Question about Tripp Lite SRXCOOL12K - SRXCOOL12K Airflow Cooling System - 12660.7 Kj - Tower
I have a portable air conditioning unit SRXCOOL 12K and it i flashing a P1 code
What does P1 mean if it's flashing on the screen
P-1 code
Hello Friend, thank you for allowing me to assist you!
If you are getting an error code P1 on your Frigidaire air conditioner, normally it indicates that the bottom tray is full. Carefully remove your air conditioner to a drain location and remove the bottom drain plug and allow the water drain. Then restart your appliance and P1 symbol should disappear after you have let your appliance run. However, if the error code continues, at this point, I would recommend reaching out to a professional to proceed further. - Z
Jul 20, 2014 | Frigidaire FAP094P1Z Portable Air...
Code es error
Hi Kirby, thank you for allowing me to assist you!
Error code ES and P1 are commonly referred to a sensor failure. Because it is a smaller appliance, repairs are often more costly than the actual unit replacement. Is your appliance still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your air conditioner and the procedures to any potential remedy in that regard.
Best of luck!
Sep 12, 2013 | Frigidaire FAP094P1Z Portable Air...
What does the P1 mean and full?
Is there a model number on there, usually there is a little data tag on the back or bottom of the unit. If you can find a model # I might be able to track down a owners manual.
Aug 25, 2013 | Frigidaire Heating & Cooling
Bucket full light is on, I have drain tube out the window, air won't work. How to fix?
Hi Kathleen King - Typically when the error code P1 displays on panel it indicates that the unit has a sensor error. I would recommend contacting a professional to accurately diagnose and repair the unit.
Oct 02, 2012 | Frigidaire FAP094P1Z Portable Air...
Whats does P1 mean on my portable ac unit everstar model # mpn1095cr-bb6
What if you don't have the drain hose that came with it can you use any hose?
Jul 30, 2012 | Heating & Cooling
Mec portable air condition shows E5 on the screen after i on the air cond about 15-30minutes. Once it showed E5, cool air was not feel but just like fan air. what is the problem?
MEC portable aircond show P1 after on in a 1 and half hour. Once it showed P1, cool air was not feel but just like fan air. what is the problem?
Jun 02, 2012 | Heating & Cooling
I am getting a code P1, what does it mean?
P1 Indicates that the water collection tank is full and needs to be drained. Turn the unit OFF & unplug it before attempting to drain it.
Hope this helped and thanks for choosing FixYa.
Sep 13, 2011 | Danby DPAC5070 Portable Air Conditioner
My Everstar mpm-08cr-bb4 stopped working and dislays P1
The P1 code means the lower water bowl is full.
Put a pan under it an pull the lower plug (some 10" below the upper drain plug that I hope you have a hose attached to.
Jul 07, 2009 | Heating & Cooling
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
Tripp Lite SRXCOOL12K - SRXCOOL12K Airflow Cooling System - 12660.7 Kj - Tower Logo
41 people viewed this question
Top Tripp Lite Computers & Internet Experts
SHIVAJI YADAV
SHIVAJI YADAV
240cpa
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
