A/C Compressor-How much oil?
How much oil do I put in my new A/C Compressor?
  • Robert Moller
    Robert Moller May 11, 2010
    New Compressors come with oil.
    Problem Solver:
  • 11 Answers
None, it is already in...
Posted on May 08, 2009
NEW AC COMPRESSOR MAKING NOISE
Did you add the correct amount of oil to the compressor? Is it overcharged? Did you evacuate all the air with a vacuum pump before charging? Was the fixed orifice replaced? If you are sure you did the install right and the oil and charge are correct you have another defective compressor
Jan 25, 2012 | 2005 Chrysler Town & Country
How much oild to put in the ac compreeser
unless you are changing a new compressor you should not have to add any oil in there. Do not put oil since the compressor already has enough oil in it. If you put oil in there and it already has oil, the AC system will not function properly because it has too much oil. How much oil to put in there is determined how much is already in there.
May 28, 2011 | Dodge Ramcharger Cars & Trucks
How much oil do you put in a new ac compressor, 1992 buick lesabre
Hello: Drain oil out of old compressor, measure amount and put that amount in new compressor. Approximately 8 oz.
May 15, 2011 | 1992 Buick LeSabre
How much oil do i put in my 2000 dodge stratus air conditioner compressor?
Most the time its 8 oz,, need to check with the seller and see the specs on compressor,it should say on ac compressor
Aug 22, 2010 | 2000 Dodge Stratus
Installed new air conditioning compressor in 2002 Pontiac Grand Prix - how much compressor oil do I need to put in?
If you have not cleaned out the ac system,the ac system will have oil in it,but,the compressor most likely does not have any in it,so pour about 4 to 5 oz in the low side opening on the compressor before installing it,and turn the center nut of the compressor clutch about 8 to 10 times,oil will try and come out the high side,when it does,this will be enough turning.If the system needs more oil,add as needed when freon is put in the system.If the oil is not added to the ac compressor before installing,the compressor could be damaged.Please rate if this was helpful,thank you.
Jun 11, 2010 | 2002 Pontiac Grand Prix
When replacing the air conditioner Compressor and dyer how do I determine how much oil to put back into the system?
THE ACCUMULATOR OR DRYER.YOU HAVE TO PUT 1 OUNCE OF REFRIGERANT OIL IN IT.THE COMPRESSOR HAS SHIPPING OIL IN IT.IT HAS TO BE REPLACED.SO YOU TAKE NEW COMPRESSOR POUR OUT THE SHIPPING OIL IN IT.AND PUT THE SAME AMOUNT OF NEW REFRIGERANT IN COMPRESSOR.GO TO GARAGE OR AUTO PARTS PLACE.TO CHECK TO SEE HOW MUCH OIL COMPRESSOR HOLD TO BE ON THE SAFE SIDE.
Oct 18, 2009 | 2003 Ford Taurus
I am working on a 2000 nissan maxima and i have replaced the compressor and refilled the freon and oil and the presure relief valve keeps poping open with only one can of freon instaled it seems likethere...
Sometimes there are plugs in the compressor when shipped. Make sure that there is nothing in the compressor where the line attach. How much oil did you put in the system. Compressor are shipped with oil in them. The correct way to measure would be to drain the oil compressor and measure that amount. Then drain the new compressor and compare the amounts. Put NEW oil in the new compressor. Remember the compressor can not compress liquids. It is possible that there is too much oil in the compressor.
Jul 18, 2009 | 2000 Nissan Frontier
I installed a new a/c compressor on a 91 geo metro.Where does the compressor oil go into the compressor at?
The compressor's oil is mixed with and circulates with the refrigerant. R134a refrigerant can be purchased with or without oil mixed into it. There are also separate oil 'chargers' that inject oil without the refrigerant.
Jul 01, 2009 | 1991 Geo Metro
What kind of oil do you put in ac
Any aftermarket refrigerant additives (the ones you can buy at Wal-Mart, for example) come with the oil already in place.  It is a synthetic oil - for this reason, it is incompatable with older refrigerants, which used mineral oils.  A note of advice - if you don't know exactly what you are doing with the A/C system, take it to a professional, as you can really mess it up (overcharging the system, allowing impurities in, etc).  If you cannot afford this, at least buy one of the more expensive refrigerant refills that have the guage calibrated to the temperature outside.  Good luck!
May 25, 2009 | 2002 Dodge Caravan
Whrilpool Compressor
They are oil cooler lines. Your unit does not have an oil cooler so leave the plugs in & don't mess with them. Trust me just put the same compressor in the same model today. Appliance tech 10 years.
Oct 29, 2007 | Refrigerators
Open Questions:
Heating & Cooling Logo
418 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
