Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Ricoh aficio mp 1600le error code SC-322 Laser 1 synch. Problem
Functional problem
SOURCE: ricoh 1035 laser problem
sometimes the plastic of the laser is turned by the heat proves to relax and to fit the screw that holds the laser unit that is of the side of the drum while it raises a millimeter with a screwdriver, this sometimes works.
Verifies that the glasses and mirrors well be positioned correctly.
Other
Poor connection between the laser
synchronization detector board and
the LD unit.
Laser synchronization detector board
out of position
defective
LD unit defective
Posted on Nov 15, 2009
Ickoajnc
  • 183 Answers
SOURCE: Ricoh Aficio MP 1600 Le error code sc 322 occured
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
Posted on Jan 13, 2010
  • 903 Answers
SOURCE: Ricoh Aficio AP 2600 laser printer there is a code
On most Ricoh models, SC-322 is a problem with the laser unit. If you have a service contract, have your technician take a look at the printer. Otherwise, you can either have a local Ricoh tech give you a repair estimate or buy a new printer.
On rare occasions you can turn the printer off and turn it back on and the code will be cleared, but most of the time this is a serious error that requires a service technician.
Posted on May 29, 2010
SOURCE: error code sc 322 for
this is a laser unit problem.check laser connections clean the laser unit.
Posted on Aug 10, 2011
SOURCE: Ricoh Aficio MP 2000Le Machine error code SC 546 appears.
"Unstable Fusing Temperature" Chang Fusing Thermistor.
Posted on Jan 07, 2013
Display erro sc 322
This is a Ricoh error code. There is a laser unit synchronization error with the drum unit. I would take out the drum unit of the Ricoh and reseat it to see if that's the problem. You may have a bad drum or a laser unit. If you live in Southeast Florida Advanced business computers is a great source for help. Computer network repair, printer copier maintenance repairs, copier printer leasing and supplies.
Apr 08, 2016 | Ricoh Aficio Mp-1600 Copier
Error code sc 322 for aficio ricoh 2045
Aug 08, 2011 | Ricoh Aficio 1035 Copier
Sc 322 for RICOH AFICIO 2045
That is a LASER error code.
It can be just toner dust because that error is a bad communication between the laser synchronization detector board and the LD unit.
Sometimes the dust of toner goes to the laser and causes this error.
Try to clean the laser unit. Maybe that work
Feb 24, 2011 | Ricoh Aficio 450 Copier
SC 322
sc 322 how to solve this error
Jun 16, 2010 | Ricoh Aficio 450 Copier
Ricoh Aficio AP 2600 laser printer there is a code SC-322
Apr 28, 2010 | Ricoh Aficio AP2600 Laser Printer
Ricoh Aficio MP1600 Le
Is your Windows 7 a 32 or 64 bit? Which driver are you downloading? Recommend PCL5c...
Feb 10, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio MP 1600 Le error code sc 322 occured during print job how do i clear it
Regards
Jan 12, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
I HAVE AN ERROR SC 322 WHEN i GO TO PRINT RICOH 1035
Error Code SC322:
1st laser synchronization error
The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Possible Causes:
+ Poor I/F harness connection between the laser synchronization detector board and the LD unit.
+ Laser synchronization detector board out of position and angle of reflection not correct
+ Laser synchronization detector board defective LD unit defective
Not sure what your expertise is on this, but unless you know how to service the machine yourself, this one is going to require a service call...
There have been instances where toner drops onto the LD Unit and creates problems like this. About a month ago I replaced the Laser Synch. Detector Board in a 1045 for this exact problem and error code.
I'd start by cleaning up any toner on the LD unit, and re-seating all the electrical connectors on the laser unit. If that doesn't clear things up, it's probably one of two things, the LD Unit or the Synch. Board. I'd lean more towards the Synch. Board myself, but you never know...
Nov 18, 2009 | Ricoh Aficio 1035 Copier
Sc 322, sc 326 codes
Never heard of this happening to five machines before.  Check the connections in the laser unit.
Oct 25, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
148 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
