Question about Weather King 10AJA2501AH Air Conditioner
How to wire a rheem model rbhc-14j11sfa to a themostat
My system uses a permenant air filter. It's missing. It's a Ruud Model UBHC-14J11SFA. What size replacement filter can I put in this system?
You can measure what size and use any after market permanent filter. Measure the opening to the rear and across the opening. Should read as ?x?
Dec 03, 2014 | Ruud Heating & Cooling
Rheem heat pump
Model number of the inside unit is required
Jul 02, 2013 | Water Heaters
What's your problem?my furanace no heat modl no RBhc-14j11sfa
Hello, dan
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about hot waterheaters and possibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/water-heater.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Oct 18, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I need to replace my out side heat pump my air handler is steel good it is a rheem rbhc 14j11sfd what do i need
they like the name brands to match but it dosnt matter.you need to get the model and serial#s off the coil to find out what ton it is and just get the same size out side unit.
Sep 24, 2010 | Heating & Cooling
Ineed to now how many ton is a rheem model number rbhc-14jo7nfd air handle
Hello, that unit is 800cfm on High speed. One ton of cooling requires 400 cfm. Thus your unit is a 2 ton capable air handler.
May 19, 2010 | Heating & Cooling
Rheem RBHC-17J14SFA elec furnace fan won't stop
sonds like u have a bad safety switch they r round and have 2 wires on them usually and u can check them by taking the wires off of them and checking continuity thru them there might be one on the blower housing also either that or ur blower relay may be bad and stuck closed
Feb 18, 2010 | Heating & Cooling
No heat. are the elements bad? or Heat Relay
Yes, The red wires to the heat kit can be jumped to the red wires, turn off the power first and identify L1 and L2 lets call black L1 its where they connect to the power board, then pull the red wire and connect the to the power board. Also set the fan at t-stat to the On position, turn on power. use the breaker to control it.
Jan 03, 2010 | Quasar HQ2052UH Air Conditioner
Ruud Electric Furnace Cannot Reach Setpoint - "Watt Restrictor"?
unfamiliar with watt restrictors.
heat strips have 2 safety devices, a thermal overload, they get to hot they shut off, cause not enough air flow increase fan speed this device is auto reset. a fusible link a fail safe to thermal over load, no reset and sometimes replaceable. if this does not help would like to ask you a few questions. one of the buildings i take care of has 200 + reem/ ruuds all electric heat. if a part is defective replace, please do not by pass. safety frist.
Mar 02, 2009 | Ruud UBHC Air Conditioner
Weather King 10AJA2501AH Air Conditioner Logo
70 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
