Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door jumps when opened.
I have a Craftsman garage door opener and when opening the door it jumps about an inch before going up. Any ideas????
  • Brian B May 11, 2010
    check the emergency release might not be totaly seated
    President:
  • 3,197 Answers
Release the opener from the door and operate the door manually. You can also operate the opener and this should give you a good idea where the problem lies. I think you have a door problem.
Posted on May 08, 2009
My Craftsman garage door opener opens the door fine, then the door rolls back about 6 inches. I little history - this started after I replaced the drive cogs in the unit.
This is an unusual complaint and I have an idea your door is opening just a little too far. On the side of the motor unit you will find the 'up limit' control. Turn this a complete turn in the opposite direction of the arrow printed on the cover. See how this works and you may have to tweak it a bit to get it right.
Oct 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
The craftsman garage door opener only opens door 6 inches to about 30 inches and won't go any higher model 139 .53930D
Check your door springs. One may be broken. Also check the drive gear. It is a white nylon gear just in front of the motor.
Mar 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door does not open all the way stops @12 inches
You most likely have a broken door spring. Release the door from the opener and try lifting it by hand. Look above the door for the springs.
Mar 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman garage door opener and just replaced the plastic gears. I followed the step by step directions but the door is now only opening 2-3 inches, reversing and then going back down. any ideas?
I managed to troubleshoot this myself and got my door working. The problem was that the black rpm wheel was not far enough down on the gear shaft. By unscrewing the screws on the final piece of the assembly on the shaft and then pushing it all more firmly toward the motor and rescrewing in place, I made it so the door operates beautifully.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't open
You probably have a broken spring on your door
Nov 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Door opens only 6 inches and stuck
I would try jumping a wire across the white & red terminal to see if your safety sensors are working Properly! If your door opens you have a loose connection or faulty sensors.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 24, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,177 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
