Question about NorStar T7316E Corded Phone
System startup time clear message
Problem started after a powercut
My split ac is showing f8 on digital screen
Need to add some details, what kind of system do you have? Suggest starting by reading the owners manual, either the paper one or one Google shows you on line.
Dec 28, 2013 | Heating & Cooling
Tip
Speed Up Windows XP in 5 Steps
Most of the times we observe that our system seems to gradually slow down. Here below i am listing five basic and easy steps
that can help you speed up your Windows XP computer.
1. Clear the Prefetch Folder :The Prefetch Folder contains files that keep getting stored on your computer whenever you launch any program or application. Deleting these files clears up space on your system that might have caused the slow down. Here is how you need to go about it.
Click Start..click Run..type Prefetch and click ok. The prefetch folder will open up. Press Ctrl and A together. This highlights the entire contents of the folder. Press the Delete key on the keyboard and confirm the deletion. Once done close the prefetch folder window. Now right click on the recycle bin icon on the desktop and right click and select empty recycle
bin and then confirm the deletion.
2. Disable Startup Items: Certain programs get initiated in the background as soon as your system starts causing the system to slow down. These programs are actually not required on startup but because they get initiated it affects the system performance. Here below i am listing the steps to take care of this issue. Please note this step is very effective and
enhances your system startup speed significantly.
Click Start...click Run...type msconfig and click Ok.
The System Configuration utility window will open.
Click on the Startup tab on the top right. Click on the disable all button. Once done, in the list above, you will see many options with checkboxes. Please check any option that indicates your antivirus program software and internet service provider.
Click Apply and Ok. Please restart the system once.Once the system reboots you will get a message coming up saying "You have used the system configuration utility...." Please check the option below that says" Do not show this message again" and click OK.
3.Clear the Temporary Files Folder: Certain temporary files get created as a cache of our activity on the system. Clearing these files from time to time also improves the system speed. Below are the steps for the same.
Click Start..Click Run...Type %temp% and click Ok.The temporary files folder opens.Press Ctrl and A together. This highlights the entire contents of the folder. Press the Delete key on the keyboard and confirm the deletion. Once done close the folder window. Now right click on the recycle bin icon on the desktop and right click and select empty recycle bin
4.Clear Cookies and Temp Internet Files: As you browse the internet the images of the pages you view get saved on the system occupying space on the system. Clearing these files increases your system performance while on the internet.
Open Internet Explorer. Click on the Tools menu on top right. Click Internet Options. Click on delete button to delete cookies, files and browsing history. Click Apply and Click Ok.
5.Scan our system for infection: Your system might run slow in case its infected with virus, spyware, malware, adware, trojans etc. Here below i am listing a tool that you can download and run on the system Its free of cost and is very effective. It scans your system and cleans up any infection. Click on the below link to download the tool. The link that opens up also has a tutorial on running the tool in case you face any difficulty.
Download Combofix Tool
With the above 5 steps, your system speed should surely get enhanced.
If you find the information shared by me in the above tip useful, please do rate the tip.
All the Best!!!
on Dec 09, 2010 | Computers & Internet
System startup
Below the event message it should be also display"time" and "clear"on the screen. There are two corisponding soft keys below the two words. Press the clear key to erase the message from your display.
Feb 19, 2012 | NorStar T7316E Corded Phone
When i start my computer i get two error loading messages: c:\windows\kep2at.dll and c;\windowsewaxoxiw.dll and they both say "the specidied module could not be found" i looked in regedit and didn't find...
go to start, run, type in msconfig and press enter. msconfig is the command to run an application to control startup items. Go to the startup tab at the top of this window, and uncheck any unnecessary items so they won't startup at reboot. If you are unsure what a process is, just google the name and it should give you details as to what application it belongs to, and you can make judgement if you need it or not. I would uncheck anything I wouldn't recognize.
Sep 04, 2010 | Computers & Internet
PoweReadACValue error
Probably it is cause due to power management system corruption
Try following steps
Perform a Clean Boot
If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
Method :Perform a Clean Boot
Step 1: Start the System Configuration Utility
1. Click Start, click Run, type msconfig, and then click OK.
2. The System Configuration Utility dialog box is displayed.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, and then click OK.
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. If you are prompted, log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
Note: Start Windows in Normal State
Steps to configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
1. Click Start, and then click Run.
2. Type msconfig, and then click OK.
3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
4. When you are prompted, click Restart to restart the computer.
Sep 04, 2010 | HP Pavilion dv7-1130us laptop
Cannot find gphone.exe
gphone.exe is a virus that affect google talk or yahoo messenger, to remove it you can download a copy of Eset antivirus.
You could have the same error after the antivirus removal but now the system is clear and you have to delete gphone.exe from your startup files list: start -> run -> msconfig -> go to startup and uncheck gphone. This should help you.
Jul 18, 2009 | Microsoft Computers & Internet
Cursor lockup
This just because that there are too many services running in the background of the Operating system
All you need to do is to manually disable maximum of them and disable all the startup Items
Here is how you can do that the easy way
Manual steps to perform a clean boot in Windows XP
The System Configuration Utility dialog box appears.
6. (VERY IMPORTANT DON'T MISS THIS) Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then Click on the startup tab and click on Disable All Button and then click OK..
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The System Configuration Utility is currently in Diagnostic or Selective Startup mode, causing this message to be displayed and the utility to run every time Windows starts.
Choose the Normal Startup mode on the General tab to start Windows normally and undo the changes you made using the System Configuration Utility.
Step 4: Optional step to disable features
This step temporarily disables Microsoft features such as Plug and Play, networking, event logging, and error reporting. Also, this step permanently removes the restore points from the computer. The System Restore feature uses restore points to restore your computer to an earlier state. If you remove the restore points, you can no longer restore Windows to an earlier state.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
2. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
Aug 14, 2008 | Microsoft Windows XP Home Edition
Shutdown
Aug 14, 2008 | Dell Dimension 8200 PC Desktop
Strange problem about WBR 1310
7. Click Disable All, then got to Startup click Disable All and then Apply and then click OK..
Aug 11, 2008 | D-Link 802.11g Wireless Router WBR-1310...
I have a Lexmark x5470 and evertime i start my computer now i get an error message which says im32fax.dil not found. How do i stop this from occuring.
Please follow the instructions below.
Click Start menu, click Run, type msconfig, and then click OK.
2. Click to clear the Load Startup Items check box.
3 When you are prompted, click Restart to restart the computer.
After restarting system.
Note: Doing this startup programmes will not run in the background however you can start the programmes later from start all programmes.
Please feel free to get back to me If you need any further assistance.
Regards,
Mohammed.
Aug 05, 2008 | Computers & Internet
NorStar T7316E Corded Phone Logo
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
