Question about LG M227WD-PZ LCD TV
M227WDP screen blacks out a few seconds
Every now and again, the screen falls away (turns black). After a couple of seconds, "RGB" appears (in the uppr-right corner), and everything goes back to normal. Any ideas ?
micromaster
  • 3614 Answers
SOURCE: LG Flat Screen Problem
since when have you experienced the problem? does the tv still turn on or not...?
Posted on Aug 08, 2008
freetek
  • 5568 Answers
SOURCE: LG 47" LCD FLAT SCREEN
IF IT WASNT DIGITAL HD I WOULD HAVE SUSPECTED HIGH VOLTAGE POWER SUPPLY BUT THAT DOES NOT EXIST HERE.
Well, not completely true; the fluorescent backlight is still a high voltage device, even if only hundreds of volts instead of kilovolts, and either the lamp(s) or the power supply for it (them) is causing the dropout of your picture. When it does it next time, look at the screen from various angles, I think you will see that video content is still there.
Posted on Sep 14, 2008
SOURCE: tv guide on our LG tv
It is NOT the main board. You need a V CHIP UPGRADE "epk file" Email me and I can walk you through it, very easy introspectionx2@yahoo.com Put "TV GUIDE" in the subject line
The problem started with TV GUIDE messing with things while they are doing their digital conversion
Posted on May 14, 2009
  • 8457 Answers
SOURCE: Half the tv screen goes black randomly,then returns to normal
The Tuner signal board have problems.The board CPU,Chip,have intermitten short.When the chip is completely dead.The tv will get only LED light indicator power only,will not get tv signal pictures.
Posted on Apr 12, 2010
  • 4090 Answers
SOURCE: LG Screen M227WDP shows only white screen with a version number
Well as you have only had it a few months, SEND IT BACK ( LG does not mean Lifes Good, in the trade we say LG=Lotta Garbage) There have been quite a few chip failures in this model, It should be recalled. Do a warranty call and get it replaced.
please rate my help++++Thanks for using FIXYA
Posted on Jun 22, 2010
LG M227WDP turns black a couple of seconds
Do you have the "sleep" mode turned off on the computer?
As well, you can try different screen resolutions and refresh rate settings on the video section of your computer. That might make the connection to the TV more stable.
Nov 27, 2013 | LG M227WD-PZ LCD TV
Mio moov 300 screen alignment problem
Download the user manual online and look for factory resettings. Follow instructions and it should work. On my Garmin, the same thing happened. On Garmin, you turn the unit off, press and hold the top left corner of your screen, and turn the unit on while pressing the top left corner of the screen. You wait for 10 seconds and a black dot appears and requests you touch it. The dot moves around the screen and you keep touching it. Once done, your screen perimeter is identified and all the letters fall in place when you press them. Good luck!
Dec 02, 2012 | SNK Mio Moov 300 GPS Receiver
Sony rear proj tv, no picture, menu appears, but in three seperated colors pin cushioned.
Best to first if you have not done so---UNPLUG the set for several minutes and plug back to power to see if that fixes it (it does a lot of the time especially if you had a power outage).
Nov 30, 2012 | Sony Televison & Video
I get a black rectangle in the middle of the screen. I can click any button (mute, view mode, cc) and the black rectangle will go away and whole picture will appear, for a couple of seconds and then the...
I do know that on Zenith CRT televisions of the 1990's this will happen and all I did to fix it is to go to the menu and turn the text feature off. This may be true with your Sharp as well.
May 21, 2011 | Sharp Aquos LC-32D40U Television
The TV has a Black cloud on the right half of the
My parents have the same issue with their Sony KDL-46V4100 TV and were told by the tech that the LCD screen was physically broken and would have to be replaced. The replacement of the screen would cost more than a brand new TV and the TV is not longer under warranty. After the TV is on for awhile the Black cloud goes away but it always comes back when they turn the TV off/on. It stays for 20 - 30 minutes sometimes. The Tech took both top corners of the TV and pushed one back and pulled one forward to show them he could recreate the problem after the black blob cleared up. By twisting the corners he made the blob reapper which he claimed was becuase of the damaged screen. I have no idea how the screen was damaged? I helped them take it out fo the box and set it up. We never dropped it bumped it once? It's never falled off the stand so go figure? It would be nice to find more people with this issue and get a recall going. Something that expensive should last longer than to two years.
Jul 03, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Screen brightness, then disappearance.
Phone flex needs to be changed. As you open and close the flip phone, the flex worn-out gradually.
When you get it fixed, avoid opening the slide unnecessarily and also try as much as possible not to make your phone fall on the ground as this will damage the flex or even the screen.
Take care.
Dec 08, 2009 | LG VX-8700 Cellular Phone
Pioneer AVH-P4000DVD video goes black after 2 or 3 seconds. I can touch screen and it comes back but for only a couple of seconds. Audio is fine
You pressed the Disp. Off button on the bottom left corner. If you press it again it will stop turning the display off.
Oct 25, 2009 | Pioneer AVH-P4000DVD Monitor
My screen goes black after a few seconds
Sounds like a bad solder joint on the printed circuit board. Once it heats up then it no longer makes good contact and the monitor goes black until it cools down and makes contact again. You could resolder it if you knew where it was but monitors are dangerous to go playing around with as they can hold very high charges of electricity in their capacitors that are very dangerous. It's a throw away world. Go buy a new one.
Jun 02, 2009 | Gateway FPD 1750 17" Flat Panel LCD...
LG M227WD-PZ LCD TV Logo
47 people viewed this question
Computer Repairing
Computer Repairing
