Question about Toshiba Computers & Internet
Downloadcor i3 m380 drivers
My mouse pad is not working
    New Friend:
  • 63 Answers
Be sure your mouse pad is connected firmly to your computer desk. If the cushioning of your mouse pad is not sufficient, perhaps consider using a pillow instead.
Posted on Nov 27, 2013
Asus s200e
Is your mouse or pointer pad driver properly installed or plugged in?Try a different mouse.
Aug 24, 2014 | ASUS VivoBook S200E Notebook PC - Intel...
Lenovo v560 laptop motherboard no power on
check you battery, try turning on with battery removed. try a new charger. check charging port to see if it is loose. if all these fail then motherboard is bad
Dec 28, 2013 | Lenovo Ideapad V560-43422gu,intel Core...
Upgrade intel t2130
On a laptop?, Most likely not. Laptops can't really be upgraded much, sadly.
Aug 25, 2013 | ASUS F5R-AP038A Notebook
How di make my mouse work
usb mouse or mouse bad ?
Look at the type of mouse you have.
To date, there are three types of mice: the USB mouse, the PS/2 mouse and the Bluetooth mouse.
USB mice connect with a USB adapter, which has a rectangular shape. Conversely, the PS/2 mouse uses a PS/2 adapter, which is round.
Finally, there's the Bluetooth mouse, which has no external adapters.
Plug the mouse into your machine.
Now, how you do this will depend on the mouse you're using.
With a USB mouse, simply plug your device into your laptop's USB adapter, which will also be rectangular in shape.
For PS/2 mice, you'll need to plug it into a PS/2 adapter. Plug your mouse into the PS/2 end then plug the other end into your laptop's USB adapter.
And for Bluetooth mice, no plugging is required.
Install the mouse drivers.
If your mouse is not plug-and-play, you're going to need to install its drivers. To do this, insert the CD or diskette that came with your device.
The installation should occur automatically.
Pair your mouse, if using a Bluetooth mouse.
At this stage, non-Bluetooth mice are ready to be used.
However, if you are installing a Bluetooth mouse, you must perform one additional step: pairing it to your machine.
To achieve this, use your laptop's touchpad and right-click on your Windows screen. Select the option "Pair Device." From there, follow the on-screen instructions to sync your mouse with yourcomputer.
Place your mouse onto a mouse pad. Before using your mouse, you need to place it onto a mouse pad.
This should be done for all types of mice, whether they are wireless or trackball.
Otherwise, movement will be difficult
mouse pad
Examine your mouse pad.
Dirt and grime can affect performance and slow down mouse sensitivity, if not shut it down altogether.
Make sure the surface of the track pad is clean and that there is nothing that has managed to get beneath it or around any trackball buttons that could affect the pressing and depressing of the component.
Check to see if your mouse pad has been turned off.
If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad.
To enable your mouse pad on a Windows PC go to the Control Menu.
Under the Printers and Other Hardware option, click on Mouse.
Then, click on the tab on the top of the pop-up menu that says Device Settings.
The touch pad for your computer should come up as a selectable option. Click on it and you will see the option to enable your device, then click OK. If this does not work,
Check the manufacturer of your laptop (for example, Toshiba) and then navigate to their official website. Find an area for Software and Drivers, and move on to that area.
Enter your laptop number (check your documentation/manuals and/or the bottom of the computer) and look through the drivers that are presented as a result of this number input.
It could be that your mouse pad simply needs updated drivers. Find the driver that corresponds to your computer and mouse pad (for example, most Acer laptops use a Synaptics touch pad).
Then, click on download.
Once the drivers have downloaded, double click them to ensure they install, restart your laptop, and your mouse pad should be working again.
hope this helps
Sep 09, 2012 | Compaq Presario CQ57-339WM
I WAS SETTING WIFI ON MY HP PRO BOOK 4520S AND SUDDENLY MY MOUSE PAD AND NAVIGATION KEY STUCK AND NOW IT IS NOT WORKING KINDLY GIVE SOME BETTER INSTRUCTION TO MAKE MY LAPTOP WORK SAFELY
Do not worry .. You disabled the touch pad by mistake .
Press two times the touch pad area where you can see yellow light...
two times press make it lock and unlock both......
Mar 31, 2011 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
I want to deactivate the center blue colour touch/scroll botton
Usually the mouse control panel has options to disable the pointer or pad.
If you can't see it, download the latest pointer drivers from Dell for your model.
Mar 19, 2011 | Dell Latitude E5410 Laptop Computer (Intel...
Cursor won't move gateway NV79 intel core
Just a quick reminder... Above the keyboard there are touch buttons, one of them is to turn off the touch pad, (it looks like a finger touching the pad). LOL, I know sometimes we overlook the easiest stuff....
Feb 28, 2011 | Gateway - Laptop / IntelĀ® CoreTM i3...
I have a dell inspiron 15R (two weeks old) The touch pad doesn't work at all. I used a wireless mouse to play a game and when I took it off the touch pad would not work.
Go to the Dell website and then surf to their Support site. Choose the Download Drivers section of the page. The screen will then ask you to input your Service Tag, which should be on a sticker on the bottom of your laptop. Once you input the number you will get a list of all of the drivers you need for your machine. Download the touchpad driver for you laptop. It would be easiest if you save the file to your desktop. Once the download is finished double click on the icon that was created on your desktop. The driver file will then unpack itself and complete the installation process.
What you should be able to do now is use both your mouse and the touchpad at the same time. Anytime you install a driver for a mouse you will have to reinstall the touchpad driver again. Once you do that they should both be able to co-exist without any further issues.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 18, 2011 | Dell Inspiron 15R Laptop Computer (Intel...
Computers & Internet Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
