Question about HP Photosmart C6180 All-In-One InkJet Printer
Cannont print normally, I have to choose everytime "ordinary paper" on the printer properties before printing....the automatic position doesn't work, I can copy, fax without problems, the only matter is printing and as everytime I have tochoose ordinary paper, I cannot do any maintenance, the printer doesn't accept the paper....what to do before changing? thank you
  • HP Expert
  • 393 Answers
From the start menu go to printers and faxes select the printer by right clicking and go to print pref and select the paper type it wants
Posted on Nov 27, 2013
4 Suggested Answers
  • 624 Answers
SOURCE: Error Message "Page too Complex"
Hi Sccfire, This apparently is a fairly common problem with the 2800 series printer and associated with connection to a PC using USB. It can only be overcome by manually configuring the printer?s USB port to work in standard mode rather than at high-speed USB2.0 mode which probably won?t be to much of a problem. Here is a link from a support page on HP?s site that should walk you through the process: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00506095 Let us know how it goes and please don?t forget to rate the posting.
Posted on Jan 05, 2007
jackboy
  • 2985 Answers
SOURCE: hp psc 1210 vista issue: properties
Have you got the Vista driver installed.?
Vista has many driver problems and manufactuers are not addressing them
Go to HP site for a Vista driver download,
or go to www,fixyourownprinter.com/forums and put this problem there
Posted on Aug 20, 2008
SOURCE: My printer won't print from the computer command; it will print fax or copy a paper.
MY PRINTER WONT PRINT FROM THE COMPUTER. IT WILL COPY A PAPER, BUT NOTHING FROM THE COMPUTER COMMAND.
Posted on Nov 11, 2008
I cannot print my documents, everytime I click the printer "print spooler is not running". I already restart my printer as well as my computer. And I also tried to reinstall my printer but it doesn
Click Start.
Type services.msc in the start search box and press enter.
Right click on print spooler and click on properties.
Check if the startup type is automatic. If it is not then change it to automatic.
Check if the service status is stopped.
If yes then click on the start button.
Try to add a printer and print a test page.
If you need any technical help on printer then you can reach at here
Jan 25, 2013 | Office Equipment & Supplies
My Deskjet 970cxi printer is now using too much ink (which does not dry) when printing photos on premium photo paper. the results on ordinary paper are much better. How can I rectify this Ian
When you give a photo print, the print quality will be high.
To adjust this go to Printer properties.
1) Go to control panel
2) Open Printers and Faxes.
3) Right Click on Printers.
4) Select Printer Properties.
5) Select Printing Preferences, and choose quality of photo print to medium
Dec 03, 2010 | HP DeskJet 970cxi InkJet Printer
How do I print on both sides of the sheet?
If you print to an IS networked printer the printer will automatically print on both sides of the paper (duplex). This saves paper but, because it is print toner which is the largest part of the cost, charges are the same as printing on two sheets of paper.
If you wish to print duplex to another printer (NB not all printers support duplex printing) you must:
Office 2007
  • Open your Office Document
  • Click on the Office button in the top left corner of the screen officebutton.gif
  • Click Print and select one of the printers that will perform duplex printing
  • Click on the Properties button under the Layout tab
  • Choose either Flip on Long Edge or Flip on Short Edge and click on OK If your page is set up as Portrait
  • Choose Long Edge If your page is set up as Landscape
  • Choose Short Edge . Click on OK again to send your work to the printer
Other Applications
  • Go to File and Print
  • Select one of the printers that will perform duplex printing
  • Choose Long Edge if your page is set up as Landscape
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 02, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Hi I have HP PSC1610 printer-copier-scanner. 90% of all my printing I do in "FastDraft" Paper Quality. The default is in "Normal" Paper Quality and I have to change the settings each time I print. I would...
When you print from the Microsoft Word and while printing you change the Printer Properties and Print Quality to FastDraft
Everytime you close the window the setting gets reset and again when you start, you have to do the settings.
The Solution you are looking out is
Go to Start >> Control Panel >> Printer and Faxes
There you choose the your Default Printer HP 1610 >> Right Click
and Click Properties
Then you choose Printing Preferences and Make Choose FastDraft
This setting will remain as your default setting now
So whne you have to Print Normal Mode
You need to change the Properties from Microsoft Word.
and it will reset everytime you close MS Word.
Cause your Default setting then is "FastDraft"
I hope this solves your problem
all the best
Jan 02, 2009 | HP PSC 1610 All-In-One InkJet Printer
Ink not dry and significant smudging
there r various modes in the printer in which u have to print .and that u have to select.as you said it is printing properly on ordinary paper.the printer is perfect.the photo paper have less soaking power that ordinary paper.as the photo paper can consume ink but not so quickly as ordinary paper.
u just change that printmode and then check out how it prints.
for example the modes r ----------best mode printing.
better mode printing.
fine mode printing
normal mode printing.
draft mode printing
economy mode printing.
now i f u print in best mode it will consume lots of ink but will take lots of time to print.
if u select normal mode it will consume less ink and print quickly.
u can change the settings in printer properties.
thanks
Nov 14, 2008 | Canon MP610 Photo All-In-One Printer
Canon Color ImageRunner - Tab Instructions
To be able to print using tab paper from the driver
Since the tab paper can only be fed from Stack Bypass, single reverse tab paper cannot be
used. The tab paper must be single forward.
1. Go to the printer and put some tab paper in Stack Bypass
2. Press Letter on C3200 LCD panel and press Next
3. Select Tab paper and press Done
4. Go to Windows Start menu and choose Settings
5. Open Printers folder
6. Select Canon iR C3200 PS3’s Properties
7. Click on Device Settings tab
8. Click on Form to Tray Assignment button
9. Making sure that Stack Bypass is highlighted and Paper Size is Letter, select
Tab Paper by scrolling down the Paper Type list
Page 2
Hint:
In order to print to Tab paper, it is necessary to select Tab Paper in the Form to Tray
Assignment dialog box before using this option. Otherwise, the option of printing to Tab paper
is not available from the print driver.
10. Click OK to close Form to Tray Assignment
11. Click OK to close Properties window
12. Open Word document called “tabs.doc”
13. Go to File menu and select “Print…”, and change the current printer to Canon
iR C3200 PS3.
14. Click on Properties
15. Click on Paper Source tab.
16. Select Paper Type option
17. Choose Tab Paper from Paper Type list. As soon as you select “Tab Paper”,
Conflict Information dialog will appear. Click on OK.
Page 3
Hint:
In order to change the tab position, click on Tab Position button. Clicking this button opens a
dialog box for specifying the width for shifting the image data to be printed on the tab part of
the paper.
Hint:
The conflict information displayed pertains to the finishing of the document. Tab paper must
be grouped, not collated. Since the default value for finishing is Collate, the driver
automatically adjusted the finishing option to resolve the conflict.
18. Click on OK to close the Properties window.
19. Click on OK to print the tab paper.
20. Go retrieve your output.
Note:
Please note that this procedure for printing on tab paper is not the same for all drivers. CCD
drivers would be similar to this procedure, but depending on the OS Platform, exact buttons
and steps would vary. However, from such drivers as imagePASS-C1 PS and Macintosh drivers
would work completely different from this procedure. Although we will not cover each
procedure step by step, we encourage you to take time to make yourself familiar with the
procedures.
Sep 30, 2008 | Canon imageRUNNER C3200 Color Printer
Hp 2605dn - choosing the correct paper tray
Open up your control panel, then your printers, then open up your HP 2605dn by right clicking it and choosing the 'properties' option. Next, look for device settings and specify there what is in each tray. That should enable you to just print to the printer and have it automatically pick the right paper.
Have fun!
May 22, 2008 | HP LaserJet 2605dn Printer
Two-sided printing
On a PC...
- Ctrl + p to print
- Choose the Canon MP530 if it's not already selected
- Click Properties button
- Page Setup tab
- Select Duplex Printing
My paper always gets jammed, so I always uncheck the Automatic checkbox. Hopefully you won't have to do that.
Good luck.
Nov 13, 2007 | Canon PIXMA MP530 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
53 people viewed this question
Seeker5211
Seeker5211
