Question about Bosch HDI7282 Dual Fuel (Electric and Gas) Kitchen Range
Need maximum (gas) input rating of range
Need max (gas) input rating of Bosch range model # HD17282U to correctly size the flexible gas supply line.
Thanks,
Jerry
2 Suggested Answers
  • 207 Answers
SOURCE: We just bought a Bosch gas range HGS5053UC. The
It is possible. There are a variety of replacement knobs. THere's two websites that you should check out. One is partsdirect.com. Go there with your make and model and it will walk you through the rest. The other would be Bosch's site itself.
Posted on Jan 25, 2011
What is the maximum outboard hp recommended for a 1989 18' Sunbird center console.
There should be a Coast Guard registration plate that recommends a maximum horse power rating for that boat. If there is none, the rating in the range of 200 to 300 HP is enough. IF you are sure of the length 300 HP is pushing it.
Jan 27, 2017 | HP Boating
Converting Bosch HDI7282U/09 back to natural gas / orifice sizes?
they are set sizes and you need to change the air shrouds as well to get proper burn
this is a job for an accredited gas fitter so call one in and he will
have the correct jets and be able to adjust the air shrouds as well
Nov 10, 2015 | Bosch Kitchen Ranges
Tire pressure
I would look on the side of the tire to see what the max P.S.I. is and inflate
it to that point, but NO higher. Max PSI is determined by the size of the tire and ply rating. By inflating it to the maximum you will be able to roll it around much easier than if it was under inflated.
Mar 19, 2012 | Briggs & Stratton Briggs Stratton 6200...
Water temp flucuates from hot to cold, esspedially on very rainy days.
Gas water heater problem based on weather could imply atmospheric interference, which might indicate venting problem. Check vent specs for that model. Make sure roof or side wall vent are installed correctly, and lenghts do not exceed maximum.
Problem might also be associated with elevation setting, since water heaters are sold to match expected conditions at that elevation.
If rain is associated with cooler temperatures, and more gas appliances run at same time, then unit might be starved for gas or home does not have enough ventilation.
Problem could also indicate that tankless unit needs to catch up on yearly maintenance, including clean burner and combustion parts, check loose wiring, test ignition system, clean air intake, bleed gas line, check gas pressure and check for correct vent, etc.
Before calling service technician, open following link for Bosch troubleshooting resources including Bosch contact, typical manuals, etc.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Aug 09, 2011 | Bosch GWH 425 EF L Water Heater
My paloma tankless gas has a error code c2 11 c4 12 why
Open following link for useful troubleshooting information:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error code 11 is 'No ignition'
http://waterheatertimer.org/pdf/Paloma-Tankless-Error-Codes.pdf
Ensure you have gas to the appliance.
Ensure gas type and pressure are correct.
Bleed all air from gas lines.
Ensure gas line, meter, and regulator are sized properly.
Ensure appliance is properly grounded.
Check gas solenoid valves for open or short circuits.
Ensure igniter is operational.
Check igniter wiring harness for damage.
Error code 12 is 'Flame Failure'
Ensure flame rod wire is connected.
Check flame rod for carbon build-up.
Check power supply for loose connections.
Check power supply for proper voltage and voltage drops.
Disconnect remote control.
Disconnect and re-connect all wiring harnesses on unit and PC board.
Ensure proper venting material was installed.
Ensure condensation collar was installed properly.
Ensure maximum vertical vent length does not exceed allowable limits.
Ensure maximimum horizontal vent length does not exceed allowable limits.
Range of causes are part failure, gas pressure loss, air in gas line, improper installation of gas line or vent, 120V power to unit is disrupted or unit not grounded, circuit problems, venting problems, remote control, wiring to PC board, board failure, carbon build-up on flame rod, short circuits on gas valve solenoids.
The fact that you have error code tends to eliminate your plumbing as culprit, the error code does not mention air supply, otherwise it looks like every possible cause is on the table.
Add a comment with your experience so other with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 25, 2011 | Rheem Tankless Hot Water Heater...
I have a Maytag performa poropane dryer. It states the input rating at18000 btu per hour. I have a 5/8 inch OD flexible gas line at 48inches long it is rated for 75001 to106000 btu/hr . Is this the right...
Hi and welcome to FixYa, I am Kelly.
There is nothing wrong with using a larger flexible gas line than is required. We used the 5/8 OD lines most of the time as they were much more durable than the smaller ones. The line you have is fine.
Thanks for choosing FixYa,
Kelly
Feb 09, 2011 | Maytag Dryers
I have a galaxy gas range says it is set up for gas or propane how do i switch it and is it expensive
The cost of the parts is low. Many ranges have the conversion kit attached to the back of the unit. (If installed, pull the range away from the wall and then check the back. Another likely spot is behind the storage drawer.) If the parts aren't provided, then check your manual for information on ordering the conversion kit. (At least one range I've researched had a price under $20 for the conversion kit.)
The biggest cost is to get a licensed installer to do the conversion. This is required to maintain the warranty. It is also required by law in some states. Talk to your gas company (most appliance shops do not have staff that handle propane conversions).
The instructions are included with the conversion kit. It's fairly simple and takes a screwdriver, wrench and ratchet with correct sized socket (mine took a 10mm). A nutdriver can be helpful. Check your instructions for any other tools you need. With the stove unplugged and disconnected from the gas supply, turn over the LP/NG part in the regulator (do not remove the entire regulator). Adjust the air flow damper. Remove the current orifices for both the range and the stovetop. For best results do these one at a time (the orifices are labeled and are for specific locations). In the oven, you need to remove a few covers to reach the various dampers and orifices.
Then connect the stove back to the incoming gas line and power supply (use a new flexible gas line for the connection to the regulator). Check for leaks. Then you may need to adjust the flame for each of the inlets. The stovetop burners usually have a set screw behind the knob so turn on the flame and then remove the knob. The set screw takes a very small screwdriver.
I hope this helps.
(please note I did this from memory after reading the directions on the new stove we had delivered about 2 months ago. That was an LG stove so some differences in the instructions are inevitable.)
Aug 25, 2010 | Sears 61301 Gas Kitchen Range
I have a residential gas service from PG&E. What is my maximum heater size? PG&E said the maximum output is 250,000 btus. I have a 90,000 range and a 50,000 btu hot water heater. Does that mean my...
I take it we are talking gas meters here , if so meters only pass so much gas, to there size so 250,000 is the max it will pass for that size meter if you need more you can have a bigger meter fitted , but this would cost you i would think ,so yes 110,000 is what you have left in btus on that size meter
Jul 31, 2010 | Williams 3003622 Ceramic Wall Mounted...
I HAVE A AMANA FULL CAPACITY 7.1 DRYER THAT NEEDS A FITTING THAT HOOKS ON THE BACK OF THE DRYER INTO THE GAS LINE
If you are talking about the adapter between the flexible gas line and your dryer, your local hardware store will have it. I usually recommend that you take your flexible gas line with you so they can match up the correct size. The dryer gas pipe is standard. Good Luck, Appliance Specialists
Jan 04, 2010 | Amana ALG331RAW Gas Dryer
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch HDI7282 Dual Fuel (Electric and Gas) Kitchen Range Logo
353 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
