Question about Metra 993410 - Geo Metro/Suzuki Swift 1993-1994/Tracker/Sidekick
The dash lights are not working
My dash lights will not turn on, is their a fuse i might need to change? if so which one?
How do you fix the dash and running lights?
With what info you've given,it would not have been the light switch or the rheostat for changing dash light brighting.Since both the dash lights and running lights are not working,first thing I'd have done is replace the fuse,since both are o the same fuse.Kinda like when my Toyota wipers would stop,the overdrive stopped working too.Both were on the same fuse.Replace the fuse and good to go.I carry fuses with me.
May 12, 2014 | 2000 Nissan Frontier
Brake lights turn signal and hazzards
Turn signals are on fuse number one and brake lights are on fuse number 9. Both are in the fuse box under the dash or on the side of the dash. Both are 15amp.
Jun 22, 2013 | 1995 Ford Mustang
Dash lights out in 1987 toyota corolla
Take a test light and check all fuses.Also dash lights usually have a dimmer which could be turned off or defective.Usually if tail lights work,dash lights should as they are usually on the same fuse.
Sep 28, 2017 | Cars & Trucks
Dash board lights
Check the fuses. Under the steering wheel. If the fuse for the dash lights is blown, replace it. If it blows again, replace it again and look into what could cause the short.
The lights may also need to be changed in the dash.
The switch to turn on dash lights might be bad. If this is so, outside running lights won't work either.
Sep 07, 2011 | 1995 Eagle Talon
DOES THE DIMMER SWITCH FOR DASH LIGHTS NOT WORKING HAVE ANY THING TO DO WITH TAIL LIGHTS AND PARKING LIGHTS NOT WORKING
Automobile companies make the dash lights stop working to let you know that the tail lights are out. Usually it is just an indication that you have blown a tail light fuse. First make sure that you do not just have the dimmer turned down on the dash lights. But if the dash and tail lights are out, first check the fuse block to see if the fuse for the tail lights has blown. If you change the fuse and it blows right away you will have to start searching for electrical shorts.
Another tell is when you notice that the turn signals are flashing faster than normal. This means that one or more of your turn signal bulbs has burned out.
Jan 31, 2011 | 1994 Geo Metro
The dash lights on my 2004 Toyota Corolla are not working
try checking the fuse box for blown fuses, if all fuses are ok, then the lightbulbs behind the dash need to be changed
Mar 31, 2009 | 2004 Toyota Corolla
1994 accord, dash and tail lights wont work
chk. headlight switch, my guess thats what it is.
Jan 25, 2009 | 1999 Honda Accord
Tail lights and dash lights not working
there are a few fuses under the hood be sure to check fuses again at dash they could look good but not be and if one was blown it could have blown as soon as you turned them on again that would indicate a short. it could be the switch also if it is the pull type try pulling it slowly to see if they come on and turning it like to dim the dash lights. if that makes them come on you need a new switch sometimes it will work sometimes not
Dec 23, 2008 | 1992 Mercury Cougar
Metra 993410 - Geo Metro/Suzuki Swift 1993-1994/Tracker/Sidekick Logo
Top Metra Audio Players & Recorders Experts
 Mikey
Mikey
ray gallant
Tim Rickards
Tim Rickards
Are you a Metra Audio Player and Recorder Expert? Answer questions, earn points and help others
