Kyocera drum one side horizontal line problem
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
If it repats itself ( more than one line, spaced out ) it's the drum
Posted on Dec 11, 2013
C5350dn
If the whole page is covered by these black lines, then you have to replace the developer unit K..
If there is (for example) one black line that is been repeated in page three times (vertical) then you have to replace the drum unit. The drum units are all the same, so you can test by change two drums between them.
Jul 15, 2014 | Kyocera Office Equipment & Supplies
Wahy
fuser or drum if its only on copies clean slit glass
May 21, 2014 | Kyocera TASKalfa 180 Copier
My printer is printing black horizontal lines down the right side of the paper - what is wrong?
Needs Drum If you pull the drum unit out you will see on the drum different shades of color lighter is wear the lines come from. Buy a rebuilt drum much cheaper and they work, may have to reset the drum count if the change drum lite on...
May 02, 2014 | Brother MFC-8460N All-In-One Printer
Vertical black line at the bottom of my printout
open copier front cover and remove developer unit, after that remove the drum unit ,pullon green handles on each side, the drum unit has a green cleaning lever on it ,make sure it is all the way to right side,
arrows on lever and frame of drum should meet,if this is out of position a line will appear.
Mar 20, 2014 | Kyocera FS-1135MFP
Our Kyocera FS2000D has two small parallel lines down the left hand side of the paper. It just started doing this. Is this a symptom that the machine needs a new drum? How hard is it to replace the drum?...
drums are very easily to replace.. you don't even need a screw driver....before you order a drum...check the charge rollers..
this roller is part of the drum and you can order it seperate...
ok.. to remove the drum..first take out the process unit..this is the entire unit that the toner sits into( don't unlock the toner)..once the process unit is removed..open the left hand cover and remove the waste toner bottle.. the drum sits right above the bottle..simply push on the grey square tab.. to release the drum out of the left side of the printer (easy right!!) check the drum and chare roller..also on the process unit there is a green tab you can slide back and forth to clean the grid
Jan 07, 2010 | Kyocera FS-2000D Laser Printer
Change drum kyocera fs-3900
open printer front cover and remove drum unite ,two side screw open two side spring **** two side open drum
if you are not possible it then buy a new one unite in your service authorized delar
Aug 27, 2009 | Kyocera FS-3900DN Laser Printer
Problem for print by photo copier
sounds like the charge grid is not set properly in the drum unit..did you et up the drum unit properly and run the new dev and drum set up..if youy are getting black the charge is not working correct as the charge of the drum help to keep the toner from adhering to the drum surface when copying .. I would take the drum chrge unit out again and check it is set in the right way when you put it back on also check the contacts arent put out of line.
Aug 05, 2009 | Kyocera Copystar CS-1820 Black and White...
Dell Print Quality Problems: Horizontal lines On One Side
Try running a cleaning sheet through the printer. Remove the drum and check you waste toner (if that is built-in to your drum then skip this). If that gets full, then some of the bad toner can spill out creating lines/smuges. I would also use compressed air to blow out the inside of the printer where the toner/drum goes. That will help remove anything that is left behind after a replacement.
Also, check the settings in the print server for anything that will clean the printer/correct horizontal lines.
Mar 16, 2009 | Dell 3010cn Laser Printer
Black line on prints from Kyocera fs2000d
remove the drum by opening the LHS of the printer & removing the toner waste bottle, then depress the grey button on the drum assembly & firmly pull the assembly out. Best done in a darkish room as the drum is light sensitive.
The black line couldn't be fixed as it is caused by a scratch less that 2mm long on the drum. Ether a new drun at £299 or a new printer ar £245..
Dec 03, 2008 | Kyocera FS-2000D Laser Printer
I have a mita dc1255 copier. When coping the copies come out dark with horizontal lines. Any idea what the problem could be.
One, it might be the optics in the machine are dirty, two the cleaning blade for the drum may need replacing.
Hope that helps...
Lbcoaster
Jul 02, 2008 | Kyocera Office Equipment & Supplies
43 people viewed this question
jasbo
jasbo
