Question about Metrologic Instruments Metrologic ScanPal 2 (SCANPAL2CB) Portable Terminal
ScanPal2 wont download program, getting error "Terminal Not Ready"
When I go to "Download Program" on scanpal I get an error message on terminal saying "Terminal Not Ready"
2 Suggested Answers
e-Guru
  • 3917 Answers
SOURCE: we have the metrologic scanpal 2 units and
Hi
Check that the RS232 cable is correctly connected to the host system and to the
ScanPall2 Portable Terminal or to the download cradle.
For transmission using the download cradle, check that the ScanPall2 Portable
Terminal is correctly inserted in its cradle.
Check that the communication settings of the host system match those of the
ScanPall2 Portable Terminal.
Check that the IR transceiver is correctly connected.Check that the communication settings of the host system match those of the ScanPall2 Portable Terminal.Check that the ScanPall2 Portable Terminal is correctly positioned in the IR transceiver read area (a distance of 5 cm to 100 cm, and a maximum angle of 30°).
If the problem persists, contact Technical Support.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 10, 2011
How to fix a no apps error on a t4220 terminal
No apps means the programming has been lost in the terminal.
If that is the only message you get, and can not progress to another screen you will need to load the terminal with the appropriate applications
try a quick power cycle- unplug terminal and leave unplugged for 60 seconds, replug and see if it starts to cycle the apps, if noti it needs a download.
Jun 18, 2014 | Hypercom Optimum T4220 Dual Terminal...
Runtime error abnormal program termination
Sounds like you have ran a scan on your drive and the software has become corrupt.
Download the utility from Seagate and try again
Feb 08, 2014 | Seagate Back Up Plus Desktop Drive...
Download needed no *go variable
'No *GO Variable' indicates that the terminal was unable to locate a valid Go Variable used to initialize the terminal.
Use the following to guide you through resolving this problem. Terminal Response Probable Cause Solution No *GO
Variable The terminal is not loaded with the VMAC (Verix Multi App Conductor) program used to allow the terminal to access multiple applications (File Groups). Download VMAC into the terminal. The download installed into the terminal is corrupted. Re-download the terminal. The terminal has not been downloaded. Download the terminal. The download did not authenticate correctly. Re-download the terminal. The download did not unzip into the correct location, therefore cannot be accessed. Re-download the terminal, if this is unsuccessful, verify where the file is being unzipped to.
I hope this help if not them call 775 - 358 - 2922 : - )
Nov 08, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
Verifone vx570 checksum error
Maybe you have a corrupted program/application. Call your credit processor for the download process of your application. But before downloading, don't forget to batch and settle your unit if you can. Then clear all the old program in your machine. I hope this will help you. if need more help call (775)358-2922 ask for Randy. Thanks
Jan 29, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
It says no go file
Terminal ResponseProbable CauseSolutionNo *GO
Sep 05, 2011 | VeriFone VX510
Hello! I have a problem when programing the CipherLab 8001-C Application Program (AG8000N.exe). The download start (terminal bip) and after 3-4 sec show "Download Complete" but the terminal show the...
Cipherlab has technical support available - I'd recommend getting in touch with them. The Cipherlab global site is: http://www.cipherlab.com/default.asp - you can choose your region, then support or the contact link.
Oct 19, 2010 | CIPHERLAB 8000 Series Handheld Mobile...
Getting a message about shadowing my session
The program you are using is telling the terminal to accept a VNC request, as it will send date on the port open for VNC. So the terminal is asking you to accept the prompt to allow a remote machine to control your session.
You can set the program to ignore the VNC ports, so it wont get prompted. Failing that you should be able to change the terminals behavior to the requests by editing the wnos.ini to not allow VNC connections. I think that can be done from there. Check on the config generator for wyse terminals on technicalhelp.de to find the correct syntax.
Jun 23, 2009 | WYSE S10 (90210501) Network Terminal
Error message
This means that something has gone wrong in the application software. The best thing to do is to get a reload of the application.
May 26, 2008 | VeriFone OMNI 3200 (P092-101-10) Printer
Error message
This is a software error message. This model of scanner actually holds a file set ..not just one file. it is likely you are using a program to download your inventory list or similar, and the files have been lost (usually by leaving hte battery out too long).
A SKU is another name for an item number.
It is quite unlikely this is a problem with the hardware itself.
Dec 25, 2007 | Symbol LRT3800 Portable Terminal
Metrologic Instruments Metrologic ScanPal 2 (SCANPAL2CB) Portable Terminal Logo
77 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
William Robinson
William Robinson
Sandeep Kumar
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
