EVESHAM ALQEM142SX TV
SCREEN PROBLEM. GHOSTING, AN LINE'S
How do i connect my acer laptop to my evesham TV
Use an HDMI cable, 1,366x768 resolution. You should be able to select mirror (duplicate the laptop screen) or extend (act as a second desktop).
Feb 23, 2015 | Evesham Televison & Video
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Jan 24, 2014 | Vizio Televison & Video
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
5 digit evesham tv code
Dear Sir:
go to www.fitness.manualsonline.com or call to your manufacturer TV for get the digits.
God bless you
May 13, 2012 | Evesham Televison & Video
Composite output has ghosting around the video (sort of an auro around all images on screen, including text and video). dvd menu also has this problem, so i verified that it is the output of the recorder...
Try reducing your sharpness value on either your TV or the player if applicable. Also disable any edge enhancement or "DVE" modes on the TV if applicable.
The easiest way to adjust sharpness control by the naked eye is with a calibration disc. Alternatively however, just for sharpness if you have a screen full of text and/or lines do the following;
Reduce your color/saturation value all the way down...this will make the picture black and white.
Then reduce your sharpness control until the "ghosting" effect or any additional white lines on text edges and line edges disappear.
Then you can return your color/saturation value back to normal.
Hope this helps!
Jan 12, 2011 | Toshiba DR4 DVD Recorder
Blue dots on screen plus ghosting on screen
The optical block is defective. Contact Sony support. Sometimes they will warranty these even after the 1yr warranty has expired. Have your model and serial numbers handy.
May 12, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Ghosting on LCD TV
get a big heavy brick and throw it at the screen this fixed mine
in no time and got a sony instead
Apr 08, 2008 | Televison & Video
Philips rear projection tv prob
You need to replace the conversion ICs. Both of them.
Mar 09, 2008 | Televison & Video
Lcd with bad picture
my sony bravia 40v 3000 has bad ghosting in the first 15 mis of operation
Oct 13, 2007 | Televison & Video
Sony KP-43HT20 ghosting effect.
may have bad convergence amps stk392-560 board location Ic8001 Ic8002 or the dcu unit is bad or the alignment drifted off and it needs service adjustments made to it.
Dec 28, 2006 | Sony KP-43HT20 43" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
