Question about Sony Cyber-Shot DSC-F828 Digital Camera
Praktica DCZ 8.3
REMOVE LENS
Camera wont switch on praktica dcz 8 lm busy light comes on 3 seconds then off and nothing after that
took the memory card out and then turn on the camera. Now see the busy keep coming or its gone. If not showing busy any more then format the memory card and then try to turn on the camera with inserting the memory card. Thanks.
May 23, 2012 | Praktica SlimPix Digital Camera
I CANNOT FIND THE INSTRUCTION MANUAL FOR THE PRAKTICA DCZ 8LM CAMERA
Hello
OK, at the l;ink below you will be able to download the manual in PDF format free of charge.
Click HERE to navigate to download page.
Fell free to contact me if you need any further assistance.
Kind regards
Andrea
Sep 25, 2010 | Praktica DCZ Digital Camera
Lens error 15 and 25
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 14, 2010 | Praktica DCZ 5.4 Digital Camera
Praktica dcz instruction manual
0e94afd.jpg May be this will help a little bit. Manual can not be found.
Jan 29, 2010 | Praktica DCZ Digital Camera
Praktica dcz 8lm camera: when turned on the light comes on for a second then goes straight back off again. won't take pictures or allow you to view pictures on pc
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 13, 2009 | Praktica DCZ Digital Camera
Transferring photos from camera to PC
I clicked through and found a mode on camera that I hadnt seen before
and it worked after that thanks.
Jul 12, 2008 | Praktica SlimPix Digital Camera
Sony Cyber-Shot DSC-F828 Digital Camera Logo
20 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
