Hornby 2000 (r8012) one channel does not work
One of the channels has stopped working. Took case off and tested what I could. There is a flat circular flesh coloured conponent about 8mm diameter which is very hot when compared to the working side. Is it a VARISTOR and could it have failed. If so whado I buy to replace it?
    Top Expert:
  • Televison & ... Master
  • 74,243 Answers
It sounds that it will be best for you to contact any service technician.
For more information go to http://electronicshelponline.blogspot.com/
Posted on Nov 27, 2013
SOURCE: Can't tune in my Samsung DTV channels
WDDW
Posted on Nov 17, 2008
  • 718 Answers
SOURCE: Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Posted on Mar 16, 2009
SOURCE: channel button on tv and remote control dosent work
Just press menu go to auto search
problem fixed and you'll have more digital channels as well
Posted on Mar 29, 2009
milkburp
  • 416 Answers
SOURCE: no sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Posted on Mar 26, 2010
SOURCE: Freeview channels have stopped working on Panasonic TX-32LZD80
how to retune freeview channels on tx-32lzd81
Posted on Apr 10, 2010
We have a 4 year old Visio HD TV. Recently we had time when both the HD channels and going up and down using the channel surf buttons did not work. The low Def channels would work and entering the channel...
I don't believe that it is cost effective. BUT, if you have Comcast, you will now need a cable box to watch most channels now. I believe they stop at about channel 12 without the box. It's their way to stop cable thieves, but it's an inconvenience for the rest of us.
If this isn't the case, you might want to try to contact Vizio tech support www.vizio.com. or try to reset the TV - unplug the TV, press and hold the power button for 30 seconds, repeat. Plug it back in and see if it helped.
Apr 22, 2011 | Televison & Video
Hello. I have bought a Hornby HM2000 controller and slave but it came with no instructions. Search the web to find a download with no success. Have you any ideas. Basic operation is straightforward but...
Hi Roger and welcome to FixYa, I am Kelly.
I went through the same searching drill you just did and came up with the same negative results.
The product code is R8012 and the model number is HM2000. (Forum searches also)
You are going to have to contact them here:
http://www.hornby.com/building-a-model-railway/hvr-support-form.html
or here: http://www.hornby.com/contact-us
Make sure to include the model number and the product code on the form.
Thanks for choosing FixYa,
Kelly
Mar 05, 2011 | Toys
I have a KDL-32v3100 Sony LCD. only analogue channels are found. no digital channels are found. aerial is OK
You don't say how clear the analogue picture is. If it's snowy, or ghosting (double images etc) your signal may be too weak to produce an acceptable result for digital signals to work at all.
If this is not the case you may have a faulty digital tuner. This assuming that the set was working and then stopped.
Jan 19, 2011 | Televison & Video
I have a Grundig TV P37-080GB or G.CG61-02GBM bought in UK. Using Auto Tuning I can find local TV channels but the audio to each of these channels does not work. I get a hissing sound as gets when not...
Hi.
If you are using the TV in UK, and you are using the internal digital tuner (aerial cable to TV), then the TV may be defective (faulty tuner or audio circuit). In that case call Grundig at the number listed on manual.
If TV is using an external digi box (eg. freeview), then check connection from box to TV, test using a different connection cable. Test using a DVD, if TV works on DVD replace the digi box.
If you are trying to use the TV outside UK, and you are using the internal digital tuner, then there may be a problem with signal. In that case purchase a tuner box and connect it to the TV.
Jul 14, 2010 | Televison & Video
Cannot get tv to scan digital stations. I have a
test test 18:30
test test test 18:31s rthsr thsty 3456234
Jun 27, 2009 | Televison & Video
I brought a hm 2000 r8012 with out a manual thanks peter5496 hornby trains
Hello peterallen,
Check this out may be that help you.
Thank you for using FixYa.
Apr 08, 2009 | Toys
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
Channels keep changing
Make sure there is no other remote control working simultaneously or with a key pressed constantly by mistake. In my case i found the air conditioning remote control with one key being pressed by my furniture next to my bed, it was causing that erratic behavior. As soon i realized, i stopped that remote control and problem solved. I hope this works.
Nov 11, 2007 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
