Question about Acer Office Equipment & Supplies
Projector fan temp
Fan errar
Red Light flashing
it may be because of the problems as u described air filters and fan .but try first with the filter,u can find it at amazone or flipkart
May 03, 2017 | Epson Computers & Internet
I have a dell 1209s projector and the temp symbol flashes. I dont know if I need a new lamp or what? Help me? thanks
Check the lamp cooling fan of your projector. maybe its has some problem. its not running at the correct RPM. that's why the lamp get over heated and the temp lamp flashes.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
Also try to reset the lamp hour of your projector. you can see the option for reset the lamp hour in the menu. Please not one thing lamp reset is recommended only after replacing the lamp.
ok
Mar 10, 2011 | Dell 1209S DLP Projector
Purchased 2006. Ceiling mounted. Just stared overheating after approx 10 minutes after last bulb replacement in March of 2010. Floor fan pointed at projector helps. Tried cleaning. Running right side...
Yes, if bulb was low price and was installed in old lamp casing then it is bulb that is not good and creating too much heat that exhaust fan can't throw out to make projector cool enough so temp sensor activates and send over heat signal to system control chip thus projector shuts down.
Please install original lamp that comes with casing to solve this issue.
If lamp was original then check exhaust fan that might be running slowly due to stiffness in bearing so temp sensor finds over temp in projector.
Hope these info will help you.
Thanks.
Dec 18, 2010 | Optoma EP1690 DLP Projector
I get a temp warning on start up and then just shuts down only one fan seems to be working the one next to the lens dose the bottom fan only come on at certain temp. or are both fans supposed to run all...
first blow out any dust out of the projector with canned air. duat holds in heat. if the other fan is supposed to come on at first and doesn't, you would get a fan warning, not a temp warning.
Aug 02, 2009 | ASK Proxima Proxima 5800 SVGA Projector...
High temp light on when powering up
Remove the screws and check out the fan's working state.
EP759 have one big 92mm fan for the lamp, and three small, near 40mm, fan's for the optics.
Power of the bulb is very high, so just 1 broken fan can make that situation.
Apr 25, 2009 | Optoma EP759 - HDTV Compatible DLP...
BLINKING TEMP LIGHT ON HP VP6110 PROJECTOR
All projectors are cooled by the use of a fan. The light chamber has its owned fan to extract the excessive heat generated by lamp. Check to see if this fan, close to the fan is operating.
Mar 23, 2009 | HP Digital Projector Vp6110 Multimedia...
Problem with my dell 1200mp projector
if you haven't already try cleaninig the filters
Aug 22, 2008 | Dell 1100MP Multimedia Projector
Hitachi projector temp light
This is what your projector's user manual says about a flashing "TEMP" light :
"The cooling fan is not operating. Turn the power OFF and wait approximately 20 minutes. After the main unit has cooled down, please make confirmation that no foreign matter has become caught in the fan, etc. After performing any needed maintenance, turn the power ON again; if the same display is displayed, then please contact a sales store or a service company."
Your user manual is available at the following link :
http://www.hitachi.us/Apps/hitachicom/content.jsp?page=Products/SupportServices/Support/DiscontinuedModels/index.html&level=4&section=Products&parent=DiscontinuedModels&nav=left&path=jsp/hitachi/forhome/DisplayTechnologiesGroup/
May 20, 2008 | Hitachi CP-X275 Multimedia Projector
Temp/fan light
Hi...  PLZ Help For sony projector vpl-sc50m
 Temp/fan light problem,
How to Stop light.....
Urjant.....
               Reply...
Feb 27, 2007 | Sony VPL SC50 Multimedia Projector
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
