Question about Craftsman 14.4 volt Cordless Drill/Driver with Work Light
14.4 craftsman battery - Craftsman 14.4 volt Cordless Drill/Driver with Work Light
    Habit-Forming:
  • 188 Answers
Sears.com has them on sale for $29.74
Posted on Nov 29, 2013
Fuse for igntion were its located
    Riding Lawn Mower Fuse Replacement - Craftsman Lawn ...
    ? 1:51
    https://www.youtube.com/watch?v=rjFz8l8hoGk
    Aug 22, 2014 - Uploaded by RepairClinic.com
    ... instructions for replacing the fuse on a Craftsman riding lawn mower. ... Mower Starter Solenoid Replacement - Craftsman Riding Lawn ...
    14 HP Murray Mower 42813x92B Blowing the Fuse - YouTube
    ? 4:37
    https://www.youtube.com/watch?v=J8l1Ew40G7g
    Feb 14, 2013 - Uploaded by RogerASkiVideo
    Photographic guide to troubleshooting a Murray riding mower that keeps blowing the 15 amp fuse. images for Lawn Mowers ignition fuse
Dec 19, 2015 | Garden
Craftsman lt2000 17hp kohler Has12volts to solenoid and only clicks and doesnt crank. Jumped to starter red cable and starts.
The battery is weak or needs a charge. Have it load tested at a parts store. It needs about 14 volts to start.
Jan 15, 2013 | Craftsman Garden
I have a craftsman with a kohler magnum 18hp. If i put a battery charger on my battery it dont charge i can turn the key and it wont roll over. If i jump my lawn mower and it running i can turn the key all...
Hi, if your battery wont charge you will need to replace it and when you do you need to check that the mower is charging by checking the battery voltage with a multimeter while the mower is running. It should be around 14 volts. Regards Phil.
Sep 06, 2012 | Craftsman Garden
Fuel line craftsman 2.0 14
take the new fuel line cut it down to 1/3 its size about a 1/2 long then feed a wire threw the hole in the tank and out threw the gas cap hole slide the hose over the wire and slowly pull the wire threw untill the hose sticks out then pull it threw
Aug 22, 2012 | Craftsman 2.0/14" Chain Saw Misc. Parts...
I am trying to find an owners manual for a craftsman mower Model No. 917270641
195 craftsman mower manuals on eBay, 6-14-11.
direct hit on google same date:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917270641/0247/1509200
pretty tough. google is the first place to look instead of asking someone else to do it for you.
Jun 14, 2011 | Craftsman Garden
How can I test a riding mower regulator? (puts out 23 amps @ 3800 rpms. My dmm only goes up to 10 amps.(system won't charge battery while in operation. Can it be tested off the mower? Mower is a Craftsman...
Simplest test is to leave it on the engine, battery hooked up normally. Run the engine at normal full speed (not just idling) and use your voltmeter to measure the voltage across the battery with your DMM. If you measure 13.5 to 14 volts, your rectifier/regulator is probably OK.
It can't easily be tested off the mower. You'd need a source of AC at 24 volts to simulate the motor's stator winding, and a load that draws about 23 amps at 12 volts.
Don't forget a bad battery can cause failure to charge - it's not always the regulator.
Jul 16, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Battery discharing light is on
Does your tractor have electric clutch ? With the switch turned off try removing positive battery cable you then try touching cable to post if you get a spark you have a short in system you could also charge battery and remove positive cable from battery over night to see if battery stays up to check battery,you also have a alternater under flywheel to charge battery you should be getting an output of about 14 volts most likely not the problem
May 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 14.4 volt Cordless Drill/Driver with Work Light Logo
53 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
