Bottom part of the screen cut off
My sony trinitron tv screen has moved down, I don't see the the figured at the bottom line. I guess I gotta go to service mode and adjust the vertical height. Please tell me the code to get to that point.
  • 2,113 Answers
If the vertical of the tv moves when it is that old that is your first warning sign. All electronics need their electrolytic capacitors replaced (especially the small ones). Not replacing them will cause a catastrophic failure. The next sign you will receive is when you have lines every half inch across your screen. Or the next sign will be losing your vertical entirely until all you have is a line. Then everything will go poof till only a standby power light will show. Pressing buttons in a secret pattern to get into the service mode will not fix failing.
Posted on Nov 27, 2013
3 Suggested Answers
techman
  • 3130 Answers
SOURCE: Sony TV - Loss of half the picture
sarge, it sounds like the vertical output IC went bad on you. If it was a bad connection or a bad capacitor, your picture would have been a straght line across the screen. They call the output section of the IC a push-pull type of amp, so the top half of the sweep IC went out. If you have had some soldering experience, and or experience with solid state repair, locating the bad IC and replacing it is no big deal. If you havent, stay safe and call in a pro to assist you in this repair, as there is alot of high voltage inside this puppy that is still present even if the set is unplugged. It should not cost an arm or a leg to repair this set. An honest repair on a set like this if you take it in should not exced 125 to 150 bucks. Good Luck PS Please dont forget to rate this thread.
Posted on Oct 22, 2006
jerryg50
  • 1689 Answers
SOURCE: Need to center the picture
This is a defect in the vertical scan amplifier. It is not an adjustment. Most of the time there are a number of capacitors in the vertical deflection amplifier that can cause this type of fault. Sometimes the output drive IC can cause this fault, but more rarely.
An experienced service tech can locate the defective parts and replace them. The average time involved is about 1 to 1.5 hours.
Jerry G.
Posted on Jun 02, 2008
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
I get a horizontal line at bottom of my 27 crt sony trinitron tv screen that bounces up and down how can i fix it myself ?
There is a 10MFD/250v (black) capacitor near the fly back transformer that would have leaked or swelled up. Replace it and those lines will disappear.
Jun 17, 2011 | Televison & Video
My 12 year old Sony Trinitron KV-32XBR200 still works pretty well except that it cuts off about 25 - 30 scan lines at the bottom of the screen when cold, then gradually improves somewhat to missing only 15...
No,tv have cold solders inside the tv like vertical IC or around the area.Have a soldering iron,a roll of solders,also know how to do basic soldering?Yes.Take the tv aparts,take a back plastic of the screw driver tabs all around the main pcb,will see the vertical changes,take out the a/c power sourced,resolders those area,will fix this problems.
Feb 10, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony lcd projection tv vertical adjustment KF-50E200A
Try changing the settings for the video formats, widescreen, regular, and all that. There are angle mirrors in the back of the tv that direct the projected image on the screen. The mirrors are positioned such that if, says, a piece of a metal bracket or something falls down inside the projection area, it'll fall right against the projection lens and block the image. Open up the back of the tv and follow the light path from the screen backwards to its source and make sure there's no debris in the projection path.
Sep 17, 2009 | Sony KF50E200 TV
Scroll captions cut off
Here is link to know the procedure how to go in to service mode in Sony TV.
Need further help, let me know.
Sep 29, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV is cutting in and out of color
My sony Trinitron TV just shows a padlock on the screan.Please help me unlock it.
Mar 16, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Jerry G.
Dec 30, 2007 | Sony FD Trinitron WEGA KV-36HS20 36" TV
My tv picture
when i switch on my tv, it works for about 10mins then it develops lines accross the screen and the picuture starts moving up and down.
Oct 28, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My tv rolls from bottom to the top
It's a bad cable connection. Move the cable wire and see if there is a difference. The bad connection can also be at the cable box outside.
Jun 29, 2007 | Sony FD Trinitron KV-28FQ75 28" TV
TV goes black at bottom and has horizonal lines in middle?
Hello, please check the high current area around flyback transformer, horizontal output transistor as well as the deflection connector for bad soldering. Best regards, Arpi If you need more info please advice.
Apr 12, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
