Question about EPoX EP-4PDA3I-3 Motherboard
Bios update download - EPoX EP-4PDA3I-3 Motherboard
Motherboard BIOS update
Support For A55M P33 MSI USA Motherboard The world leader in motherboard... Use this page to download the BIOS update. At the bottom of the list is instructions on how to flash the BIOS
Sep 02, 2016 | MSI Computers & Internet
How do i update bios?
Hello download the bios version here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5AD2-E%20Premium&p=1&s=22
By selecting your windows system.
Open bios folder, and click global for download, for the newest version.
Download also ASUS Update, In utility, and please unzip both files.
Install first asus update, and run the program, select update bios from file, and select the bios version you have downloaded, the rom or bin file, and click next.
Now the bios update process will begin.
DO NOT turn off the power, when the process is running, and you have to setup the whole bios, when the job is done.
Follow the instuctions on screen, when you have rebooted.
Good luck
Mar 02, 2013 | ASUS P5AD2-E Premium - Mainboard...
How do i upgrade bios
Open bios folder, and click global for download, for the newest bios version.
Good luck
Mar 02, 2013 | ASUS P5AD2-E Premium Motherboard
I NEED BIOS OF ASUS P5GC-MX/1333
http://support.asus.com/Download.aspx?SLanguage=en&m=P5GC-MX%2f1333&p=1&s=22
Download also ASUS Update V7.15.04, In utilitys, and please unzip both files.
Install first asus update, select update bios from file, and select the bios version you have downloaded, the rom file, and click next.
Good luck
Feb 21, 2013 | ASUS P5GC-MX/1333 Motherboard
What are the instructions for flashing BIOS?
Hello use auto detect here to find the right mainboard:
http://support.asus.com/download/options.aspx?SLanguage=en
Download asus update, this is the easyest program to upgrade the bios, while windows is running.
Install first asus update:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
When the mainboard is found, select download, and select your windows system.
Open the bios folder, and download the latest bios version.
Unzip the bios file.
Run asus update, and select update bios from file, and select the bios file, in the folder you just have downloaded ( the bin file )
Be very carefull when you upgrade the bios, because a power loss will damage the mainboard, while the upgrade process is running.
You also have to setup the bios settings, when the job is done.
You have to select F1 or F2 to enter the settings.
If any doubt download the manual.
Good luck
Feb 07, 2013 | ASUS Computers & Internet
Cerna obrazovka nemam disketu bios
Hi, you can download the bios here:
http://www.asus.com/Motherboards/AMD_Socket_A/A7V600X/#download
Download the asus update utility from here:
The asus Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows environment.
The Asus Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
Aug 25, 2011 | ASUS A7V600-X (90M7A820G0EAYZ) Motherboard
How to update bios
To find the current BIOS version, follow the steps below:
  1. Restart the computer and enter the BIOS screen by pressing the F1 or F10 key at the first screen.
  2. Write down the BIOS revision number from the Main page. You will use this number to see if HP has a later version available.
    1. Go to the HP Software download page
    2. If you are presented with a page to enter your model number, type in your model number. For example, Pavilion p6230f or TouchSmart 600-1050uk.
    3. Select the version of Windows the computer is using.
    4. Click the BIOS link.
      • If a BIOS update is not listed, HP does not have a BIOS update posted for your computer at this time.
      • If there are several BIOS updates available for different motherboard names, you need to find out what motherboard is installed in your computer. To do this, turn off the power to the computer, remove the side panel, and read the name printed on the motherboard. The name of the motherboard should match or be similar to the name of the download link.
      • If a BIOS update is listed, continue to the next step to download and install the BIOS update.
        Click the download link. The instructions for downloading and installing BIOS updates vary. For most computers with Windows XP, download the file, open it and follow the on-screen instructions. For many computers before Windows XP, save the downloaded file to the hard drive, insert a formatted disk, open the downloaded file to copy the BIOS files to the disk, and then restart the computer with the disk still in the drive. The instructions on the download page may be different so carefully read and follow the instructions on the download page and in the installation setup screens. If a 251 or CMOS Checksum error occurs after installing the BIOS update, perform the following steps:
        2. Press the F5 key to load the default BIOS configuration.
        3. Select YES by using the arrow keys, and then press Enter .
        4. Press the F10 key to save the settings and exit.
        5. Select YES by using the arrow keys, and then press Enter .
        When the BIOS update is complete, the new BIOS revision number is updated on the Main BIOS screen.
Feb 28, 2011 | Compaq Presario 700 470024-192 Notebook
Vertical lines and discoloration on my sony vaio vgn a140
It is required to get the BIOS and the Video Driver Updated in the Computer to resolve the issue.
The BIOS Update and Video Driver Update are available at Sony Support Site for download.
You can view and download the BIOS Update from this link
Before installing the BIOS update, be sure the computer is running from AC power. If the installation of the BIOS is interrupted by power loss, the computer may not operate correctly or at all.
During the installation of this update:
  • Do not turn the computer off.
  • Do not allow the computer to enter Standby or Hibernation states.
  • Do not start other programs.
  • Do not connect any peripherals.
Download the AIBSYS-00772903-US.EXE file to a temporary or download directory.
Go to the directory where the file was downloaded and double-click the "AIBSYS-00772903-US.EXE" file to begin the installation.
At the "BIOS Update Utility for Microsoft® Windows® XP" box, click "Next".
At the "License Agreement" dialog, read the agreement, then, if you agree, click "I Agree" to continue with the installation.
NOTE:
Please wait while the utility extracts the necessary files for the update.
At the "VAIO BIOS Update Tool 1.0.01.10181" box, click "Update".
At the "WBFLASH" box, click "OK".
NOTE:
Please wait while the utility updates the BIOS.
At the "WBFLASH" BIOS Update successfully completed box , click "OK" to shutdown the computer.
After the computer shuts down, wait for a few seconds, and then power on the computer.
After the computer restarts, the installation of the BIOS Update is complete.
After installing the BIOS Update, it is required to Update the Video Driver to resolve the issue.
You can view and download the Video Driver Update from this link
Download the ATDVID-00610812-US.EXE file to a temporary or download directory (please note this directory for reference).
Go to the directory where the file was downloaded and double-click the ATDVID-00610812-US.EXE file to begin the installation.
Then, please follow the onscreen instructions to complete the installation.
After installing the Video Driver Update, please restart the Computer for the settings to take the effect.
Performing the above steps should fix the issue.
If the issue is not resolved, please check if the Vertical lines and discoloration are visible while accessing the BIOS Setup Utility.
To access the BIOS Window, please restart the Computer, press and hold the F2 Key to access the BIOS Setup Utility.
If the lines and discoloration are available on the BIOS Setup Utility window, the issue may be related to the LCD Screen of the Computer and you will need to get the Computer serviced to fix it.
In that case, you can contact Sony Service Center get the Computer serviced and resolve the issue.
Apr 14, 2010 | Sony VAIO VGN-A140 PC Notebook
Desktop hp Product Number P6402A
Step 1: Find the current BIOS version number
  1. Turn ON your pc. When the first screen appears, press F1 to enter the BIOS Setup. On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
  2. The BIOS revision number is listed on the Main menu. Write down the current BIOS version that is listed.
  3. To exit the BIOS setup screen, press F10 , select Yes , and then press the Enter key.
Step 2: Check the Drivers and Downloads page for BIOS or ROM updates
  1. Go to http://h10025.www1.hp.com/ewfrf/wc/softwareRedirector?lc=en&dlc=en&cc=us&product=67009&docname=c00007682 enter the model of the PC (for example, Presario 5002US or Pavilion a518d), and click the download button.
  2. Click the link for the PC Operating System (like Windows XP).
  3. Try to find the BIOS update listed under the heading, BIOS , BIOS- System , or RomPaq.
    NOTE: The term "Rompaq" refers to BIOS updates for Compaq Presario PCs prior to 2002.
  • If a BIOS update is not listed, HP does not have a BIOS update posted for your PC at this time.
  • If there are several BIOS updates available for different motherboard names, you need to find out what motherboard is installed in your PC. This can be done by turning off the power to the PC, removing the side panel, and reading the name that is printed on the motherboard. The name of your motherboard should match or be similar to the name of the download link.
  • If a BIOS update is listed, proceed to the next step to download and install the BIOS update.
Step 3: Download and install the BIOS update
  1. Click the download link. The instructions for downloading and installing BIOS updates vary.
  • For most PCs with Windows XP, download the file, open it and follow the on-screen instructions.
  • For many PCs before Windows XP, save the downloaded file to the hard drive, insert a formatted disk, open the downloaded file to copy the BIOS files to the disk, and then restart the computer with the disk still in the drive.
  • The instructions on the download page may be different so carefully read and follow the instructions on the download page and in the installation setup screens.
  1. If a 251 or CMOS Checksum error occurs after installing the BIOS update, perform the following steps:
  2. Restart the PC and enter the BIOS screen by pressing the F1 or F10 key at the first screen.
  3. Press the F5 key to load the default BIOS configuration.
  4. Select YES by using the arrow keys, and then press Enter .
  5. Press the F10 key to save the settings and exit.
  6. Select YES by using the arrow keys, and then press Enter .
Please rate this solution. Thank you.
Feb 01, 2009 | Computers & Internet
EPoX EP-4PDA3I-3 Motherboard Logo
29 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Alun Cox
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
