Question about Kettler treadmill Pacer
E1 error after start
After switching system on, in 5-6 seconds E1 error appeared on displey.
    Top Expert:
  • Kettler Master
  • 12,223 Answers
This ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display. see the diagram attached.
God bless you
Posted on Nov 28, 2013
E1 error for stamina 320
If you wish to get some details; check the site http://electro-medical.blogspot.com/. Pull up older posts. Surf the site with patience. Check for treadmill article
Feb 14, 2016 | Stamina Products Exercise & Fitness
I'm getting an E1 f5 error code and my oven won't light
The F5-E1 error code means that their is a problem with the switch on the self clean door latch...it (the switch) is telling the control board that the door is locked even though it may be open so it will not let the oven come on
GENE
Nov 14, 2011 | Whirlpool SF325 Gas Kitchen Range
E-1 & F-5 come on after about a minute when attempting to use self cleaning. the micro switches work & the solenoid has been replaced. could it be the ERC ?
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa
Oct 21, 2011 | Whirlpool GMC305PD Electric Single Oven
I have a FO-2080 fax machine and it is displaying a message system error (E1-00) and will not work at all.
Page 69 on operation manual suite Source: http://files.sharpusa.com/Downloads/ForBusiness/DocumentSystems/FaxMachines/Manuals/fax_man_FO2080_suite.pdf
Error indicator is lit or blinking.
SYSTEM ERROR [XX - XX] REFER TO USER GUIDE
When [L1-00] appears, the scan head locking switch is locked. Turn off the power, release the scan head locking switch, and turn the power back on page 13 on the manual
The machine will not function. Turn the power switch off, wait about 10 seconds, and then turn on the switch again. If this does not clear the error, remove the power cord from the outlet, and contact your SHARP service center.
Mar 08, 2011 | Computers & Internet
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
I did the self clean on my oven, and now the oven door will not unlock (E1-F5-) pops up onto the oven screen.
Hi
Error E1 F5 means that the control has detected a problem with door latch switch. Switch off the power and unplug it from the mains. Check after 5-6 minutes whether the error has disappeared. If the error is still there then once again start the self clean cycle. Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Try moving the latch manually to unlock it. hope this helps...
Daniel
Aug 28, 2010 | Kenmore 92002 / 92004 Kitchen Range
Etiger treadmill starts then after 5 secs or so cuts out and E1 error signe appears on console
Your problem is probably that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jul 19, 2009 | Exercise & Fitness
I have a whirlpool/kenmore plus range that came with our house when we purchased it. Former owners did not leave a manual for it. The numbers on it are 95779890 and serial RJ3516457. I wanted to "auto...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$TERGD
Feb 26, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning code error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&*^Y
Nov 22, 2008 | Whirlpool RBS305PD Electric Single Oven
F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
Kettler treadmill Pacer Logo
600 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven's...
Steven's...
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
