Old remington typewriter
This is an old Remington typewriter from the '30s or '40s... it still seems in good shape, but when you hit the keys, the carriage does not advance.  Seems like it should just be a belt of something, but I do not want to go poking around without advice and possibly make the problem worse.  I can supply photos of the typewriter if you really want to see them.
  • 1 more comment
  • cnguyen1 Feb 14, 2008
    For some reason when I type, the carriage won't advance. Moreover, when I try to manually move the carriage, it too is stuck.
  • Anonymous Sep 14, 2008
    I acquired a 1930-1940 Remington Typewriter which looks to be in good shape, but carriage is locked up. The keys work, but nothing will move the carriage backwards or foreward. It rolls paper up and down, but that's it.
    Charles M. Harper
    804-273-0780
  • robstack Mar 09, 2009
    I have the same problem. These instructions are a bit complicated to follow. Does anyone have picture samples?
    Problem Solver:
  • 19 Answers
G'day mate, most likely cause is that the drawband is broken/disconnected. Look under the right-hand side of the carriage,you would have to tilt the typewriter on it's back. There you will see a small hook where the drawband should be attached to. If not, set the typewriter on it's feet again and move the carriage to the extreme right then looking down past the left thumb wheel you will notice a drum with the drawband attached. Rotate it until the drawband hook come into view. Get a piece of strong wire about 12 inches long,fashion one end into a hook,thread it through the machine under the carriage,from the right-hand side until it appears just over the drum. Ayyach the drawband hook to it and pull your piece of wire out to the right. You will notice the drum rotating and the increasing tension on the drawband , this good,nothing is going to snap, break etc. Hook the drawband on to it's latch and try the typing. If the typewriter's carriage moves slowly it means that there is not enough tension on the main-spring located inside that drum. Do not depair, because by removing both side plates you will see a large screw on each side of the back cover plate remove these and then you will see the mainspring drum in it's entirety. There will be a winding gear central to the drum,loosen the locking pawl and begin winding in aclock-wise direction to increase the main-spring tension. Test the carriage occasionally for tension.
When all is OK reverse all what you did before.  Cheers and goo luck from Australia....
Posted on Oct 18, 2007
Alot of these old typewriters had a lock point in the center of the carriage so they would sit properly in the case for transport. Usually these are unlocked by a release lever on 1 or both sides of the carraige, by the platen or rollers. My Remington deluxe noiseless has this lock, it is released via a lever on the right hand side. Poke around and pull the levers up and down and often you can find the correct lever to release the carriage. Often this same lever will also lock it back up for transport. Good luck and happy typing!
Posted on Apr 21, 2009
SOURCE:
I have a old royal or remington typewriter but can't remember where I put the key.
If you are talking about the key for the case these are simple locks and easily opened with a hair pin or take it to a lock smith.
DickyO
Mar 11, 2015 | Royal Office Equipment & Supplies
Problem with ribbon on Remington manual typewriter
find the ribbon selector lever but it in the black position of that don't work it may have a broken link
Aug 16, 2014 | Office Equipment & Supplies
My Remington Noiseless 1939 typewriter has ghosting on the letter keys. I have put on a new ribbon but this just shows up the ghosting of each letter more than ever. I notice when typing the carriage
Could also be that your paper is too fibrous of finish. I found this page because my typewriter was ghosting, too. I adjusted some of the settings and there was not a trace of ghosting. I put the settings back and still no trace of ghosting. Then I realized that I tested for ghosting on paper that has a much smoother finish. I was ghosting on cheap paper we use here at work. So, I don't blame the typewriter. I blame the cheap paper. My typewriter just likes good paper.
Nov 14, 2011 | Office Equipment & Supplies
Lookinf for a typewriter ribbon for a Remington 15
I can't find a remington 15 listed anywhere but you can try this.
Almost all typewriters use a 1/2 in. ribbon buy a ribbon and wrap it on your spools this is a little messy but sometimes it's the only way.
DickyO
Jul 27, 2010 | Office Equipment & Supplies
Where can I find brushes for the remington model
Remington saw has gone out of business, and finding parts can be a hit or miss experience. Motor brushes in particular are quite rare, so you need to be resourceful in finding a similar brush used in other small tools. Visit a small tool repair shop or check with Ace Hardware (our local store has a whole display box of various sized brushes). If you do find something, buy more because these saws seem to eat brushes for lunch! Good luck!
Jun 07, 2010 | Remington Electric Chain Saw
Old Remington Typewriter Model 16
Google it. You should be able to try some of the old typewriter dealers in the Northeast or Chicago. I charge about $ 100.00 dollars to overhaul manual typewriters. This is a pretty easy machine to use.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 10, 2009 | Office Equipment & Supplies
Open Questions:
3,317 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
