Question about Nokia N91 Cellular Phone
My phone is not selecting a network - Nokia N91 Cellular Phone
  • 1 more comment
  • Dmac Mcallister
    Dmac Mcallister Nov 27, 2013
    Hi Dmac Mcallister, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Dmac Mcallister
    my n91 cellphone is not selecting a network
    when I put in a simcard
  • Dmac Mcallister
    how can I fix this problem
Try manual network selection..if its not working change the sim..if it doesn't work may be a hardware problem..
Posted on Apr 12, 2014
I want w995 network problems
The problem with the phone is either is hit a hard object or you need to select the network on phone.
To select the network on the phone, you need to go to the menu, select the settings, go to phone settings, select the network option, you can use either the manual or automatic settings, which ever you select, you will pick your home network.
The other means is to contact the operating network of your phones via the customer care to lay complains so they will be able to help you solve the problem if it is from their network.
If that does not work then it means the network port of your phone is faulty and requires you to seek a phone repairman assistance.
Take care and good luck
Oct 12, 2010 | Sony Ericsson Walkman® W995 Cell Phone
MY Nokia 6610i keeps telling to select network especially if i put it in my pocket.What is the problem?How do i solve it?
i think your phone's network connection is in manual. You should Press Menu, and select Settings, Phone settings and Network selection. Select
Automatic and the phone automatically selects one of the cellular networks
available in your area.
Apr 16, 2010 | Nokia 6610i Cellular Phone
What is network selection? which is better automatic a or b ?
Most GSM handsets offer a choice to select a new network, automatically or manually. The default setting, in most cases, is automatic, which instructs your mobile to automatically connect to the strongest network signal available. As you move, the handset will continually monitor the available networks, and keep you connected to the strongest one. In a manual network selection setting, your mobile handset will detect if there is more than one network present and offer you a choice. If you then select one network, your mobile phone will remain connected to it regardless of the alternative networks available. You may prefer to remain connected to one network if it offers cheaper outgoing call charges. To manually select networks please refer to your mobile phone user manual for instructions. Your Jersey Telecom SIM card can store a list of your preferred roaming partners. If you have an automatic network selection setting, and there are two networks of equal strength available, the mobile phones will connect you to the one that is highest on your SIM card’s preferred list. The list can be edited by using the appropriate menu on your mobile phone. Check your mobile phone user manual for details.
don"t forget to say thank's
Mar 31, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Network problem.
1)go to settings ->phone->Network selection.
2)select 'manual selection' .
3)choose your network from the list.
Jan 11, 2010 | Nokia 2310 Cellular Phone
Network problem
Hi!
Try checking your phones Network settings by opening your D900i's menu - Select Settings / Select option 6 (Network Services)
  • 4 - Network Selection: Should be set to Automatic. You can also try selecting Manual & selecting your phone service provider (Vodafone, Telstra etc)
  • 7 - Band Selection: Should be set to GSM 900/1800
Hope this helps. You can also call Samsung Technical support on: 1300 362 603. They will be able to check some additional settings including some that you can't see on your phone.
Nov 17, 2009 | Samsung SGH-D900 Cellular Phone
Manual network selection
1. Press the Talk button to bring up the call history/dialpad. Now press Menu (at the bottom right hand corner) and select Options. Go to Network tab and select Manual under Network Selection.
2. Tap Start >> Settings. Tap on Phone option in Personal tab, go to Network tab and select Manual under Network selection.
Nov 16, 2009 | HTC S620 Smartphone
Cant pick up a network, it keeps searching
If it is continueing to search for a network. Wanna make sure you have the correct simcard for the carrier in your phone. And it is in the phone correctly. Maybe the phone is NOT completely unlocked. If that all works, check your network in the phone.
  1. At the main screen, press the Menu key.
  2. Scroll to and select Settings.
  3. Scroll to and select Network.
  4. Scroll to and select Network Setup.
  5. Scroll to Type and select Change.
  6. Scroll to and select AUTOMATIC
SAVE. Besure once a day to power down the for about 10-20 seconds a day.
Feb 14, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Motorola K1 KRZR Unlocked but wont connect to 850 network.
you can do a manual band selection
  1. From the main screen, select Main Menu.
  5. Scroll to Band.
  6. Press the Center Select key.
  7. Select one of the following:
    • Automatic
    • 850/1900
    • 900/1800
  8. Select Done.
Feb 02, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
CONTINUOUS SEARCHING FOR NETWORK
change the settings to automatic network selection
if still the problem exists
then contact ur service provider
Oct 28, 2007 | Samsung SGH-E900 Cellular Phone
Nokia N91 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
