Question about RCA DRC247N DVD Player
Has stopped Dubbing onto discs
The Dubbing facility has worked faultlessly for years but now begins the dub but does not complete it
    New Friend:
  • 46 Answers
Try spraying it with pressurized air. Perhaps it needs to be cleaned internally.
Posted on Nov 27, 2013
Testimonial: "I tried this but the fault has remained. Time for a new replacement I think. Thanks for taking the time to help me, it's very much appreciated."
I would like to make a copy from my video tape to a DVD How do I do it?
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. Remotes.com often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
BTW: the manual is available here: http://www.managemylife.com/mmh/owner_manuals/26967/SANSUI-DVD-VCR-Combo-L0311311?brand_name_search=sansui+VRDVD4005 .
I hope this helps.
Nov 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Can't select simple dubbing...
What type of disc are you trying to record onto?
Jun 17, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Recorded onto my lg rh397d/rh399d, want to copy to dvd
You need to read page 37 "Dubbing a title"
Select the title you want to record and select the Dubbing option.
Apr 06, 2009 | LG Televison & Video
HDD>DVD dubbing.....stopping, creating coasters
Still unable to find a solution for this problem. No response from JVC on their product either.
Jun 25, 2008 | JVC SR-DVM600
Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Dr-mh30s. stops dubbing after a few minutes.
I seem to have sorted this problem for me simply by unplugging power.
I actually left it for nearly a week before plugging in again, but I'm sure a day would do, probably less.
Dubbed 2 playlists since, no problem.
Nice simple solution if it works.
Feb 22, 2008 | JVC DR-MH30S DVD Recorder
DVD problem
I've had the same problem. Are you using x8 DVD-R? I had no problems with the old x4 discs, but had the (long) Self Check process and a failed dubbing occur between 1/100 and 2/100 in the dubbing process with the x8 discs. I've found two workarounds: 1) The problem doesn't seem to occur if the recordings are made with hi-speed dubbing enabled. I do this now as a default, but the loss of the ws tag is a pain . If I still get a dubbing failure with hi-speed dubbing, a quick power down/power on of the unit seems to rectify the situation. 2) If you record a "leader" in hi-speed dub mode of a minute or two, and dub it onto a x8 DVD-R first, you can then copy non-hi-speed dub recordings onto the disc. Not quite sure why this works, but it does - it's like the first minute or two being dubbed over needs to be hi-speed enabled to be written from the memory of the E-85 to the disc, but once that's done it dubs as it should. btw, another process that crashes the unit is if you try an change the thumbnails on a x8 DVD-R. Not the end of the world but again annoying on expensive equipment less than two years' old. DVD-RAMs are not affected by the problem in my experience. Apparently there's some firmware in the US that addresses the problem with x8 discs - http://www2.panasonic.com/webapp/wcs/stores/servlet/vDownloads?storeId=15001&langId=-1&page=DVDFirmware , but Panasonic UK don't distribute it. I think the E-85 is a good box but it has proven too buggy and I'm thinking of upgrading it, possibly when the new 85 is released by Panasonic in a few weeks. Good luck
May 14, 2006 | Panasonic DMR-E85H DVD Recorder
RCA DRC247N DVD Player Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
