Question about Husqvarna Chain Saw 20" Bar
Husqvarna chainsaw runs then just quits why - Husqvarna Chain Saw 20" Bar
  • Dustin Burrell
    Dustin Burrell May 08, 2014
    Hi doug ross, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
#1 Taper
  • 1041 Answers
SOURCE: Husqvarna 345 chainsaw runs when using starting
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner.Makesure the small screen is free of debris. (Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
SOURCE: 350 chainsaw will not start and run, getting fuel
check set screws on the side of carb turn the all the way in the turn out till idles or check the screen in the muffler
Posted on Feb 04, 2010
dontbother10
  • 2220 Answers
SOURCE: my Chainsaw Husqvarna 345, won't start. With
I hope 2 different problems Marvin. I think the starter is most important, after you reply with findings we will take on the likely fuel delivery problem. Please do this and post back (below) with what you find.
Starter Handle difficult to pull:
1. Remove the starter cover. Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if not repair the starter.
2. Is the saw equipped with a decompression valve? Yes continue, no proceed with 3.
· Leave the ignition off, set the valve and pull the starter.
· Pull gently to release the valve. Is there a difference in the effort required?
· If yes continue with 3, if no repair or replace the decompression valve.
3. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including but not limited to; leaky intake connections at the engine or carburetor; leaky crankcase seals; cracked fuel delivery lines; running on gasoline containing no 2-cycle oil.
· Disconnect the spark plug wire and remove the plug. Remove the muffler (clean it and the spark arrestor before reinstalling), hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Please Note: Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
4. The last likely possibility is the saw has jumped timing. Inspect the flywheel and crankshaft under the starter cover. Are the woodruff key slots aligned and the key intact? Please take it to a good local saw seller/mechanic for a written diagnosis before authorizing any repair.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Starter fluid removes what little lubrication is provided by the fuel mix. I suggest a teaspoon of mix into open carburetor throat or the plug hole. Do not go to speed with the air filter removed.
Posted on Mar 29, 2010
Testimonial: "I think this is excellent advice. Thankyou very much"
  • 4088 Answers
SOURCE: husqvarna 235e will not stay running
Take the saw back for warranty service. We have a Husky #435 that had starting problems when new last year--warranty service replaced the ignition module the first trip, then a little later, they replaced the carburetor--it has worked very well since. I suspect that Husqvarna has had problems with our ethanol blended fuels. Hope this helps!
Posted on Jul 14, 2010
  • 4348 Answers
SOURCE: Husqvarna Model 136 chainsaw will only run for a
Take apart the fueling system and carb. Something is blocking or gummed up. One thing that sometimes works is to remove air filter, rev the unit up, and place hand fully over the intake, and remove before unit stalls. This sometimes will clear the blockage.
Posted on Oct 05, 2010
Husqvarna 359 chainssaw vent for gas tank ?
Venting issues are not common on these saws in my experience. could be a cracked fuel hose. check for scoring on cylinder. may be loosing compression.
Aug 31, 2014 | Husqvarna Garden
Huaqvarna chainsaw 240 runs then quits
when ??? dies at wide open throttle ??? dies at idle ??? dies it restart right away or take an hour or more ??? did you put the right 2 cycle mix in the gas tank ???
Nov 27, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
445 HUSQVANA SAW QUITS
Sounds like fuel starvation, always start with simple things first, replace the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of leaking.
Jan 18, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna chainsaw 41(1994-05) is what the model number is showing the carb has been rebiult new gasgets it has fire but will not run can u help
The 41 was quite prone to blowing the crank seal on the flywheel side, remove the flywheel and check, at the same time check the flywheel key has not sheared, behind the carb fixing plate is a rubber induction tube, make sure this has not split, als check the impulse seal underneath the induction tube.
May 19, 2011 | Husqvarna Garden
Husqvarna 350 has spark and fuel wont start just quit running while in use
1- Is the mix (gas & oil) right? If its 2-cycle,check the manual.
2- Is the choke set?
hope this helps
Jan 06, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Husqvarna Model 136 chainsaw will only run for a short time with choke closed. Engine quits shortly after choke is opened.
Oct 05, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 235e will not stay running
Jul 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a husqvarna 345 run about 4 min then stops
Do you have to wait awhile before it restarts? If so may need new coil.
Mar 19, 2009 | Husqvarna Garden
Husqvarna Chain Saw 20" Bar Logo
42 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
