Question about Refrigerators
I have a Kenmore to freezer model 106.74253400 when it stops running it clunks multiple times and shakes sounds like someone is knocking it is cooling properly. It's 9 years old.
    Genius:
  • 1,198 Answers
The compressor motor is rattling around in it's shell. It had mounts, but they wear out. It may be ok, but I would price replacing the compressor, or the whole unit, depending on what shape it is in.
Posted on Nov 28, 2013
  • 33 Answers
SOURCE: Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
Posted on Jan 01, 2008
22yooper
  • 828 Answers
SOURCE: compressor making a loud noise, freezer cannot cool
It sounds to me like the internal relief valve is lifting due to discharge pressure being to high such as it a system that is over charged with refrigerant. Have the system tested for pressures on high and low sides. If someone has serviced this unit recently there may be to much of a charge in the system. Also check the name place for the proper refrigerant and charge .
Posted on May 19, 2008
SOURCE: kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Posted on Feb 01, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
Posted on May 28, 2009
Testimonial: "It was the compressor. Bought a new Amana and it's great! Hate Sears still;)"
dmftrucker
  • 1922 Answers
SOURCE: Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Posted on Nov 01, 2009
Testimonial: "That's what my fridge is doing? Thanks for the help."
Very loud noises
Check the rubber mounts under the compressor and look for any lines touching the sides of the cabinet. The gurgling and clunking are often normal. good luck. Roger
Jan 19, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
I have a Kenmore 106.74253400 top freezer when it stops running it clunks multiple times and shakes though it's cooling properly.
The clunking noise, or shattering.. isn't likely to ever become a problem as far as cooling goes.... It will be more than likely try-your-patience than anything else . The compressor has springs located inside which are used to reduce the piston-travel when the unit reaches temperature and shuts off. Strange as it may sound, it won't cause the unit any harm.
Nov 27, 2013 | Refrigerators
Amana fridge stopped working for 2 days
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 03, 2012 | Amana AFF2534FE Bottom Freezer French...
Kenmore refrigerator makes clunking sound when motor shuts off. Repairman says it has a "broken leg". Wanted to replace the compressor. Can it be repaired WITHOUT replacing the motor?
Maybe... but it would take some "farmer rigging" to do it....most repair man have no idea how to just make things work anymore...do you know someone that is very good at making things work in a round about way???
Even getting a rag or something to pad underneath it may stop the clunking for the time being... giving you time to get money together at least for the repair...
It just depends on where and how badly the leg is broken...the unit is still very funtional... you just need to stop it from clunking...
heatman101
Aug 13, 2010 | Kenmore 60721 Refrigerator
What is the clunking noise made after the refrigerator stops running? Its a Kenmore and is 10 yrs old. We have thoroughly cleaned behind and beneath the refrigerator and now the noise seems louder.
The clunking noise you hear , is probably when the compressor shuts off , due to temp reached or when it goes into defrost . An internal motor mount spring , inside the compressor , is broken ( rusted and broke ) . The refrig can go on working for years , without any problem , except noisey , when it cuts off . To stop the noise , replaceing the compressor is the only option . I have heard of placeing objects under 1 leg of the compressor , to " re-adjust " the ballance , but thru my experience , another spring broke , causing more knocking .
Mar 24, 2010 | Kenmore 64802 Top Freezer Refrigerator
After the compressor runs it makes a loud clunking sound when it stops running. The sound comes from the compressor.
My guess is that it is running on high head probably caused by a dirty condenser. Try cleaning that. The noise itself is the actual compressor and motor bouncing around inside the hermetic can (what you call the compressor).
Good Luck
Gilshultz
Nov 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore Model 363 makes Clunking sound
sounds like the mount may b loose.(motor mount)
If so you may want to get under the machine and check to see if there are some screws missing or lost. (they may b on the floor rite next to the motor;)
good luck;)
Feb 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore top freezer fridge does not cool but freezer works
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Amana refridgerator mdl abl2222fes knock noise
sounds like the compressor vibration dampers are wearing out. the dampers are the rubber washers that seperate the compressor from the chassis of the fridge. when they start to deteriorate, and the compressor kicks on, it will bounce against something in the chassis, causing a knocking noise.
Jan 22, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
