Question about Cub Cadet Street Sign- tractor lawn riding mower parts
When going to move forward or turn it goes slow or not at all
When I try to go forward and push the bars to move, it either does not go or it moves very slowly. Almost like a wire is not connected.The last time I used it, I got stuck in the mud and I went back and forth a lot. After I got out, I finished mowing without a problem. Then when I tried to use it again this started. Any advice?
  • leannesimmon May 13, 2009
    We also got stuck in the mud, then it started the next time we mowed we took it today and they changed the drive belt because it was burnt. Came home and finished mowing but still do not have the speed back. Don't have any clues what it could be either, guess I will have to take it back. Wonder what being stuck in the mud has to do with it.
  • Anonymous May 25, 2009
    My Zero Turn will not move at all.. It cranks and runs fine.. The drive belt is intact, some wear but otherwise ok. Will replace as soon as I figure out why it won't move at all. Is this a common problem on these mowers? Is it a relay?
5 Suggested Answers
  • 11 Answers
SOURCE: Honda HTR3009 riding mower runs great but won't
sounds like your drive belt is slipping.
look under your engine (you may have to raise the cover to engine to do this), see if the belt that is around the pully which is on your engine drive shaft is on correctly or is in need of replacing.
Posted on Jun 24, 2009
SOURCE: cub cadet starts but won't move forward or reverse
What model? I have a 1554, that I just took to the dealer, for repairs, for the same thing. The motor starts, the blades engage and cut, it just stopped moving forward, or reverse. If I remember, I'll get back on here and let you know, unless you already know?
Posted on Apr 22, 2010
SOURCE: will not move
The transmission is shot. A common problem. Mine died after 3 years and 200 hours of use. Estimate to fix was almost $2000. I scapped it and bought a better mower. There was a rtransmission design defect in the RZT series.
Posted on Jun 21, 2010
hunter19_46m
  • 7482 Answers
SOURCE: cub cadet riding mower,
Hi
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel line/s from the carburetor be sure to make a drawing to how the line/s are connected to the carburetor.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 20, 2011
Testimonial: "i do think your solution is the bbest that i could think,, i will do this today , and see you tomorrow."
My JD L130 has little power going foreard and almost none in reverse.
The forward reverse pedal linkage needs adjustment. Remove mower deck pins and slide out of the way. Pull linkage pin out then turn clockwise one full turn .move brake pedal while looking at it .You should see a small brake disc on side of rearend with a nut bolt going through the disc. Pull rod on back of mower that allows you to push mower freely.set parking brake try to move mower by pushing if it moves with break set tighten bolt that goes through brake disc til mower don't move.release parking brake try to move mower should roll easy.if not losen bolt 1/2 turn til it moves easy.reengauge rod on rear of mower to drive it test and be sure to place cable ties on any thing under mower dragging ground .If test works .reinstall mower deck.
May 18, 2014 | John Deere L100 Series
Hercules Helicopter doesn't move forward much
My Hercules is a 3 channel heli,and I will try moving battery forward. On my SYMA s107 I turned the back blade upside down and got a dif style blade. It now goes Forward Great.
Jun 01, 2013 | Toys
The warthog won't move when I press any of the controls. I picked up the warthog and tried to see if it was just bad traction on the tile, but the wheels wouldn't move. I tried turning it off for a minute...
i think these warthogs mite be **** because i got one for christmas and it wont go forward only in reverse it steers fine but i think we are just the lucky ones who dont get a working one so my advise is to bye another one or get a different kind of hog
Dec 21, 2010 | Jeep Halo 3 Warthog Rc + 2 Figures Remote...
My 2001 ford escape xlt the driver side seat started moving forward until my knees were in the dash and i was on top of the steering wheel the seat is electric where should i take the car? also there is a...
The knocking noise sounds like it could be a CVjoint going out. This noise only happens when turning I assume? That would be another shop fix because Ican not tell you on here how to replace it but it needs to get done right away. As far as the seat goes. Could you move it back into the correct place with the operating buttons after it moved you? Was there a chance you setyour purse or some other object down by the control switch that made it move?
Apr 16, 2010 | 2001 Ford Escape
My front seat will not move forward. It will recline, move up and down but it will not move forward. I've tried reseting the seat positions but nothing seems to work. my seat wont move forward is there a...
You can move the drivers seat back by turning on the power, getting in the seat and position your feet firmly on the fron flor with your back firmly against he seatback, and then engage the switch pushing back - while pushing like hell with your feet. You can actually hear the seat drive shaft turning while the seat moves back. The principle should be the same for moving forward, but pressure would have to be aplide to the back of the seat.
Jun 02, 2009 | 2004 GMC Envoy
John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Mar 23, 2009 | Garden
AUDI A4 AUTOMATIC SLOW TO ENGAGE FORWARD GEARS ,REVERSE ENGAGES INSTANTLEY BUT TO MOVE FORWARD I NOW SELECT DRIVE FOR AROUND THREE MINUTES THEN MOVE OFF SLOWLEY,THEN ALL GOES WELL
Not overly familiar with Audis but it sounds like either a.) you have an electronic tranny that has a serious bug or b.) there's a problem in the computer of the car itself. What is sounds like is the car is taking a long time to "understand" that you're telling it to move forward. How new is the car? When you push on the gas before the three minutes, what happens?
Oct 21, 2008 | Audi A4 Cars & Trucks
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
243 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
