Question about Dell Inspiron E1505 Notebook
Dell Inspiron E1505 will not power up - Battery or A/C Power
I was handed a Dell Inspiron E1505 yesterday with the offer of if I can get it working, it's mine.
With the computer plugged in and the battery installed, I press the power button, the power indicator (next to the hard drive indicator and battery indicator) will flash green for about 1/2 a second, and that's it. No fans will spin up, no optical drives will do anything, nothing.
I took the battery out of the computer and ran straight A/C power, same symptom.
I let the battery charge overnight, and the battery indicator was green while the computer was charging.
One suggestion was to get a new battery, since Dell's won't even power up with a dead battery. However this does not make sense, because if the battery is removed, shouldn't the computer at least start?
I reseated the two RAM modules, and pulled out and pushed back in the hard drive.
Suggestions?
  • scott734 May 08, 2009
    Thanks for the suggestions!! I just pulled the computer apart, and took a good look at the motherboard. I detected no burned resistors, or anything that was not connected. Reassembled everything and when I tried to turn it on, nothing. Going to price a new motherboard, since I now have experience in taking it apart!
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Yes, it won't start if the motherboard is fried...the ac hookup is straight power to you notebook so buying a new battery does not make any sense at this point sense it doesn't work on AC power it won't work on a new battery either. You probably would be doing good taking it to a repair shop and letting them run diagniostics on it, they can tell you if the motherboard is no good..which in that case it'll make a good book end that's about it..
    Sergeant:
    Novelist:
  • 197 Answers
If you're not ready to take it to a repair shop, there are a few things you can look for yourself. If the power blinks for a quick second before cutting out, which means you most likely have a short. This could be as simple as a faulty power cord, so try moving the cord where it takes the most movement, to see if you can get prolonged power by holding the cord in certain ways (temporarily making the worn wire inside make contact)
If that does nothing, take a look at the mainboard itself. Look for any darkened or discoloured areas, or melted/damaged resistors etc.
Posted on May 08, 2009
Well with regards in laptop battery not charging, there are huge steps to follow on how to fix it such as (http://www.genuinebatteries.com/blog/solutions-for-a-laptop-battery-not-charging/) While in giving a good quality replacement for your laptop battery, there is GENUINEBATTERIES.COM. I hope it would help, keep on posting.
Posted on Sep 13, 2012
    Problem Solver:
  • 9 Answers
If the PC shot off cause of an overheated CPU, the protection mechanism won't let you turn it on for a certain period of time. However that time is usually from a couple min to maybe an hour. Try clearing the CMOS, either by removing the BIOS battery or through the board's jumper, if it has one.
Also a dead, or "stuck" CPU fan could prevent it from turning on. Odd, but still a possibility with dell's bizarre configurations.
Dell Inspiron E1505 will power off after 3 seconds
If the system will not run long enough to run diagsnostics, I'd replace the heatsink and the fan
May 14, 2010 | Dell Inspiron E1505 Notebook
I just bought a replacement 9 cell battery and a 90 watt power adapter for my Dell E1505. With the new battery and power adapter my battery indicator light keeps flashing green and the battery doesn't...
If a new DELL ac adapter (3rd party Adapters are not recognized and the charging circuit is disabled) and a new battery doesn't resolve then the charging circuit on the motherboard is bad
Dec 29, 2009 | Dell Inspiron E1505 Notebook
DELL LAPTOP INSPIRON 6400 MY LAPTOP BATTERY IS SHOWING STATUS ( UNKNOWN ) ON WINDOWS & ON BIOS IT SAYSS BATTERY NOT INSTALLED
Here are my recommendations for this issue:
1. Reseat the battery.
2. Remove All External Components
3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris.
4. Remove All External Components
5. Try a known-good battery in the system, if available.
Jun 09, 2009 | Dell Inspiron 6400 Notebook
I Cannot turn my laptop
Make sure that power cord is not connected. Reseat battery, plug in power cord, power on
Apr 24, 2009 | Dell Inspiron E1505 Notebook
Dell inspiron E1505 won't charge or power on period!!!
Sounds like you might have a bad dc power jack. ifyou wiggle the jack around where it plugs in on the computer, does the powr light come on?
Mar 30, 2009 | Dell Inspiron E1505 Notebook
Does not power up
Battery may be bad on the laptop. Try removing the battery and powering on the computer with only the AC power.
(Usually you can flip them over and there's a locking "slide" that you have to hold over while you remove the battery. )
If it still refuses to power it on, try to note what it says on the screen (use a digital camera to snap a few photos if necessary) and post back. It seems likely that it's the battery, however.
Hope that helps.
Nov 30, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 Notebook Logo
591 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
