Question about Xerox Phaser 3100MFP/S Laser Printer
Printer error fuser temp
Printer does not initialize
    Novelist:
  • Xerox Expert
  • 107 Answers
You can find answers to Xerox questions at www.xerox.com/support
Solutions for : Printer Error Fuser Temp Message There are two configuration options available for this model; the Phaser 3100MFP/X and the Phaser 3100MFP/S. Fax features are only available on the Phaser 3100MFP/X. To determine the configuration of your machine, print a Configuration Page. See the Related Items below for additional information.
Solutions ranked by relevance:
  1. Make Sure the Power Cord is Securely Connected to the Machine and the Electrical Outlet
  2. Make Sure the Machine is Plugged Into a Functional and Stable Power Outlet Test the power outlet that the machine is plugged in to by connecting another device to the outlet. Make sure the outlet is functional and stable. If possible, have the line tested by an electrician. If necessary, plug the machine into another power outlet.
    NOTE: The machine should be plugged directly into the wall outlet, and should not be connected to an extension cord, power strip, or Uninterruptible Power Supply (UPS).
  3. Reset the Fuser Error Solution : Reset the Fuser Error CAUTION: The following solution will put the printer in the Diagnostics mode and is only valid for this problem. Follow the steps carefully; any deviation from the process can cause other settings to be changed and / or render the machine inoperable.
    If at any time it is necessary to cancel the procedure and start again with step 1, press the [Stop] button four times.
    NOTE: This procedure will delete all pending jobs that have been sent to the machine.
    To reset the Fuser error:
    (Click on one of the following links to jump to the corresponding section.)
    To reset the Fuser error for the Phaser 3100MFP / X
    1. Press the [Down] arrow (Menu) button on the Control Panel.
    2. Press the asterisk [*] button.
    3. Press the pound [#] button.
    4. Press the [OK] button.
    5. Press the [1] button. ("00100001" changes to "10100001" at SOS1)
    6. Press the [OK] button.
    7. Press the [Stop] button.
    8. Press the [Down] arrow (Menu) button.
    9. Press the pound [#] button.
    10. Press the [T] button on the keyboard. (Do not use the numeric keypad.)
    11. Press the [OK] button.
    12. Power the machine off, and then power the machine on.
    13. Press the [Down] arrow (Menu) button.
    14. Press the asterisk [*] button.
    15. Press the pound [#] button.
    16. Press the [OK] button.
    17. Press the zero [0] button. ("10100001" changes back to "00100001" at SOS1)
    18. Press the [OK] button.
    19. Press the [Stop] button.
    20. Make a copy to check machine operation.
    To reset the Fuser error for the Phaser 3100MFP / S
    10. Press the [Down] arrow (Menu) button until "T>>Printer" is selected.
Posted on Nov 30, 2013
4 Suggested Answers
  • 208 Answers
SOURCE: Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Posted on Dec 03, 2007
  • 191 Answers
SOURCE: i own a Xerox Phaser 3100MFP and it keeps giving
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
Posted on Sep 22, 2009
SOURCE: Printer Error Fuser Temp. in xerox 3100mfp
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
Posted on Jul 04, 2010
I have an HP clj 4025 with a 50.2 fuser error when I put in a new fuser. I ordered another fuser and get the same error. There is a clicking sound on initialization.
There have been problems with the fuser drive failing. You cannot see the damage without taking the printer apart. There are two different fuser drives, one for duplexing machines and one for simplex machines.
Sep 22, 2016 | HP Color LaserJet Enterprise CP4025dn ...
Error fuser temp
replace the fuser unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 09, 2014 | Konica Minolta PagePro 1390MF All-In-One...
LET'S START
PREES- MENU BUTTON
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
OK BUTTON
Mar 12, 2010 | Xerox Phaser 3100MFP/S Laser Printer
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Mar 09, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Fuser error 50.1
turn off printer and unplug it.
remove the fuser
wait 20 minutes
reinstall fuser
insert power cord, power on.
wait for it to initialize.
If error comes back...you've got a bad fuser or power supply
Jan 27, 2010 | HP LaserJet 2840 Printer
Fuser temperature error for xerox 3100mfp
kindly check externally the fuser is heating or not. i SUSPECT THE FUSER MIGHT BE FAILED.
Nov 16, 2009 | Xerox Phaser 8400 Laser Printer
I own a Xerox Phaser 3100MFP and it keeps giving me an error message saying "Printer error Fuser temp"...Help
Sep 22, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Xerox Phaser 3100 Printer Error Fuser Temp.
fuser Temp printer error problem.please give me the solution.
Sep 14, 2009 | Xerox Phaser 6120/YN Laser Printer
Printer error, fuser temp
It is giving me an error message of "printer error,fuser temp"
Jun 24, 2009 | Gestetner DSm415f All-In-One Laser Printer
U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Oct 03, 2008 | Office Equipment & Supplies
Xerox Phaser 3100MFP/S Laser Printer Logo
213 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
