Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Huaqvarna chainsaw 240 runs then quits - Husqvarna "Chain Saw - 16" Bar, 3 Hp
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
When ??? dies at wide open throttle ??? dies at idle ??? dies it restart right away or take an hour or more ??? did you put the right 2 cycle mix in the gas tank ???
Posted on Nov 28, 2013
How to replace gas vent on huaqvarna 51 chainsaw
Disassembly
The fuel tank vent is located on the right side of the fuel
tank next to the right rear rubber element. With the fuel
tank empty and the fuel hose disconnected at the
carburetor, remove the two rear rubber elements. Separate the rear of the crankcase and the fuel tank enough to expose the fuel tank vent. Working through the fuel filler opening, grasp the fuel tank vent tube with a pair of needle nose pliers. Push the vent out the other side.
For access to the right side rubber elements, first remove the chain brake cover, bar, chain, chain catcher and cover plate.
For access to the left side rubber elements, remove the starter housing.
Assembly
Install the fuel tank vent using a drift the same diameter
as the vent tube. The remainder of assembly is the
reverse of disassembly.
Nov 07, 2014 | Garden
My chainsaw starts and runs but the chain won't turn so it shuts itself off. What am I doing wrong?
Check the braking bar. You usually start the chainsaw with the brake in the 'on' as a safety feature. You have to release the brake before powering up the chain, otherwise you are fighting against the brake and the engine will shut down. Hope this helps.
Jul 09, 2014 | Garden
HOW AND WHERE TO ADJUST THE OILER ON THE 240 HUSQVARNA
The Husqvarna 240 does not have an adjustable oiler. Always use good quality bar and chain lube, never motor oil.
Jun 14, 2014 | Husqvarna Garden
What Size File for a Husqvarna 240 Chain?
The 240 runs standard a 3/8 " pitch H36 low profile chain. The proper size file is 5/32" (4.0 mm)
Jun 09, 2014 | Husqvarna Chain Saw 20" Bar
Husqvarna 235 chainsaw wont run
Check fuel supply, proper plug (resistor) compression 120 to 145 lbs. If saw will not run have the ignition tested with a 3-point spark tester.
Apr 30, 2014 | Husqvarna 232 235 240 Cylinder Pn...
Chainsaw chain keeps running
This is a carb adjustment issue and needs to be rectified before using it again, the L jet on the carb is set too lean, if you cannot correct yourself i would suggest taking it to the local chainsaw shop.
Jan 19, 2014 | Husky Garden
Homelite 240 20" oil blowing out exhaust
Your machine need s a complete overhaul.Gas & oil out of exhaust is problably due to wear piston rig and camshaft.
Oct 25, 2011 | Garden
What to hook the two hot wires up to for 240 volt use of a quad ballast on a 400W metal halide fixture? Common and 240?
Hooking one side to common (neutral) will give you only 120 volts. You need to hook to a double ganged breaker which will supply the needed 240 volts. Be sure to run a ground wire to the metal frame of the light from the ground bar in the service panel. Hope this helps!
Nov 09, 2010 | Garden
Homelite 240 will not continue running
Check the fuel filter stone in fuel tank. Replace it with new one.
Apr 21, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
151 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
