Stand By Light Flashes 5 Times - No Video Or Sound
Video and Sound gave out during usage. Unplugged TV and tried different outlet but same problem. Power light comes on but NO Video or Sound, when I turn it off Stand by light Blinks 5 Times and then goes out. I removed the back looking at power supply BN44-00440B but found no bulging capacitors. I have the option of replacing the power supply but I don't want to spend the money if that is not the problem. My Question Is: What does error code of the standby light flashing 5 times during shutdown mean?
  • 1 more comment
  • Dennis Watson
    Dennis Watson Nov 27, 2013
    The above T.V. I am having problems with is: Samsung 40" 1080p 60Hz LCD HDTV LN40D550K1F
  • Dennis Watson
    Dennis Watson Dec 10, 2013
    Problem Solved: It was the Main Board. Got a replacement on eBay for $29. T.V. Works perfectly now.
  • duxsmer
    duxsmer Feb 22, 2014
    I replaced the main board as well. It worked for me too!
    Top Expert:
  • Televison & ... Master
  • 75,452 Answers
IKR Error at power on 05. This is the fault. it is related with its main digital processor board itself. For more information go to http://electronicshelponline.blogspot.com/
Posted on Nov 27, 2013
Testimonial: "Thank You, guess I won't rush out and buy the power board. I ordered a service manual for my LN40D550K1F so I can specifically run down error codes for this model. I'll replace the Main board if needed, I just didn't want to buy unneeded hardware."
  • 1 more comment
  • The Knight
    The Knight Nov 27, 2013
    IKR Error at power on 05. This fault is related with its main board. it will be best to contact any service technician. This is not a user repairable fault.
  • Dennis Watson
    Thank you for the response, just one more question. Are error code blink sequence the same for all LCD T.V(s). I'm just wanting to make sure this relates to my Samsung LN40D550K1F
  • The Knight
    The Knight Nov 28, 2013
    Of-course not Dennis. Blinking codes will differ to brand to brand & model to model. This detail is there by the site I,ve linked in. It has blinking codes details to many brand TVs, including Samsung. Surf the site. Hopes it will help you.
4 Suggested Answers
davebies
  • 43 Answers
SOURCE: Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Posted on Jan 06, 2008
mistersony
  • 320 Answers
SOURCE: standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
Posted on Oct 20, 2008
SOURCE: my emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Posted on Dec 20, 2010
Sony fd trinitron colour television kv 29ls60e
The power supply probably is failing.
Jan 10, 2014 | Televison & Video
Sony FD Trinitron WEGA
Here's my suggestion , unhook all the external components to the TV and leave the TV unplugged for more than a few minutes (a day/overnight). The next day plug the TV into the wall outlet (not the powerstrip) without anything hooked up to it, and turn it on. See if it comes on. Sometimes unplugging for a few minutes/hours is not long enough for it to reset itself.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No Video Or Sound - Stand By Light Flashes 5 Times
If the tv was made before December 2008, there is a capacitor settlement from a class action lawsuit by Samsung. Supposedly (at no charge) they will send a repairman to replace the capacitors.
Nov 27, 2013 | Televison & Video
I have a sony tv model kv-27v42 i have sound but no pictture and stand by light blinks what is the problem
How many times do this standby light blinks at a time of switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty circuit section inside it. Count it. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 24, 2013 | Televison & Video
My Samsung LE32N7 does not come on. The blue light under the screen constantly flashes without the tv coming on.
Hi, maybe the TV controller board is blocked, you can reset it, by disconnecting power cable from outlet for about 5 minutes, if that doesn't work, possibly and internal board or component must be repaired of replaced, in such case it's better to contact an authorized Samsung service center or technician to check your TV.
Nov 07, 2017 | Televison & Video
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony KP-51WS520 Stand by flashes 5 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
This means that there is something wrong with the video.
When you get this error, several IC and components concerning the video signal must be tested and eventually replaced.
Mar 13, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony kv32fs16 problem
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Nov 02, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Televison & Video Logo
201 people viewed this question
Top Televison & Video Experts
