Question about Epson PowerLite® 83c LCD Projector
My epson powerlite 83c overheats and shuts down
It works for 3-5 minutes at a time. After a minute or so of being off, it turns on and works for another 3-5 minutes. The bulb has been replaced. The bulb worked great for about 2-3 days and the problem started up again.
  • 32 Answers
SOURCE: Epson Powerlite 7300 Display Problem
Optical engine failure. Bad prizm.
Posted on Feb 13, 2008
zabolyx
  • 38 Answers
SOURCE: epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
  • 105 Answers
SOURCE: Epson 83+ powerlite projector overheat
hi follow the link bellow the instructions are on page 83 \\files.support.epson.com/pdf/pl83pl/pl83plug.pdf
Posted on Jun 04, 2009
EduTech
  • 54 Answers
SOURCE: Epson powerlite 83+. It comes on, then the 'heat' light flashes
Go to http://files.support.epson.com/pdf/pl83pl/pl83pl00ug.pdf#page=80&view=FitV&pagemode=none page 80, "What to do when the lights flash" . If that doesn't do it or it's not clear, please get back to me.
Posted on Jun 26, 2009
projdoc
  • 2237 Answers
SOURCE: Epson PowerLite 83+ goes completely green or red
make sure the signal matches. you could reset the settings to factory default.
Posted on Nov 19, 2009
Powerlite 77c keeps shutting down
Hi Dave,
have you inspected the led indicators after shutting down .
it must flashing and indicating pattern.normally epson have 3 LED indicators.
please come with blinking pattern or google it.
i think it is bulb problem,
regards,
nuwan
Jan 13, 2014 | Epson PowerLite 77c Projector
I changed the bulb on my epson powerlite 83+ and now there is a blurry spot in the middle of my screen. Is there anyway to fix this?
For anyone that may still stumble on this post, we have two of these and the blurry spot is most likely caused by the neutral density filter in front of the Green LCD element. We still haven't found a source for this part, but it seems to be caused when the bulb overheats and melts the plastic filter causing it to warp and wrinkle.
Jun 09, 2012 | Epson PowerLite® 83c LCD Projector
Image is upside down. ceiling option not available
Yes there is the option for ceiling mount in extended menu - here's the manual section 16 explains
http://files.support.epson.com/pdf/pl822p/pl822pug.pdf
Mar 24, 2011 | Epson PowerLite® 83c LCD Projector
I have an epson 83c, I have a flashing red lamp light
Hi!
You need to replace the lamp of your projector.
Hope this helps.
Mar 17, 2011 | Epson PowerLite® 83c LCD Projector
Projector will not turn on. Lamp light displays red and temperature light displays red.
I'm sorry to inform you that there is an internal error in the projector. Turn the projector off and unplug it. Contact Epson for help.
Feb 27, 2011 | Epson PowerLite® 83c LCD Projector
Epson powerlite is display is green when projecting form a computer
HI
problem with main board conatec service centre
M.R. Mumbai & Dubai
Sep 01, 2010 | Epson PowerLite® 83c LCD Projector
Projects upside down
go into the menu and reset the setting to factory default.
Dec 17, 2009 | Epson PowerLite® 83c LCD Projector
Nov 10, 2009 | Epson PowerLite® 83c LCD Projector
Jun 04, 2009 | Epson PowerLite® 83c LCD Projector
Epson PowerLite® 83c LCD Projector Logo
164 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
