Question about Building Materials
Repairing hanstone quartz countertops
I have a Hanstone counter top with a chip on the edge that I want repaired: how and where ?
    Problem Solver:
  • 6 Answers
Most granite shops will be able to repair with an epoxy filler.
It is probably something you would not want to do yourself
Posted on May 19, 2014
Took the finish off a 9x12 area of my countertop. It is dull rough feeling. How to I restore that portion of the countertop? Thank you.
if it is a formica or other type of top finish then I suspect that you have damaged the plastic surface of the counter top
I would seek the advice of a shop that makes and supplies counter tops but I suspect that you will need a new top
Jul 04, 2015 | Cars & Trucks
Counter top
electric or gas?
  1. Turn off gas supply - look for a valve in the cupboard under the unit - I had to trace my valve under the kitchen in the basement.
  2. Unplug electric ignition (or flip off circuit breaker if it's electric powered it'll probably have a dedicated circuit)
  3. you can now try turning on a burner - no sparks, sounds or heat, but you may smell a little gas. make sure you can't hear the gas when you turn the knob off and back on again.
  4. remove all grids and burner tops - let's make it as light as possible!
  5. The unit has a metal box casing, about 2" smaller on each side than the top itself. (quick sketch attached). The edges are not finished or smooth, so you might want to have a couple of strips of cardboard (or plywood scraps, or even an old towel) on hand to protect the counter surface when rest the unit on the countertop
  6. Try pushing a putty knife about an inch under the edge of the stovetop and running it around to free it from any "sticky" food etc. that may make it difficult to lift. I used on old serving spoon to lift the edge and get my (gloved) fingers under the edge. A cat's paw or an old chisel works too. My top weighs around 20 lbs. so if it feels "heavy", look for an obstruction.
  7. the whole top can lifted up but...
  8. when you lift it, don't pull up too far - just enough (6-8 inches) to slide it a little to one side so that the base of the unit can rest on the edge of the cutout. This way you don't pull on the gas line (probably a flex pipe).
  9. now you can see how to release the top from its casing. On
  10. my unit, there are 3/4 inch phillips head screws about an inch below the unit's top.
  11. just be careful when moving the unit while it's resting on your counter top - you don't want to leave scratches in the granite OWHY to show after the repair.
GOOD LUCK!
Dec 21, 2013 | Bosch Kitchen Ranges
We have a Bosch SHE45M06UC/50 in an island with a granite countertop. It is not attached and so moves. How do we attach it to the granite countertop? Or how do we attach it????
You glue on a wood strip, to the underside of the counter, then screw into that. Use construction adhesive. The wood strip needs to stick down no further than the counter edge treatment, so you normally cannot see this wood strip.
May 11, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
What is the solution to fixing small chips in my new granite countertop? The granite countertop was just installed a month ago and the company has not not responded to my letter about the chips in the...
Try using super glue, the thinner the better the adhesion. Once it is dry hold a single edge razor blade (use extreme caution, razors by nature are very sharp) perpendicular to the surface of the stone and scrape the glue flush, changing blades regularly. Do not use the blade to cut, as it will dig in and pull glue and possibly stone out, as you have discovered. Just take your time and scrape the glue until it is flush with the granite. If the spots are dull, you can use a little carnuba wax (automotive/hardware store) to shine it up. Some types of granite have more texture due to differences in the makeup of the stone which also gives the variety of color. I have filled entire countertops with this method, and it is tedious, but yields good results.
Feel free to contact me with any questions. Brandon Wiese
Dec 26, 2010 | Stone TOP ONLY: 21 in Black Granite Vanity...
My glass cooktop has a chip on the top edge. Is there something I could fill in the chip with?
most hardware stores and some parts stores sell a special bake lite enamel paint the repair chips and cracks with on appliances
Jan 20, 2010 | Kitchen Ranges
I need to refinish/paint old formica countertops/doors
Paint on kitchen countertops is a receipe for trouble. Any wear, hot utensils etc will constantly damage it and contaminate you food..
You could peel off the old formica® or install a new layer over it. The home supply stores can give more information on doing this. Some of the newer counter top coverings are now manufactured so the seam where the top joins the side does not show. Doors can be replaced/painted.
May 04, 2009 | Kitchen Ranges
Small chip in granite countertop
Well you should seal your granite counter at least once every two years because granite is pourus. Theres something called Granite Guard you can use to seal your counters and other different sealers as well. You can pick some up at your local home and garden supply store.
Apr 02, 2009 | Stone TOP ONLY: 21 in Black Granite Vanity...
Building Materials Logo
651 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
