on television. Make sure it is Audio Out could be wrongly connected to component out or Audio in. Have you plugged in and turned on the AC power pack as this could be another possible cause of problems as the sound bar requires power. You may have a faulty AC power pack or power point.
I looked it up on Ilive's web site
32 Bluetooth Sound BarITB183B Press the power button first before selecting Source.Use the Source button on the control unit to switch between optical , aux inputs, line in. If you plugged it into the AUX in on the back you need to select Aux inputs (indicated by a white light) on the speaker. Do you have the user manual if not it is at http://www.iliveelectronics.com/fileuploader/download/download/?d=0&file=custom/upload/File-1380574738.pdf
Hope this helps as I do not have one myself
Jun 13, 2014 | iLive It202b 32" 2.1-channel Soundbar -...
I need some help hooking up an amp, tv, and xbox 360 together please! I have a Toshiba 46g310u TV and Xbox 360 already hooked up together using an HDMI cable. I just bought a Yamaha R-S300 amplifier,...
Many TVs have to have the optical output enabled in a set-up menu. Do you see red when the connector is disconnected (which doesn't necessarily mean that it is active, just that it is 'ON').
Have you checked the amplifier to insure that the input is working by connecting something else directly up to it? Can you test the TOSLINK converter by plugging the output into something else to determine where the problem lies. I still suspect it is in the menus of the TV.
Sep 10, 2013 | Toshiba 46G310U LCD TV
How do I connect my ipod to my hm-381md stereo please?
Any audio device that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
Jun 24, 2011 | Kenwood HM-381MD Shelf System
NECESITO EL MANUAL DE Placa base 945GCT-HM PARA CONECTAR LOS CABLES DE PW ETC DE ESTA PLACA
Apr 25, 2011 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
945GCT - HM motherboard, SPDIF out?
Hi, Before doing anything please refer the motherboard manual, and as per my knowledge you need not solder any pin on the board, if you do so may be something else might not work. I better suggest you to check the Manual before doing anything.
Regards
Feb 22, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Capture HM-DH5U Video into CS4 Premiere Pro
Personaly I would use either windows movie maker, nero, or the applicatiom that came with the camera just to get it to the PC.
From there It would be easier to edit etc.
Aug 14, 2009 | JVC HM-DH5U 35-Hours Video Recorder
Conection to my computer
I burn CD's on my laptop connected to a HM-33 through the earphone out plug. You have to change the computer's system input sound preference from "system" to "Audio in". Stereo sound quality is excellent.
Sep 04, 2008 | Kenwood HM-333-S Shelf System
BYTECC BT-300
hi dear
Make sure you plug in the power for the drive first, let it boot up for a second, THEN attach the adapter and the USB
oke
Mar 22, 2008 | Computers & Internet
iLive it202b 32 2 1- soundbar Logo
101 people viewed this question
Top iLive Audio Players & Recorders Experts
cwradio73
Andrew Taylor
Andrew Taylor
Are you an iLive Audio Player and Recorder Expert? Answer questions, earn points and help others
