Question about Sun Fire V40z Server
Cannot Display From Monitor
Hi. I'm a computer engineering student and I have some troubles with our SunFire V40z Server. Problem is I plug monitor via OnBoard VGA or via an external PCI card(from DVI port) and boot the platform there is no signal. I tried that if monitor or cable is corrupted but monitor and the cable is okay. I have no idea what to do about this problem please help.
  • 22 Answers
How long have you waited for it to boot? I know some servers take forever before they send a signal to the monitor. However, if you're get the monitor test screen or "no signal" screen, this usually is a sign that the monitor is not getting any signal from the server, indicating a bad cable or loose connection or the like (though not always if it's still booting). Have you looked in the server cabinet to make sure nothing is broke on the on-board connection or something? Is the DVI port you mentioned on the external PCI card? What does it plug into? I'm guessing you've checked for any installed video cards. Is there another port on the front or anything under a panel?
Posted on Jan 02, 2014
Dose the server beep sound no display
If you only hear beep sounds but no display on your monitor it might mean a los of different issues.
Chech if your monitor works, connect it to another computer. If it woeks count how many beep sounds do you hear when you turn on your computer., go to google and input "meaning of beep sounds" Depending on numbre of beeps, you can get a fast diagnosis. Probably you have ahardware issue. If it is not tne monitor, it is your server and I suggest you should take it to a reapir shop
Sep 21, 2014 | Computers & Internet
Poweredge 6600 not showing display
If you have multiple video connections (onboard from motherboard, usually vertical or stand alone video card, usually horizontal) that you plug into the stand alone card, as the onboard is normally disabled when the expansion is installed. Verify the cable and monitor both work and that the monitor is on the correct input. Finally try another video card, if you have one available. Even if the drivers are not correct, etc, you should still see a boot screen.
Nov 13, 2013 | Dell PowerEdge 6600...
My monotor don't switch on but my power supply seems working gooid, how can i know if my monotor is over ? tne turn on buttom don't send thegreen light please tell me abouit that my model is fujitsu...
You can test for a display by plugging another monitor or borrowed monitor. You will know exactly where the trouble if you only have the other monitor which is really working and test it to your computer. If there is a display that means your monitor is over. But if there is no display that means you have to focus on your video card or memory. You must have the small paint brush and hard eraser because you are going to clean your video card and memory pin. First you must discharge electro static by holding the computer casing chassis for about 2 minutes because computer components are very sensitive to electro static which is present in our hands or body. After discharging unscrew the video and gently slide the eraser to the pin of the video card and same with the memory then use the paint brush to remove the dirt on your video card and memory pin. Then plug again the video card and memory test for a display. If there is a display test the two monitors for making sure that the monitor is still working or need to buy a new monitor. Have a nice day.
Feb 26, 2011 | Fujitsu Siemens Premium Line 3816 FA-M 15"...
Sunfire v480 when powered on not showing anything on monoitor server was working last 4 years without any problem
Dear,
If your server came up without key board and monitor on last boot, you wont get anything by connecting monitor. you have reboot the server by making user, input device=keyboard and output device=monitor you can see this value by using eeprom command from os you set this value eeprom input-device=keyboard eeprom output-device=monitor
Jul 13, 2009 | SunFire V480 UltraSPARC III...
Server starts but no display in the monitor
how i get the server end rank for him the game is cunter strke 1.6
Apr 05, 2009 | HP Computers & Internet
X2 gen 17" lcd monitor, no display
This indicates either a problem with the monitor cable(ie shorted) or the display adapter. Try plugging the monitor into a different computer and if it works you will need to install a new display adapter in your computer. If it doewn't work on the new one either you can try a different monitor cable if yours isn't permanently connected. Hope this helps
Mar 29, 2009 | X2 MG17R 17" LCD Monitor
No video at all on Compaq ProLiant 1850R
Do the server has an onboard Video disable the video in the BIOS setup insert another PCI Video card and check for the display , IF the PCI display is up then there could be a problem with Onboard card.
Nov 27, 2008 | HP Compaq ProLiant 1850R Server
LCD monitor trouble
Hi
It could be an issue with the monitor or the software or the drivers for the graphics card.
Pls uninstall the display drivers, restart the drivers and reinstall the display drivers and then restart the computer once again and check the display.
Also pls install the monitor software that came with the monitor.
Also you may try downloading the original display drivers and any driver updates from the graphics card manufacturer website and check the display.
If the above steps doesnt work, then the monitor has to be serviced or replaced.
Feb 26, 2008 | Computers & Internet
Booting probleam
Hi FAYU,
First make sure that the monitor is plugged into power and properly connected to the tower. If it is, does it sound like the server is actually powering up even though you are not getting display? If the server is powering up, then I would suspect the monitor to possibly be faulty. You can troubleshoot this by attaching another monitor.
If the server is not powering up, then you may have a faulty power supply or faulty processor.
--RoadHawk
Nov 20, 2007 | HP Compaq ProLiant ML110 G4 Server
Sun Fire V40z  Server Logo
77 people viewed this question
Top Sun Fire Computers & Internet Experts
David Payne
David Payne
Are you a Sun Fire Computer and Internet Expert? Answer questions, earn points and help others
