Question about Intedge 12H-1/2 Meat Chopper Plate, 1/2-in
On/off switch not consistantly turning on motor. sometime motor only hums w/o motor turning
Any ideas? where can we get parts in zip 07067
Blades will not turn. They turn with broomhandle but when I throw the switch, just get humming.
Whenever the motor hums without spinning, it is overheating.
Your motor has no obstruction since blades rotate freely, so motor lost power in the start winding.
Once motors overheat, and stop turning, then they are bad.
There are no replacement parts for disposals.
I wrote EZ disposal replacement step that will save time and sometimes money:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 22, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a 18 year old dura-glas pool pump. Recently, when turned on, the pump sometimes just 'hums' for about 3-4 seconds, then starts. The pump is primed and does not leak. There are no obstructions...
SOUNDS LIKE THE START SWITCH IS DIRTY OR IT MAY NEED A CAPACITOR it's a 161start cap THIS IS HANDS DOWN THE BEST PUMP YOU CAN HAVE ! THESE AS ALL PUMPS CAN BE TRICKY TO WORK ON, THIS COULD HAVE THE MOTOR REPAIRED WITH NEW BEARINGS AND A SHAFT SEAL AND DIFFUSER ALL FOR ABOUT 100.00 .. LOOK FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY OR SHOP.. USE YOUR ZIP CODE IN YOUR SEARCH .. GOOD LUCK AND VOTE .. Jay
Jul 28, 2010 | Sta Rite StaRite Duraglas Pump 1 12 HP...
Kenmore Model 110 washer humming/popping breaker
Good day,
Anytime an appliance knocks a breaker down, the motor is the obvious culpret.
The first thing to do is remove the motor and take it to an appliance parts house for testing.
If the coupling broke, it is just sometimes just happenstance. In other cases it could be a transmission starting to lock up, which would overtax the motor, and eventually cause it to fail.
Lastley, most models are 2 or three speed. If the timer screws up and tries to run the motor on high and medium or low at the same time it will fry the motor.
Dec 10, 2009 | Kenmore Washing Machines
My Kenmore stackable dryer (model#417.97802792)doesn't start consistantly. Sometimes when turning the start switch it will run fine. Other times you have to hold it a little longer for the drum to turn....
Yes the motor is going out, The motor is getting a "flat spot" or a bad area in the windings. If it happens to stop there it does not want to start. After holding the button it moves from that spot and will run again.
You can do a search for "appliance parts" online and find your part easily. Just enter your model number and find your part.
Check a number of different sites as the prices can vary greatly.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 30, 2009 | Washing Machines
1/3 hp drill press motor runs hot and very slow.
Look instead at the motor and drill post bearings. Remove the belt to see if the motor runs correctly with no load. If it still hums and gets hot, check that the motor itself turns freely (when off). If the motor seems to be ok, turn the driven pulley by hand--it should also turn freely. The capacitor is usually a starting assist, not running. To test, wrap a small rope several turns (when pulled must turn in the normal direction) around the small motor pulley and pull smartly while turning the motor on. If it now comes up to speed, the capacitor has lost capacitance. Electronic parts suppliers like Jameco or Mouser have such items.
Aug 23, 2009 | Drills
Blower/Switch Problem with Air Flow?
The extra air flow most likely turns the fan motor, check the fuses, check the fan motor switch for power if O.K. check the fan motor for power..
Aug 15, 2009 | 2002 Isuzu Rodeo
Dryer hums and won't work
can you remove the belt and run it/..look at the motor if it is spinning. let me know. normally, if it hums, its the motor which is not starting, when you replaced the motor, im sure it has its own centrifugal switch and starting capacitor. did you replaced the starting capacitor?..it could be open.
Mar 28, 2008 | Dryers
GE Dryer DWSR473GV0WW periodically just hums when turning on switch
might have a dead spot on the armuture or lint in the motor and or the centrifcal switch try taking it apart and cleaning the motor if that doesnt work replace the motor
Feb 14, 2008 | Dryers
My Matag dryer does not run, but for a while it hummed before starting.
Motors of this sort have a "start" winding, to give them an extra boost to get them turning. Once they're turning, the start winding shuts off. Critical to this is the start capacitor which, when shorted, causes the exact symptom you've described. The motor's "regular" winding gets power (and then hums), but it needs that extra boost to actually start turning. Have someone check the capacitor (with an ohmeter) or check to see if the motor's start winding is open (broken).
Apr 10, 2006 | Maytag HYG2460AWW Gas Dryer
Intedge 12H-1/2 Meat Chopper Plate, 1/2-in Logo
196 people viewed this question
Top Intedge Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you an Intedge Kitchen Appliances - Other Expert? Answer questions, earn points and help others
