Question about Epson Stylus 1400 InkJet Photo Printer
Can't clear the buffer
Keeps printing a job that we didn't call for and we would like to clear the buffer but cant ..any suggestion
  • Epson Master
  • 4,338 Answers
Run a Printer Check: You can run a printer check to determine whether a problem comes from the printer itself or some other source. Before you run a printer check, make sure the CD/DVD tray is not inserted in the printer. 1. Turn off both the printer and computer. Then disconnect the USB cable from the printer. 2. Make sure letter-size plain paper is loaded in the printer. 3. Press the can't clear the buffer - probsolv.5.1.25.jpg paper and power buttons together to turn on the printer. Continue holding down the probsolv.5.1.27.jpg paper button until the gcan't clear the buffer - probsolv.5.1.28.jpg://i.fixya.net/uploads/images/probsolv.5.1.28.jpg" alt="probsolv.5.1.28.jpg" class="h_mi" /> power light starts to flash, then release it. A test page prints showing the printer’s ROM version number and a nozzle check pattern. (If the pattern has gaps, you need to clean the print head.) 4. Turn off the printer after it prints the test page. Then reconnect the cable and turn on your printer and computer. If the test page prints, the problem probably lies in your software settings, the cable, or your computer. It’s also possible that your software may not be installed correctly. Follow the instructions in Uninstalling Printer Software to uninstall and reinstall your software. If the test page doesn’t print, you may have a problem with your printer. Try the suggestions in Problems and Solutions. If nothing works, contact Epson as described in Where to Get Help. Problems and Solutions
See page 63 in the manual:
http://files.support.epson.com/pdf/pho140/pho140ug.pdf
Also, in the solving problems section of this reference guide:
http://files.support.epson.com/htmldocs/pho140/pho140rf/wwhelp/wwhimpl/js/html/wwhelp.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 08, 2009
The first 6 copies print quickly, then it goess to "slow motion" for rest of print job. How can I get the printer to print at the same speed
My guess would be that the quick printing at first is because the print job get spooled into a buffer and when the buffer is full the print job starts. The printer begins printing and using the buffer data as the computer continues to process the job and supply the buffer. At some point the buffer gets empty and the printer is waiting on the computer for more data, causing the slowdown. This rarely happens anymore, unless you have a very old printer or very old computer, as most printers have a rather large internal buffer memory. You may be experiencing issues with connectivity if the printer is being used wirelessly. Check to ensure that the wireless signal is strong to ensure maximum data throughput capability.
Oct 14, 2016 | Office Equipment & Supplies
How can I stop it from printing over and over again
you have clear the print buffer in the computer.
by clearing out the buffer, unplug the computer after ward and than also unplug the printer too, that should clean the memory in the printer itself.
GO TO START CLICK ON START GO TO DEVICES AND PRINTERS, OPEN THE FOLDER CLICK ON THE PRINT YOU ARE HAVING ISSUES WITH DOUBLE CLICK IT WILL SENT YOU TO CHECK LIST OF OPTIONS THE FIRST ONE.
1. SEE WHATS PRINTING, CLICK TO OPEN
2. HIGH LIGHT PRINTER THAN SCROLL DOWN TO CANCEL ALL DOCUMENTS.
YOU SHOULD BE DONE
BUT YOU STILL HAVE TO CLEAR THE MEMORY THAT STORE INFORMATION IN MEMORY INSIDE THE PRINTER
BY TURNING OFF MAY NOT BE ENOUGH YOU MITE HAVE STILL UNPLUG IT TO CLEAR ANY OR ALL MEMORY FILE
THANK YOU ROD
Mar 03, 2015 | HP Office Equipment & Supplies
Zebra printing continuously problem
disconnect printer from computer and power on again. at driver chech if still jobs there and clear buffer. at printer, if still printing whithout connested its becase it still have information to print. just reset printer to factory default or let job to finish.
Mar 18, 2014 | Zebra GX420t Thermal Printer
When I click on cancel and then on "yes" the printing job continues. Sometimes I want to stop in the middle of the job because I have gotten all that I want printed.
The printer has a buffer which stores data from the computer as it's printing, and even after you cancel a job the printer will keep going until it uses up that data. If you've printed all you need, you can shut off the printer. This will cause Windows to tell you about the communication error, and you can cancel the job then. When you turn the printer back on, the buffer is clear and it won't print anything else until the next job.
Dec 16, 2010 | Computers & Internet
Lexmark x6575 - i work off a mac message reads : The cartridge carrier is jammed. Check under the scanner unit for obstructions. Close the unit and press the Check button on the control panel. Delete or...
Clear the print buffer, unplug the printer, remove everything that could be jamming the printer, CHECK carefully, then plug the printer back on and see if it has cleared. You may have to restrt the computer to reset the print buffer. Hope it helps.
Brock
Sep 16, 2010 | Lexmark P6250 All-In-One InkJet Photo...
CANT STOP OKI 591 PRINTER TO STOP PRINTING REPORT
Check that the LINE FEED button is not jamming or on.
The LINE FEED + POWER ON will print the "Printer Character Report" or "Test Page".
May 24, 2010 | Okidata 591 Printer
How do you clear print buffer on Genicom 4440XT printer?
The buffer on the 4440XT can be cleared by powering the printer OFF and then back on again.
You may however find print jobs are held in the spooler on the computer system and will simply reprint when you turn the printer back on again, you will need to check the spooler on the system also to delete any unwanted print jobs.
Nov 17, 2009 | Tally Genicom 4440 Printer
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Model C2680 All-in-one. Have been editing/printing photos etc. work completed and PC shut down. Re-opened PC and selected WEbsite through internet. Tried to print text on PC screen. Printer kept...
its called a print JOB, and is a FEATURE, even DOS had it.
some users actually do not want to lose that job or data. so....
is a FEATURE, not a bug at all. (keeping data is job one)
watch the movie Patriot games see this is action, printing a deleted fail. shows just how this works.
you need to study how print QUEUES.
work.,
there are 2 of them, aka as BUFFERS to geeks and programmers.
one is the windows print queues.
and the other is insided the printer.
(Wbuff1) >>>> (Pbuff2) >>>>printing engine.
worst case,
if the printer say died, or ran out of ink MID STRIDE
then unplug the AC power to printer.
guess what it forgets all JOBS now. gon
but next (keep printer unplugged)
see your task bar.
no OS stated by you.
See that print ICON there, that Sir is the W10 , print buffer.
QUEUE. first in , first out queue.
if you click it you can delete any JOB (or or more)
I have 2 printers here,both HP top printers.
one has X button on top the empties the printers buffer only..
on that printer, i kill the w10 buffer job first then push X button on the printer
boom data gone. (to the BYTE BUCKet in the sky)
or as we said long ago, data fell on the floor.
that is how it works, and can be a pain.
we had printers, off say 1000' feet from users.
we had room full of 20 printers (and radial types). and magic printer server there.
killing jobs there was near impossible.
yah, run like H3LL.
the get it finished then reprint the 1 mangled page is say 100 printed.
back in the old days DOS? (even RXS-11m or uVAX, or CPM)
we unplugged the printer
then went to the dos folder for queued files and deleted them.
Btw WINDOWs STILL likes to mess up here,!
sometimes clicking the task bar, print icon then canceling the job fails.
in that case , google how to fix that. at microsoft dot com,
it's there like 1,000,000 posts.
endless for over 25 years.
ask how, can google for you , sure.
Jun 21, 2017 | HP Office Equipment & Supplies
PRINTER PROBLEM where is my hp tool box? I HAVE INSTALLED NEW INK CARTRIDGES AND NOW MY PRINTER PRINTS OUT A LOAD OF PRINT I CANT UNDERSTAND. THANKYOU
Try double-clicking on the printer in the Printers and Faxes folder and clear any pending jobs. Turn off and disconnect the power cable from the printer for a few minutes to clear its buffer. Keep the paper removed from the tray during this process and only re-insert it after the printer has stopped attempting to print. When the spooler and buffer are cleared normal printing should resume.
Nov 11, 2008 | HP Deskjet 6940 InkJet Printer
Epson Stylus  1400 InkJet Photo Printer Logo
152 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
