Question about KitchenAid Dishwashers
Did not fully drain and will not turn back on
Did not drain fully and will not turn back on
    Scholar:
    New Friend:
  • 53 Answers
Might have blown fuse.
Check for obstructions in drain line -- the pumped line from pump under DW to drain. Is their debris in air gap or in the bottom of the DW, where the drain is screened?
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
Good luck.
Posted on Jan 11, 2014
Is there a method to bring power tool batteries back to life?
Yes! Rechargeable batteries can be rejuvenated by draining them fully and then recharging fully and then repeating a few times! The trick is to fully drain and fully charge!
Jan 21, 2015 | Ryobi Drills
Water is not fully draining after after cycle
it sounds like the pump is weak. I would replace it
Apr 04, 2014 | Whirlpool Washing Machines
My Beko 81241 LW seems to be stuck in the Spin & Drain cycle (it's not actually on though) and the Start symbol is flashing. The time is also displayed (12mins). The door is also locked. Holding the Start...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Oct 30, 2013 | Beko Washing Machines
Maytag Neptune washer machine won't spin or fully drain
    • 1 Open your home's breaker box and flip the circuit breaker switch to "On." If it is already set to "On," flip it to "Off" and then back to "On" to reset it. A power surge may have interrupted your wash cycle so the drain/spin cycle never actually started.
    • 2 Move the washer away from the wall and straighten the drain hose if it is twisted or turned in a way that makes it difficult for water to flow through it. Replace a kinked hose with a new hose.
    • Sponsored Links
    • 3 Push on the washer door to make sure it is fully closed. The washer will not drain or spin unless the door is closed tight. Press the "Start/Pause" button after you close the door.
    • 4 Wait for about 30 seconds after you press "Start/Pause." The washer will not operate until it has been able to fully lock the door and restart the drain process.
    • 5 Run the clothes through a complete cycle again, making sure you use cold water if there are a lot of suds in the washer. Too much soap in the washer can make it hard to drain. Use high-efficiency or low-sudsing detergents on subsequent uses.
Feb 15, 2013 | Washing Machines
LG WM210HW doesn't fully drain
Pull the drain boot that runs from the tub to the pump and check it for blockage. Post the results back to me.
Feb 03, 2013 | Washing Machines
Water seems to be coming from underneath
Check that your drain hose is fully inserted into the wall/floor drain. then run an empty load with just water and watch it during the drain cycle to see if either the drain is backing up or if it's not fully connected at the back of the washer. if the drain is backing up you can try a drain sn ake available at most hardware stores and that will most likely clear it. If it's leaking at the connection at the back of the washer try to push it in fully or replace the hose altogether. It's not the water inlets because they always have pressure on them and would leak constantly. or you could have a cracked basket in which case you will be better to buy a new machine. cracked baskets don't happen very often though. And once in a blue moon it could be an off balance issue where its actually splashing out. Either way you need to spend some quality time with your washer and see why it's crying =]
May 02, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Change transmission fluid in 2004 Toyota Corolla
cool off the fluid , locate, loosen and remove the drain plug of your ATF, fully drain the oil, once fully drained up to the last drop, put back the drain plug and refill the ATF. if its a manual transaxle the procedure is the same.....hope this helps.
Apr 14, 2010 | 2004 Toyota Corolla
Battery Icon with red line through it? Durring a back up, my Storm turned off and when I turned it back on this battery icon is all I get. I have a fully charged new battery in it now and it still shows...
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in.
Jul 18, 2009 | RIM BlackBerry Storm 9530 Smartphone
My Blackberry curve 8320 won't turn on it just has a battery icon with a red line through it on screen. A new battery was tried and the problem still exists.
3. If that fails, retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in to cell store.
Jun 08, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Screen shows battery with a red line through it
4. Take in.
Feb 16, 2009 | RIM BlackBerry 7130c Cell Phone
Dishwashers Logo
124 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
